5800上收到tc变化宣告导致其他端口进入discarding状态
2021-02-06提问
  • 1收藏,2042浏览
零段
查看日志,显示五条:
Instance 0's port Ten-GigabitEthernet1/0/54 was notified of a topology change.
交换机部分端口进入discarding状态
Feb 5 19:33:42:067 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/2 has been set to discarding state. Feb 5 19:33:42:067 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/3 has been set to discarding state. Feb 5 19:33:42:067 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/6 has been set to discarding state. Feb 5 19:33:42:067 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/7 has been set to discarding state. Feb 5 19:33:42:068 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/11 has been set to discarding state. Feb 5 19:33:42:068 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/12 has been set to discarding state. Feb 5 19:33:42:068 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/13 has been set to discarding state. Feb 5 19:33:42:068 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/15 has been set to discarding state. Feb 5 19:33:42:068 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/16 has been set to discarding state. Feb 5 19:33:42:069 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/17 has been set to discarding state. Feb 5 19:33:42:069 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/18 has been set to discarding state. Feb 5 19:33:42:069 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/19 has been set to discarding state. Feb 5 19:33:42:069 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/20 has been set to discarding state. Feb 5 19:33:42:070 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/21 has been set to discarding state. Feb 5 19:33:42:070 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/22 has been set to discarding state. Feb 5 19:33:42:070 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/23 has been set to discarding state. Feb 5 19:33:42:070 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/24 has been set to discarding state. Feb 5 19:33:42:070 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/35 has been set to discarding state. Feb 5 19:33:42:071 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/36 has been set to discarding state. Feb 5 19:33:42:071 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/46 has been set to discarding state. Feb 5 19:33:42:073 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port GigabitEthernet1/0/48 has been set to discarding state. Feb 5 19:33:42:074 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port Ten-GigabitEthernet1/0/49 has been set to discarding state.
Feb 5 19:33:42:074 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port Ten-GigabitEthernet1/0/52 has been set to discarding state.
Feb 5 19:33:42:074 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port Ten-GigabitEthernet1/0/53 has been set to discarding state.
Feb 5 19:33:42:074 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port Bridge-Aggregation10 has been set to discarding state. Feb 5 19:33:42:074 2021 zhuzaocun-5800 STP/6/STP_DISCARDING: Instance 0's port Bridge-Aggregation50 has been set to discarding state. Feb 5 19:33:42:177 2021 zhuzaocun-5800 STP/6/STP_FORWARDING: Instance 0's port Bridge-Aggregation50 has been set to forwarding state.
查看
disp stp bpdu-statistics interface t1/0/54
 Port: Ten-GigabitEthernet1/0/54
 Instance-independent: Type Count Last Updated
 Invalid BPDUs 0
 Looped-back BPDUs 0
 MAX-aged BPDUs 0
 TCN sent 0
 TCN received 0
 TCA sent 0
 TCA received 0
 Config sent 0
 Config received 0
 RST sent 0
 RST received 0
 MST sent 52 00:05:38 02/06/2021
 MST received 1703461 02:14:22 02/06/2021
 Instance 0:
 Timeout BPDUs 0
 MAX-hoped BPDUs 0
 TC detected 1 15:55:04 12/28/2020
 TC sent 40 02:37:16 01/28/2021
 TC received 20 00:05:36 02/06/2021
请教,如何能查到tcn是从哪个设备发来的(通过mac可查?)
yyu 五段
粉丝:3人 关注:0人
Instance 0's port Ten-GigabitEthernet1/0/54 was notified of a topology change. 这个表示从g1/0/54口学过来的,从这个接口查日志,看下是否是有某台设备存在接口反复up/down情况导致
粉丝:8人 关注:1人
mac查不了  只能顺着接口往下查
粉丝:124人 关注:6人
检查Ten-GigabitEthernet1/0/54出来的物理链路是否正常。
根据Ten-GigabitEthernet1/0/54对端的设备,登陆上去看下是否有端口频繁UP DOWN。
其次确保本端设备的根桥稳定性,下联端口都可以配上根保护。
另外如果Ten-GigabitEthernet1/0/54对端设备无法管理到,可开启STP TC保护。
