icg 3000d
2018-05-13提问
  • 1收藏,1127浏览
现在是尖括号H3C那是输入的,那是电脑提示的?麻烦详细标一下,谢了
加粗了的是需要自己输入的
<Sysname> reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:y
Configuration file in flash is being cleared.
Please wait ...........
Configuration file is cleared.
<H3C>reboot                 //重启设备
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:n           //是否保存当前配置,此处选择n
 This command will reboot the device. Continue? [Y/N]:y      //是否要继续重启设备,选择y
#Jan  1 00:23:20:782 2013 H3C DEVM/1/REBOOT:
 Reboot device by command.
%Jan  1 00:23:20:782 2013 H3C DEVM/5/SYSTEM_REBOOT: System is rebooting now.
 Now rebooting, please wait...
<H3C>
System is starting...                 //提示系统正在启动,重启之后系统即恢复成出厂配置
