S5500划分vlan的问题,怎么样搞头不通,或是部分通
  • 1收藏,907浏览
粉丝:0人 关注:8人
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
5130 CONFIG
5500 CONFI 看附件
5500 config请看附件
5 个回答
汽车大人 知了小白
粉丝:0人 关注:8人
[Core]display current-configuration
version 5.20, Release 2221P26
sysname Core
clock timezone HKT add 08:00:00
irf domain 10
irf mac-address persistent always
irf auto-update enable
undo irf link-delay
irf member 1 priority 30
irf member 2 priority 28
domain default enable system
dns server 192.168.77.60
dns server
ipv6
undo ip http enable
mirroring-group 1 local
password-recovery enable
vlan 1
vlan 10
vlan 15
vlan 30
vlan 70
vlan 77
description Internal
vlan 90
description Device-mgmt
radius scheme system
server-type extended
primary authentication 127.0.0.1 1645
primary accounting 127.0.0.1 1646
user-name-format without-domain
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
group-attribute allow-guest
local-user admin
password cipher
authorization-attribute level 3
interface Bridge-Aggregation10
description To-AC-WX3510H
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 90
link-aggregation mode dynamic
stp disable
mad enable
interface Bridge-Aggregation11
description To-AP-SW-S5130
port trunk permit vlan 77 90
stp disable
mad enable
interface Bridge-Aggregation102
description To-Edge-5F-1
port trunk permit vlan 2 to 4094
port trunk pvid vlan 77
stp disable
mad enable
interface Bridge-Aggregation104
description To-Edge
stp disable
mad enable
interface Bridge-Aggregation106
description To-Edge
stp disable
mad enable
interface Bridge-Aggregation108
description To-Edge
stp disable
mad enable
interface Bridge-Aggregation110
description To-Edge
stp disable
mad enable
interface Bridge-Aggregation112
description To-Edge
stp disable
mad enable
interface Bridge-Aggregation114
description To-Edge
stp disable
mad enable
interface NULL0
interface Vlan-interface77
ip address 192.168.77.218 255.255.255.0
interface Vlan-interface90
ip address 172.16.90.254 255.255.255.0
port link-mode bridge
description To-Edge-5F-1-1/0/47
port link-aggregation group 102
interface GigabitEthernet1/0/4
port link-aggregation group 104
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
port link-aggregation group 106
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
port link-aggregation group 108
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
port link-aggregation group 110
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
port link-aggregation group 112
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
port link-aggregation group 114
interface GigabitEthernet1/0/15
description To-AP-SW-1/0/21
port trunk permit vlan 50 77 90
mirroring-group 1 mirroring-port both
interface GigabitEthernet1/0/16
port access vlan 77
interface GigabitEthernet1/0/17
description To-AC-1/0/1
interface GigabitEthernet1/0/18
port access vlan 77
interface GigabitEthernet1/0/19
description To-PA1-8
port access vlan 30
interface GigabitEthernet1/0/20
port access vlan 77
interface GigabitEthernet1/0/21
description To-PA1-4-trust
interface GigabitEthernet1/0/22
port access vlan 77
interface GigabitEthernet1/0/23
description To-PA1-7
port trunk permit vlan 50 60 70
interface GigabitEthernet1/0/24
port access vlan 77
interface GigabitEthernet1/0/25
shutdown
interface GigabitEthernet1/0/26
shutdown
interface GigabitEthernet1/0/27
shutdown
interface GigabitEthernet1/0/28
shutdown
interface GigabitEthernet2/0/1
port trunk permit vlan all
interface GigabitEthernet2/0/2
description To-Edge-5F-1-1/0/48
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
description To-AP-SW-1/0/22
interface GigabitEthernet2/0/16
port access vlan 77
interface GigabitEthernet2/0/17
description To-AC-1/0/2
interface GigabitEthernet2/0/18
port access vlan 77
mirroring-group 1 monitor-port
interface GigabitEthernet2/0/19
description To-PA2-8
port access vlan 30
interface GigabitEthernet2/0/20
port access vlan 77
interface GigabitEthernet2/0/21
description To-PA2-4-trust
interface GigabitEthernet2/0/22
port access vlan 77
interface GigabitEthernet2/0/23
description To-PA2-7
interface GigabitEthernet2/0/24
port access vlan 77
interface GigabitEthernet2/0/25
shutdown
interface GigabitEthernet2/0/26
shutdown
interface GigabitEthernet2/0/27
shutdown
interface GigabitEthernet2/0/28
shutdown
interface Ten-GigabitEthernet1/1/1
description IRF
interface Ten-GigabitEthernet1/1/2
description IRF
interface Ten-GigabitEthernet2/1/1
description IRF
interface Ten-GigabitEthernet2/1/2
description IRF
ip route-static 0.0.0.0 0.0.0.0 192.168.77.254
ip route-static 10.210.0.0 255.255.0.0 192.168.77.1
ip route-static 10.210.10.0 255.255.255.0 192.168.77.1
ip route-static 192.168.47.0 255.255.255.0 192.168.77.1
ip route-static 192.168.53.0 255.255.255.0 192.168.77.1
ip route-static 192.168.193.0 255.255.255.0 192.168.77.1
ip route-static 192.168.200.0 255.255.255.0 192.168.77.1
ip route-static 192.168.215.0 255.255.255.0 192.168.77.1
ip route-static 192.168.248.0 255.255.255.0 192.168.77.1
ip route-static 192.168.250.0 255.255.255.0 192.168.77.1
ip route-static 192.168.253.0 255.255.255.0 192.168.77.1
ssh server enable
load xml-configuration
load tr069-configuration
user-interface aux 0 1
authentication-mode scheme
history-command max-size 256
user-interface vty 0 15
irf-port 1/2
port group interface Ten-GigabitEthernet1/1/1 mode normal
port group interface Ten-GigabitEthernet1/1/2 mode normal
irf-port 2/1
port group interface Ten-GigabitEthernet2/1/1 mode normal
port group interface Ten-GigabitEthernet2/1/2 mode normal
return
[Core]
bei 九段
粉丝:23人 关注:7人
直连不通的话,看看两边arp有没有
粉丝:6人 关注:2人
没有看到附件,中间打trunk放通对应VLAN,查看一下ARP是否学习到
粉丝:119人 关注:1人
老弟,你截图上相同的网段的VLAN ID都不一样啊,跨交换机,如果是二层,相同网段的VLAN ID需要配置成一样的
粉丝:124人 关注:6人
关于划分的VLAN不通,以下是排查要点,请参考:
1、检查交换机内是否已经创建了相应的VLAN。
2、交换机之间的互联需要走trunk,且trunk相应的VLAN通过。
3、在相关交换机内将VLAN划分到终端接入的端口。
4、在核心交换机上配置VLAN IP。
