小贝MSG360-10-PWR升级固件提示空间不足,手动删除boot.bin和system.bin释放空间升级,还是显示空间不足,后面重启了设备就进不了系统。这个情况该如何拯救?麻烦提供详细步骤,谢谢各位大侠!
释放空间后有290M空间
(0)
进不了系统,那就需要通过Bootrom下版本升级,软件包你应该下载好了吧,如果没关系的话就在bootware界面格式化一下,ctrl+F,然后再导入版本试试
1.
2.
3.
===============<EXTEND-BOOTWARE MENU>=========================
|<1> Boot System
|<2> Enter Serial SubMenu
|<3> Enter Ethernet SubMenu
|<4> File Control
|<5> Restore to Factory Default Configuration
|<6> Skip Current System Configuration
|<7> BootWare Operation Menu
|<8> Clear Super Password
|<9> Storage Device Operation
|<0> Reboot
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): 3(此处输入)
================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash
|<1> Download Application Program To SDRAM And Run
|<2> Update Main Application File
|<3> Update Backup Application File
|<4> Update Secure Application File
|<5> Modify Ethernet Parameter
|<0> Exit To Main Menu
|<Ensure The Parameter Be Modified Before Downloading!>
4.
Enter your choice(0-5): 5
===========<ETHERNET PARAMETER SET>=====================
|Note: '.' = Clear field.
| '-' = Go to previous field.
| Ctrl+D = Quit.
Protocol (FTP or TFTP) : TFTP
//忽略输出内容,直接输入TFTP,然后回车
Load File Name :MSG360_40-CMW710-R5221.ipe
//忽略输出内容,直接输入MSG360_40-CMW710-R5221.ipe,然后回车
Target File Name :MSG360_40-CMW710-R5221.ipe
Server IP Address :192.168.0.1
//忽略输出内容,直接输入电脑主机的 IP,比如192.168.0.1,然后回车
Local IP Address :192.168.0.50
//忽略输出内容,直接输入和电脑主机的ip同一网段,比如192.168.0.50,然后回车
Gateway IP Address :0.0.0.0
//忽略输出内容,直接回车
备注:注意给电脑手动配置一个与MSG360同网段的IP地址,保证电脑与MSG360路由可达,能ping通
|<1> Download Image Program To SDRAM And Run
|<2> Update Main Image File
|<3> Update Backup Image File
|<4> Download Files(*.*)
Enter your choice(0-5): 2 //此时可以看到TFTP服务器上数据上传的滚动
Loading.....................................................................
....................................Done!
5.
=================<Enter Ethernet SubMenu>==========================
Enter your choice(0-5): 0
6.
==================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot
Enter your choice(0-9): 0
System is starting...
重启设备完成后就可以使用设备管理地址登录MSG360进行管理,查看版本是否升级成功,命令行下通过命令
<H3C>display version
H3C Comware Software, Version 7.1.064, Release 5221
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
感谢回答我的问题,请问在哪里下载bootware软件?
这个在设备上电的时候进入命令行多按几次ctrl+B键,就可以进入这个了,这个不是软件,是类似于底层的一个系统啥的,和电脑的BIOS界面一样,进去之后就可以这样操作,格式化,这样内存应该就够了,其实可以下载这个手册查看,里面有一些维护:https://zhiliao.h3c.com/topic/huati/1249
大侠,你好,我现在可以进去bootroom,但是网卡灯不亮,如何下载固件进去?
用TFTP软件导入
