AP注册失败问题
2021-01-18提问
  • 1收藏,1013浏览
粉丝: 关注:
AP注册时候发现的一些信息,这是什么意思?
第一段信息
*Jan 18 19:21:09:248 2021 AC CWS/7/ERROR: Failed to process discovery request from AP with serial ID 219801A0X78209E00550: No configration is available for the AP.
*Jan 18 19:21:09:248 2021 AC CWS/7/ERROR: Failed to proc pkt msg from AP at 10.10.22.208:40067. MsgType = 1.
第二段信息
*Jan 18 19:22:32:001 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:32:001 2021 AC CWS/7/ERROR: Failed to decode discovery request.uiAPID=0. *Jan 18 19:22:32:002 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:32:002 2021 AC CWS/7/ERROR: Failed to decode discovery request.uiAPID=0. *Jan 18 19:22:32:002 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:32:002 2021 AC CWS/7/ERROR: Failed to decode discovery request from ip:10.10.16.8.uiAPID=0. *Jan 18 19:22:32:002 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:32:002 2021 AC CWS/7/ERROR: Failed to proc pkt msg from AP at 10.10.16.8:2423. MsgType = 1. *Jan 18 19:22:32:002 2021 AC CWS/7/ERROR: Failed to decode discovery request.uiAPID=0. *Jan 18 19:22:32:003 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:32:003 2021 AC CWS/7/ERROR: Failed to decode discovery request.uiAPID=0. *Jan 18 19:22:32:003 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:32:003 2021 AC CWS/7/ERROR: Failed to decode discovery request from ip:10.10.16.8.uiAPID=0. *Jan 18 19:22:32:003 2021 AC CWS/7/ERROR: Failed to proc pkt msg from AP at 10.10.16.8:2423. MsgType = 1. *Jan 18 19:22:35:385 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:35:386 2021 AC CWS/7/ERROR: Failed to decode discovery request.uiAPID=0. *Jan 18 19:22:35:386 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:35:386 2021 AC CWS/7/ERROR: Failed to decode discovery request.uiAPID=0. *Jan 18 19:22:35:386 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:35:387 2021 AC CWS/7/ERROR: Failed to decode discovery request from ip:10.10.16.8.uiAPID=0. *Jan 18 19:22:35:387 2021 AC CWS/7/ERROR: Failed to proc pkt msg from AP at 10.10.16.8:2423. MsgType = 1. *Jan 18 19:22:35:387 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:35:387 2021 AC CWS/7/ERROR: Failed to decode discovery request.uiAPID=0. *Jan 18 19:22:35:387 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:35:387 2021 AC CWS/7/ERROR: Failed to decode discovery request.uiAPID=0. *Jan 18 19:22:35:388 2021 AC CWS/7/ERROR: Failed to decode TLV: Type=39, length=322. *Jan 18 19:22:35:388 2021 AC CWS/7/ERROR: Failed to decode discovery request from ip:10.10.16.8.uiAPID=0. *Jan 18 19:22:35:388 2021 AC CWS/7/ERROR: Failed to proc pkt msg from AP at 10.10.16.8:2423. MsgType = 1.
粉丝:124人 关注:6人
*Jan 18 19:21:09:248 2021 AC CWS/7/ERROR: Failed to process discovery request from AP with serial ID 219801A0X78209E00550: No configration is available for the AP.    //没有可用的授权给AP使用。
其次检查AP与AC的基础网络是否可达。
同时检查下AP的序列号是否有在AC内注册,且注册正确。
另外检查下DHCP地址池的空间范围是否足够使用。
检查AP与AC是否适配。
小茶 五段
粉丝:5人 关注:0人
升级一下AC的版本,看一下是不是不匹配
粉丝:38人 关注:3人
所有ap都没有上线吗?
有没有这个命令 wlan capwap discovery-policy unicast
zhiiiiao_N7L84 发表时间:2021-01-18
有上线的有没有上线的,这段信息是我在添加AP后立即debug 后出现的,我想看看这都是什么意思,什么原因导致出这样的信息,二层注册
发表时间:2021-01-18
回复:
手动注册的话检查下序列号以及ap与ac的通信,方便的话发一下配置看看
粉丝:4人 关注:3人
你好,请检查下,Ap能正常获取到ip地址吗?可以用电脑接在交换机端口上试下,是单个ap注册不上,还是所有ap都不行,确认故障具体现象?
同时检查下ac的相关配置是不是有误,AP的序列号是否正确等。另外检查下DHCP地址池的空间范围是否足够使用。检查AP与AC是否软件版本适配(参考官网手册)。
