H3C WA3628i-AGN-FIT 刷胖AP教程说明
  • 1收藏,3957浏览
H3C WA3628i的COM口与电脑对接不上,波段用的9600;终端VT100.
粉丝:12人 关注:7人
请问现在AP是否有FIT版本?也就是能否完全启动进入系统?
如果有版本可以参考如下链接:
https://zhiliao.h3c.com/Theme/details/3012
没有FIT版本,参考如下方式:
启动设备,按ctr+b 进入bootrom 菜单
* H3C WA2200 BootWare, Version 2.12 *
Copyright (c) 2004-2010 Hangzhou H3C Technologies Co., Ltd.
Compiled Date : Dec 31 2010
CPU Type : PPC 405EP
CPU L1 Cache : 32KB
CPU Clock Speed : 266MHz
Memory Type : SDRAM
Memory Size : 64MB
Memory Speed : 133MHz
BootWare Size : 512KB
Flash Size : 8MB
PCB Version : Ver.B
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Please input BootWare password: //默认为空,回车即可
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>====
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Modify BootWare Password |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Clear Super Password |
|<9> Storage Device Operation |
|<0> Reboot |
Enter your choice(0-9):
ctrl+f 键,格式化flash
选择<7>,进入BootWare操作菜单,如图:
=====================<BOOTWARE OPERATION>====================
| <1> Backup Full BootWare                                  |
| <2> Restore Full BootWare                                 |
| <3> Update Full BootWare With XModem                      |
| <4> Update Extend BootWare With XModem                    |
| <5> Update Basic BootWare With XModem                     |
| <0> Exit To Main Menu                                     |
Enter your choice (0-5):
BootWare菜单中选择<3>更新BootWare程序
键入<5>,选择用115200的速度下载程序
========================<BAUDRATE SET>=======================
|Note:  Change The HyperTerminal's Baudrate Accordingly,    |
|       Press 'Enter' to exit with things untouched.        |
|--------------------<Baudrate Avaliable>-------------------|
| <1> 9600(Default)                                         |
| <2> 19200                                                 |
| <3> 38400                                                 |
| <4> 57600                                                 |
| <5> 115200                                                |
| <0> Exit                                                  |
Enter Your Choice (0-5):
系统会提示修改超级终端的波特率为115200
Download speed is 115200 bps. Change the terminal's speed to 115200 bps,
and select XMODEM protocol. Press 'Enter' key when ready.
修改超级终端的波特率为115200
超级终端传送菜单发送文件,选择BootWare升级文件cn5010BtmV1.25.app,开始升级,协议选择Xmodem
Now Downloading Program File.
Please Start Transfer Program File And Use Xmodem Protocol.
If You Want To Exit.Press 'Ctrl+X'.
Waiting...CCCCCCCCCCCCCCCCCCCCCCCCC
传送结束后,系统会提示是否升级基本段和扩展段,请全部选择“Y”。
Waiting...CCC
Download successfully!
404608 bytes downloaded!
Updating Basic BootWare? Yes or No (Y/N) :y
Updating Basic BTM
Updating the Norm Basic BootWare....Done
Updating Extend BootWare? Yes or No (Y/N) :y
Updating Extend BTM
Updating Extend BootWare....Done
Please use 9600 bps.Press 'Enter' key to exit to Main Menu.
更新完成后,根据提示,将波特率设置为9600,然后重新启动设备。
     System is rebooting now...
     System starts booting...
      *       H3C WCM BootWare , Ver 1.08       *
     Copyright(c) 2004-2006 Hangzhou H3C Tech. Co., Ltd. and its licensors.
     Compiled date   : Mar 22 2007, 14:44:29
     CPU type        : BCM1250
     CPU L1 DCache   : 32KB
     CPU L1 ICache   : 32KB
     CPU L2 Cache    : 512KB
     CPU Clock Speed : 700MHz
     Memory Type     : SDRAM
     Memory Size     : 512MB
     Memory Speed    : 140MHz
     Flash Size      : 64B
     NVRAM Size      : 512KB
     CPLD     Version is 1.00
     Hardware Version is Ver.C
     GE0    ..............................OK!
     GE1    ..............................OK!
瘦AP 目前进不去 只能用COM口进去调试 ,跳线对接好了电脑都认出来了。超级终端连接上就是没有反映。。。。。。
zhiliao_FpBsn 发表时间:2018-05-20
回复zhiliao_FpBsn:
console线 USB转接驱动 超级终端参数设置
战五渣 发表时间:2018-05-20
驱动换了几个一样,终端设置波段用的9600;终端VT100. 应该对的吧。换了几个波段也是一样。
设备也恢复出厂过....
回复zhiliao_FpBsn:
什么VT100?console口用的是COM口,跟VT没关系。
战五渣 发表时间:2018-05-20
====================<BOOTWARE OPERATION SERIAL SUB-MENU>==================== |<1> Update Full BootWare | |<2> Update Extend BootWare | |<3> Update Basic BootWare | |<4> Modify Serial Interface Parameter | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-4): 1 Please Start To Transfer File, Press <Ctrl+C> To Exit. Waiting ...CCCCCC stopped! Download failed!
zhiliao_FpBsn 发表时间:2018-05-28
连接上了,选择更新后出错。。。
粉丝:131人 关注:3人
consle 终端配置是波特率9600  数据位为8,RTS/CTS相关的选项都不要勾选。正常来说consle应该有输出,如果没有输出则可能出现硬件故障
用笔记本连接的RJ45转COM 在用COM对接 COM转USB,笔记本没COM口。WIN7*64的系统。
