icg 3000d
2018-05-15提问
  • 1收藏,998浏览
qq正常,打开网页特慢,不论什么浏览器,哪位大侠帮看看,谢了。
<H3C>dis cu # version 5.20, Release 2514P14 # sysname H3C # domain default enable system # dar p2p signature-file flash:/p2p_default.mtd # port-security enable # password-recovery enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # dhcp server ip-pool vlan1 extended network ip range 192.168.1.1 192.168.1.254 network mask 255.255.255.0 gateway-list 192.168.1.1 dns-list 114.114.114.114 # dhcp server ip-pool vlan11 network 192.168.1.0 mask 255.255.255.0 gateway-list 192.168.1.1 dns-list 221.130.33.52 221.130.33.60 # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$dILcz64AQL4fohzSGpMJbZ1CKC4cRw== authorization-attribute level 3 service-type telnet service-type web # cwmp undo cwmp enable # interface Aux0 async mode flow link-protocol ppp # interface Cellular0/0 async mode protocol link-protocol ppp nat outbound # interface NULL0 # interface Vlan-interface1 ip address 192.168.1.1 255.255.255.0 dhcp server apply ip-pool vlan1 # interface GigabitEthernet0/0 port link-mode route nat outbound mtu 1300 tcp mss 1024 ip address dhcp-alloc # interface GigabitEthernet0/1 port link-mode route ip address dhcp-alloc # interface GigabitEthernet0/2 port link-mode bridge # interface GigabitEthernet0/3 port link-mode bridge # interface GigabitEthernet0/4 port link-mode bridge # interface GigabitEthernet0/5 port link-mode bridge # interface GigabitEthernet0/6 port link-mode bridge # interface GigabitEthernet0/7 port link-mode bridge # interface GigabitEthernet0/8 port link-mode bridge # interface GigabitEthernet0/9 port link-mode bridge # ip route-static 0.0.0.0 0.0.0.0 39.155.132.50 ip route-static 0.0.0.0 0.0.0.0 192.168.1.2 ip route-static 0.0.0.0 0.0.0.0 192.168.2.1 # dhcp enable # nms primary monitor-interface GigabitEthernet0/0 # load xml-configuration # load tr069-configuration # user-interface tty 12 user-interface aux 0 user-interface vty 0 4 authentication-mode scheme # return <H3C>
粉丝:17人 关注:2人
换个dns,不要使用114.114.114.114
