哪位大神在线,给检查下核心交换机的配置,楼层与核心交换时段时续,十万火急,谢谢
2018-05-14提问
  • 1收藏,1582浏览
[Nm_Hx_S10508]disp curr
 # version 7.1.070, Release 7557P03
# mdc Admin id 1
# sysname Nm_Hx_S10508
 # telnet server enable
# forward-path-detection enable
 # dhcp enable
 # dhcp snooping enable
# system-working-mode standard password-recovery enable
 # vlan 1
 # vlan 10
 description 1F
# vlan 20 description 2F
 # vlan 30 description 3F
# vlan 31 description 3F-Shen_Pi_Zhong_Xin
 # vlan 40 description 4F
# vlan 41 description JiJianWeiLou
 # vlan 50 description 5F
 # vlan 60 description 6F
 # vlan 70 description 7F
# vlan 80 description 8F
# vlan 90 description 9F
 # vlan 100 description 10F
 # vlan 110 description 11F
 # vlan 120 description 12F
# vlan 130 description 13F
# vlan 140 description 14F
 # vlan 150 description 15F
# vlan 160 description 16F
# vlan 254
 # stp global enable
 # interface NULL0
# interface Vlan-interface1 description FuWuQi_GongZuoZu
 ip address 172.19.2.254 255.255.255.0
 # interface Vlan-interface10 description 1F
 ip address 172.19.10.254 255.255.255.0
 dhcp select relay
 dhcp relay server-address 172.19.2.6
# interface Vlan-interface20
 description 2F ip address 172.19.20.254 255.255.255.0
 dhcp select relay
# interface Vlan-interface30
 description 3F
 ip address 172.19.30.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface31
 description 3F-ShenPi ip address
 172.19.31.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface40
 description 4F
 ip address 172.19.40.254 255.255.255.0
 dhcp select relay
# interface Vlan-interface41
 ip address 172.19.41.254 255.255.255.0
 dhcp select relay
# interface Vlan-interface50
 description 5F
 ip address 172.19.50.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface60
 description 6F
 ip address 172.19.60.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface70
 description 7F
 ip address 172.19.70.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface80
 description 8F ip address
172.19.80.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface90 description 9F
 ip address 172.19.90.254 255.255.255.0
 dhcp select relay
# interface Vlan-interface100
 description 10F
 ip address 172.19.100.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface110
 description 11F
 ip address 172.19.110.254 255.255.255.0
 dhcp select relay
# interface Vlan-interface120
 description 12F
 ip address 172.19.120.254 255.255.255.0
 dhcp select relay
# interface Vlan-interface130
 description 13F
 ip address 172.19.130.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface140
 description 14F
 ip address 172.19.140.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface150
 description 15F
 ip address 172.19.150.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface160
 description 16F
 ip address 172.19.160.254 255.255.255.0
 dhcp select relay
 # interface Vlan-interface254
 description management-vlan
 ip address 172.19.254.254 255.255.255.0
 dhcp select relay
 # interface M-GigabitEthernet0/0/0
description Connect Dhcp_Server
 interface M-GigabitEthernet0/0/1
 interface M-GigabitEthernet0/0/2
# interface M-GigabitEthernet0/0/3
# interface Ten-GigabitEthernet0/0/1
 port link-mode bridge
 description 3F_PEIXIAN
 port link-type trunk
 port trunk permit vlan 1 10 20 30 254
 duplex full
# interface Ten-GigabitEthernet0/0/2
 description 5F_PEIXIAN
 port trunk permit vlan 1 40 50 254
 duplex full
 # interface Ten-GigabitEthernet0/0/3
 description 7F_PEIXIAN
 port trunk permit vlan 1 60 70 254
 duplex full
# interface Ten-GigabitEthernet0/0/4
 description 9F_PEIXIAN-1
 port trunk permit vlan 1 80 90 254
 duplex full
 # interface Ten-GigabitEthernet0/0/5
 description 11F_PEIXIAN
 port trunk permit vlan 1 110 120 254
 duplex full
 # interface Ten-GigabitEthernet0/0/6
 description 9F_PEIXIAN-2
 port link-type t
runk port trunk
permit vlan 1 80 90 100 254
 duplex full
# interface Ten-GigabitEthernet0/0/7
 description 13F_PEIXIAN
 port trunk permit vlan 1 130 140 254
 duplex full
 # interface Ten-GigabitEthernet0/0/8
 description 15F_PEIXIAN
 port trunk permit vlan 1 150 160 254
 speed 10000
 duplex full
# interface Ten-GigabitEthernet0/0/9
 description 4F-Hui_Yi_Shi
 port trunk permit vlan 1 41 254
 speed 1000
 duplex full
# interface Ten-GigabitEthernet0/0/10
 port trunk permit vlan 1 31 254
 speed 10000
 duplex full
# interface Ten-GigabitEthernet0/0/11
# interface Ten-GigabitEthernet0/0/12
 # interface Ten-GigabitEthernet0/0/13
# interface Ten-GigabitEthernet0/0/14
 # interface Ten-GigabitEthernet0/0/15
# interface Ten-GigabitEthernet0/0/16
# interface Ten-GigabitEthernet0/0/17
# interface Ten-GigabitEthernet0/0/18
 # interface Ten-GigabitEthernet0/0/19
# interface Ten-GigabitEthernet0/0/20
# interface Ten-GigabitEthernet0/0/21
 # interface Ten-GigabitEthernet0/0/22
# interface Ten-GigabitEthernet0/0/23
# interface Ten-GigabitEthernet0/0/24
 port link-mode bridge description Uplink_F1070-E
 port trunk permit vlan 1 254
 speed 10000
 duplex full
# scheduler logfile size 16
# line class aux
 user-role network-admin
 # line class vty user-role network-operator
 # line aux 0
 authentication-mode scheme
 # line aux 1 user-role network-admin
# line vty 0 4 authentication-mode scheme
# line vty 5 62 user-role network-operator
 # line vty 63
 ip route-static 0.0.0.0 0 172.19.2.253
# undo info-center enable
 # arp static 172.19.2.6 0014-5e23-85f8
# super password role network-admin hash $h$6$EoWVFNW31BfRFX6C$WJLVX/7Wp/8a70/gTQfWZGxlVO3TcgQCjap6HHEZEDHXz7z8y1OXlZBYWuOlITPnLeLqiW55aiEq/IjQ9HP1JQ== #
 domain system
 # domain default enable system
# role name level-0
 description Predefined level-0 role
# role name level-1
 description Predefined level-1 role
# role name level-2
 description Predefined level-2 role
 # role name level-3
 description Predefined level-3 role
 # role name level-4
 description Predefined level-4 role
 # role name level-5
 description Predefined level-5 role
 # role name level-6
 description Predefined level-6 role
 # role name level-7
 description Predefined level-7 role
 # role name level-8
 description Predefined level-8 role
 # role name level-9
 description Predefined level-9 role
 # role name level-10
 description Predefined level-10 role
 # role name level-11
 description Predefined level-11 role
# role name level-12
 description Predefined level-12 role
 # role name level-13
 description Predefined level-13 role
 # role name level-14
 description Predefined level-14 role
# user-group system
# local-user nmqxxb class manage password hash $h$6$VoijDVkYB71AoCcp$5FAQjS7FpGEj+Aqx8uwSZyzgM6y4Y7YzaLS/NJlw55/qqXQKxbm5Z3A2s37uJ1HL0bCgWExPWhIGmqn7/73GqQ== service-type telnet ssh terminal authorization-attribute user-role network-admin authorization-attribute user-role network-operator #
粉丝:56人 关注:4人
看看是不是网络环路,出现表象出接口漂移了
粉丝:13人 关注:3人
这个通过配置看不出来。  看看是不是互联接口光模块故障了
