MSR3610,vlan 1里做了DHCP无法获取地址
2021-01-16提问
  • 1收藏,1298浏览
粉丝:0人 关注:10人
写两个地址池,端口下配地址可以正常获取DHCP地址,在vlan1三层接口下写地址,无法正常分发地址
组网就是一台路由器一个外线(完全正常),两个二层口,一个vlan1三层口,DHCP不正常
[ZCNSH_MSR3610] [ZCNSH_MSR3610]dis cu # version 7.1.064, Release 0605P13 # sysname ZCNSH_MSR3610 # ip pool aaa 192.168.10.1 192.168.10.253 ip pool aaa gateway 192.168.10.254 # dhcp enable dhcp server forbidden-ip 10.1.1.2 10.1.1.4 dhcp server always-broadcast # dns proxy enable # password-recovery enable # vlan 1 # dhcp server ip-pool Vlan-interface1 gateway-list 192.168.1.254 network 192.168.1.0 mask 255.255.255.0 address range 192.168.1.1 192.168.1.253 # controller Cellular0/0 # controller Cellular0/1 # interface Aux0 # interface Virtual-Template1 description VPN_BoHao ppp authentication-mode chap ppp ipcp dns 114.114.114.114 remote address pool aaa ip address 192.168.10.254 255.255.255.0 tcp mss 1422 # interface NULL0 # interface Vlan-interface1 ip address 192.168.1.254 255.255.255.0 # interface GigabitEthernet0/0 port link-mode route combo enable copper ip address 10.232.99.122 255.255.255.252 tcp mss 1280 undo dhcp select server # interface GigabitEthernet0/1 port link-mode bridge dhcp snooping trust # interface GigabitEthernet0/2 port link-mode bridge arp detection trust # scheduler logfile size 16 # line class aux user-role network-admin # line class tty user-role network-admin user-role network-operator # line class vty user-role network-admin user-role network-operator # line aux 0 user-role network-admin # line vty 0 63 authentication-mode scheme user-role network-operator # ip route-static 0.0.0.0 0 10.232.99.121 ip route-static 115.168.0.0 16 10.232.99.121 ip route-static 115.168.108.0 24 10.232.99.121 # password-control enable undo password-control aging enable undo password-control history enable password-control length 6 password-control login-attempt 3 exceed lock-time 10 password-control update-interval 0 password-control login idle-time 0 password-control complexity user-name check # radius scheme l2tp primary authentication 115.168.108.68 1645 key cipher $c$3$4rdDfmgRo52B8flyaFHOfJhroKriMHYm6Q== primary accounting 115.168.108.68 1646 key cipher $c$3$G7ralnsVzK14cLxRXtqbU5Q9c72Svf+KTw== nas-ip 10.232.99.122 # domain bsnsh.vpdn.sd authorization-attribute ip-pool 1 authentication ppp radius-scheme l2tp authorization ppp radius-scheme l2tp accounting ppp radius-scheme l2tp # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage service-type telnet http authorization-attribute user-role network-admin # local-user 123 class network password cipher $c$3$LoJwYw/8hlu9vcu/MpYUWDERVlc+WsuM service-type ppp authorization-attribute user-role level-15 authorization-attribute user-role network-operator # local-user zhoucnsh class network password cipher $c$3$MdekYYB/kM8lCrLa50Dup7HWTAD96thSJ80lnnTt service-type ppp authorization-attribute user-role level-15 authorization-attribute user-role network-operator # l2tp-group 1 mode lns allow l2tp virtual-template 1 undo tunnel authentication tunnel password cipher $c$3$yuAem8KolfJlzXdH27Habk8xygEJwUaBEQ== # l2tp enable # ip http enable # wlan global-configuration control-address disable # wlan ap-group default-group # return [ZCNSH_MSR3610]
粉丝:126人 关注:6人
关于无法自动获取IP地址,以下是排查要点,请参考:
1、检查DHCP是否已enable
2、检查VLAN是否已创建并配置了IP地址,同时VLAN是否已下发到了相应的端口。
3、检查DHCP地址池的子网是否和VLAN IP在一个子网内。
4、检查DHCP地址池的空间范围是否足够使用。
5、以下是MSR3600的用户手册链接:
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Routers/Catalog/MSR/MSR_3600/
粉丝:5人 关注:1人
配置发一下看看
电脑接哪个接口获取不到地址的
zhiliao_xUyMV 发表时间:2021-01-16
