S5120s ACL还是没有解决哦?感谢提点
2021-02-07提问
  • 1收藏,841浏览
粉丝:2人 关注:2人
怎么限制VLAN 11下的PC,只以允许某个地址192.168.2.90-99访问 VPN接口(VLAN 2或INT45),意思只允部份走VPN.
对齐方式
  • 靠左
  • 居中
  • 靠右
5120S配置下
vlan 1
 vlan 2
vlan 9 to 21
 vlan 100
dhcp server ip-pool v11
 network 192.168.2.0 mask 255.255.255.0
 gateway-list 192.168.2.1
 dns-list 61.139.2.69
 expired day 3
interface Vlan-interface1
 ip address dhcp-alloc client-identifier mac Vlan-interface1
interface Vlan-interface2
 ip address 192.1.1.6 255.255.255.252
interface Vlan-interface15
 ip address 192.168.6.2 255.255.255.0
 interface Vlan-interface11
 ip address 192.168.2.1 255.255.255.0 #
 interface GigabitEthernet1/0/1 port access vlan 11 dhcp-snooping information enable dhcp-snooping check mac-address # interface GigabitEthernet1/0/2 port access vlan 11 dhcp-snooping information enable dhcp-snooping check mac-address # interface GigabitEthernet1/0/3 port access vlan 11 dhcp-snooping information enable dhcp-snooping check mac-address # interface GigabitEthernet1/0/4 port access vlan 11 dhcp-snooping information enable dhcp-snooping check mac-address # interface GigabitEthernet1/0/5 port access vlan 11 dhcp-snooping information enable dhcp-snooping check mac-address # interface GigabitEthernet1/0/6 port access vlan 11 dhcp-snooping information enable dhcp-snooping check mac-address # interface GigabitEthernet1/0/7 port access vlan 11 dhcp-snooping information enable dhcp-snooping check mac-address #
interface GigabitEthernet1/0/45   这是去VPN接口
 port access vlan 2
 interface GigabitEthernet1/0/47  这是上外网接口
 description TO U200-M
 port access vlan 15 #
 ip route-static 0.0.0.0 0.0.0.0 192.168.6.1
 ip route-static 10.10.2.0 255.255.255.0 192.1.1.5
 ip route-static 192.168.1.0 255.255.255.0 192.1.1.5
 dhcp server forbidden-ip 192.168.2.1 192.168.2.100
粉丝:124人 关注:6人
vlan 11下的IP不是192.168.2.0网段的,且不明确2.0网段在网络中的位置,因此临时给出参考如下配置命令:
acl basic 2000
rule 0 permit source 192.168.2.90 0
rule 1 permit source 192.168.2.91 0
rule 2 permit source 192.168.2.92 0
rule 3 permit source 192.168.2.93 0
rule 4 permit source 192.168.2.94 0
rule 5 permit source 192.168.2.95 0
rule 6 permit source 192.168.2.96 0
rule 7 permit source 192.168.2.97 0
rule 8 permit source 192.168.2.98 0
rule 9 permit source 192.168.2.99 0
int vlan 11
packet-filter 2000 inbound
packet-filter 2000 outbound
rule 9 permit source 192.168.2.99 0 quit int vlan 11 packet-filter 2000 inbound packet-filter 2000 outbound 这样,99 没有法走互联网了
蜀天下 发表时间:2021-02-07
您是在有IPSEC VPN的环境下吗?
得闲饮茶013 发表时间:2021-02-07
rule 0 deny source 192.168.2.106 0 destination 192.1.1.5 255.255.255.252 interface Vlan-interface11 ip address 192.168.2.1 255.255.255.0 packet-filter 2001 inbound 这样无效果,还是可以通,,,packet-filter 2000 outbound 无法执行
蜀天下 发表时间:2021-02-07
90-99不走NAT转换,就走IPSEC VPN?
192.1.1.5是电信的入口,它路由到子公司网络上
蜀天下 发表时间:2021-02-07
具体网络拓扑图是怎么样的呢?
我不是很董,应不是lpset vpn,两端电信分别给了两个地址(一个是192.1.1.1 另一个是192.1.1.5),接在三层交换机上,相互路由,两公司的网就通了
蜀天下 发表时间:2021-02-07
感谢,明天上传个接线图
蜀天下 发表时间:2021-02-07
粉丝:145人 关注:1人
哪些地址走VPN,只要在感兴趣流里面匹配就行了
只允许部份 192.168.2.90-99 IP走VPN
蜀天下 发表时间:2021-02-07
粉丝:2人 关注:2人
再次感谢提点,
现在想实现只允许B公司部分IP(192.168.2.90-99)访问A公司网络
