S5120
2021-03-04提问
  • 1收藏,708浏览
<H3C> dis cu #
 version 5.20, Feature 2209P01
#sysname H3C
# domain default enable system # telnet server enable
 # vlan 1
# vlan 101 to 103
 # radius scheme system server-type extended primary authentication 127.0.0.1 1645 primary accounting 127.0.0.1 1646 user-name-format without-domain # domain system access-limit disable state active idle-cut disable self-service-url disable
# dhcp server ip-pool vlan101 network 10.10.1.0 mask 255.255.255.0 gateway-list 10.10.1.254 dns-list 10.168.1.244 10.168.1.245
 # dhcp server ip-pool vlan102 network 10.10.2.0 mask 255.255.255.0 gateway-list 10.10.2.254 dns-list 10.168.1.244 10.168.1.245
# dhcp server ip-pool vlan103 network 10.10.3.0 mask 255.255.255.0 gateway-list 10.10.3.254 dns-list 10.168.1.244 10.168.1.245
# user-group system
# local-user admin password simple lvcc authorization-attribute level 3 service-type telnet
# interface NULL0
 # interface Vlan-interface1 ip address 192.168.1.1 255.255.255.0 undo dhcp select server global-pool
# interface Vlan-interface101 ip address 10.10.1.254 255.255.255.0 dhcp select server global-pool
# interface Vlan-interface102 ip address 10.10.2.254 255.255.255.0 dhcp select server global-pool
# interface Vlan-interface103 ip address 10.10.3.254 255.255.255.0 dhcp select server global-pool
 # interface GigabitEthernet1/0/1 port link-type access port access vlan 101
# interface GigabitEthernet1/0/2 port link-type access port access vlan 102
# interface GigabitEthernet1/0/3 port link-type access port access vlan 103
# interface GigabitEthernet1/0/4
# interface GigabitEthernet1/0/5
# interface GigabitEthernet1/0/6 # interface GigabitEthernet1/0/7 # interface GigabitEthernet1/0/8 # interface GigabitEthernet1/0/9 # interface GigabitEthernet1/0/10 # interface GigabitEthernet1/0/11 # interface GigabitEthernet1/0/12 # interface GigabitEthernet1/0/13 # interface GigabitEthernet1/0/14 # interface GigabitEthernet1/0/15 # interface GigabitEthernet1/0/16 # interface GigabitEthernet1/0/17 # interface GigabitEthernet1/0/18 # interface GigabitEthernet1/0/19 # interface GigabitEthernet1/0/20 # interface GigabitEthernet1/0/21 # interface GigabitEthernet1/0/22 # interface GigabitEthernet1/0/23 # interface GigabitEthernet1/0/24 # interface GigabitEthernet1/0/25 # interface GigabitEthernet1/0/26 # interface GigabitEthernet1/0/27 # interface GigabitEthernet1/0/28 # interface GigabitEthernet1/0/29 # interface GigabitEthernet1/0/30 # interface GigabitEthernet1/0/31 # interface GigabitEthernet1/0/32 # interface GigabitEthernet1/0/33 # interface GigabitEthernet1/0/34 # interface GigabitEthernet1/0/35 # interface GigabitEthernet1/0/36 # interface GigabitEthernet1/0/37 # interface GigabitEthernet1/0/38 # interface GigabitEthernet1/0/39 # interface GigabitEthernet1/0/40 # interface GigabitEthernet1/0/41 # interface GigabitEthernet1/0/42 # interface GigabitEthernet1/0/43 # interface GigabitEthernet1/0/44 # interface GigabitEthernet1/0/45 # interface GigabitEthernet1/0/46 # interface GigabitEthernet1/0/47 # interface GigabitEthernet1/0/48 # interface GigabitEthernet1/0/49 shutdown # interface GigabitEthernet1/0/50 shutdown
 # interface GigabitEthernet1/0/51 shutdown
 # interface GigabitEthernet1/0/52 shutdown
# dhcp enable
 # load xml-configuration
# user-interface aux 0 user-interface vty 0 4 user privilege level 3 set authentication password simple admin user-interface vty 5 15
# return
PC机自动获取IP就可以vlan互通,手动修改同网段IP(10.10.1.1改为10.10.1.2,掩码,网关不变),vlan不能互通
4 个回答
粉丝:150人 关注:1人
地址冲突
手动改回10.10.1.1 仍然不通,只要使用DHCP自动获取就可以通
宁普记-18178973300 发表时间:2021-03-04
到网关通吗
叫我靓仔 发表时间:2021-03-04
粉丝:230人 关注:0人
检查一下地址对不对,一般测试的话用你自动获取的地址改为静态地址,防止影响内部其他地址
配置没有问题,PC机有双网卡,必须断掉另一个网卡,这个手动分配地址就可以通了
粉丝:14人 关注:0人
拓扑结构是什么样的?
