X3508h恢复出厂命令
2021-01-20提问
  • 1收藏,618浏览
X3508恢复出厂配置命令
粉丝:38人 关注:3人
通过console线连接设备输入以下命令
<H3C>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
<H3C>reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
粉丝:39人 关注:3人
reset
粉丝:124人 关注:6人
以下是恢复出厂设置的方法,请参考:
方法一:
<H3C>reset saved-configuration   //清空配置
The saved configuration file will be erased. Are you sure? [Y/N]:y   //设备提示保存的配置将会被删除,是否继续。
Configuration file in flash: is being cleared. Please wait ...
MainBoard:
 Configuration file is cleared.   //配置已被清空
<H3C>reboot   //重启交换机
 Current configuration may be lost after the reboot, save current configuration? [Y/N]:n   //设备提示会在重启后丢失当前配置,是否保存当前配置,选择n
This command will reboot the device. Continue? [Y/N]:y   //设备提示设备将会重启,是否继续,选择Y
Now rebooting, please wait...
%Dec 14 20:48:39:352 2019 SW1 DEV/5/SYSTEM_REBOOT: System is rebooting now.
方法二:
<H3C>dir  //通过dir命令查看交换机的文件
Directory of flash:
   0 drw-           - Dec 14 2019 20:37:24   diagfile
   1 -rw-        1554 Dec 14 2019 20:50:06   ifindex.dat
   2 -rw-       21632 Dec 14 2019 20:37:24   licbackup
   3 drw-           - Dec 14 2019 20:37:24   license
   4 -rw-       21632 Dec 14 2019 20:37:24   licnormal
   5 drw-           - Dec 14 2019 20:48:38   logfile
   6 -rw-           0 Dec 14 2019 20:37:24   s5820v2_5830v2-cmw710-boot-a7514.bin
   7 -rw-           0 Dec 14 2019 20:37:24   s5820v2_5830v2-cmw710-system-a7514.bin
   8 drw-           - Dec 14 2019 20:37:24   seclog
   9 -rw-        6118 Dec 14 2019 20:50:06   startup.cfg  //这个是启动配置,我们要删除此文件
  10 -rw-      110464 Dec 14 2019 20:50:06   startup.mdb
1046512 KB total (1046300 KB free)
<H3C>delete startup.cfg   //使用删除命令删除startup.cfg这个启动运行的配置文件
Delete flash:/startup.cfg? [Y/N]:y   //设备提示是否要删除,选择Y
Deleting file flash:/startup.cfg... Done.   //设备提示startup.cfg这个文件已删除完成
<H3C>reboot   //重启
