内网无法访问服务器
2021-03-07提问
  • 1收藏,1290浏览
市局有一台服务器地址为172.15.242.2,只允许我局交换机S5500的10.96.189.0这个网段去访问,然后我想我单位的内网192.168.4.0这个网段可以直接访问,请问一下有什么方法。
S5500配置:
interface LoopBack0
 ip address 172.29.33.235 255.255.255.255
 interface LoopBack1
 ip address 80.23.8.2 255.255.255.255
  interface Vlan-interface100
 ip address 80.16.1.2 255.255.255.252
 interface Vlan-interface300 description Office LAN
 ip address 10.96.189.254 255.255.255.128
 interface Vlan-interface350 description Server LAN
 ip address 10.96.189.126 255.255.255.128
 interface Vlan-interface400 description TO_SiHui_MS3040-G0/1
 ip address 172.29.34.74 255.255.255.252
 interface Vlan-interface2906
 ip address 80.23.8.1 255.255.248.0
interface GigabitEthernet1/0/1 port access vlan 400
 interface GigabitEthernet1/0/2 port access vlan 300
 interface GigabitEthernet1/0/3 description to MSR20-20
 port access vlan 100
 interface GigabitEthernet1/0/4 description to-user-fw
interface GigabitEthernet1/0/25 description to-osn1500-huiju
 port link-type trunk
 port trunk permit vlan all
 interface GigabitEthernet1/0/27 description to PTN6200-huiju
 interface GigabitEthernet1/0/28 description to PTN6200-huiju
ospf 313 router-id 172.29.33.235
 import-route direct
 import-route static
 area 0.0.0.114
 network 172.29.33.235 0.0.0.0
 network 172.29.34.72 0.0.0.3
 network 10.96.189.0 0.0.0.255
 ip route-static 80.23.1.0 255.255.255.0 80.16.1.1
MSR20-20配置:
 nat address-group 1 80.23.1.0 80.23.1.253
 nat address-group 2 10.96.181.211 10.96.181.211
 acl number 2999
 rule 5 permit source 192.168.4.0 0.0.0.255
 acl number 3000
 rule 0 permit ip source 192.168.0.0 0.0.255.255 acl number 3001
 interface Ethernet0/0 port link-mode route description to-5500-0/3
 nat outbound 3000 address-group 1
 nat outbound 2999 address-group 2
 ip address 80.16.1.1 255.255.255.252
 interface Ethernet0/1 port link-mode route description to-user
 ip address 80.16.2.1 255.255.255.252
 undo dhcp select server global-pool
 dns server 202.96.128.86
 dns server 202.96.128.166
 ip route-static 0.0.0.0 0.0.0.0 80.16.1.2
 ip route-static 192.168.0.0 255.255.0.0 80.16.2.2
拓扑图
粉丝:124人 关注:6人
内网服务器无法映射出来,以下是排查要点,请参考:
1、检查内网服务器的路由是否可达。
2、可以使用nat server来进行映射。
3、如果映射的是常规端口,可能在运营商侧拦截了,建议使用非常规端口重新映射看下。
4、另外检查是否有安全设备的安全策略拦截。
知了小白
粉丝: 关注:
外网访问内网服务器配置nat server,限制访问源可以在nat server后加acl
对端我没办法控制的,只能在我20-20改
zhiliao_Marsd 发表时间:2021-03-08
粉丝:14人 关注:0人
可以把MSR20-20到S5500的地址改成10.96.189.X不?
不可以,他本身已经有业务在用了
80.16.1.X段只起到连接这两个设置的作用,其它地方没有用到,可以改的
落啦耳朵 发表时间:2021-03-08
我把地址改成了这个网段还是不行
zhiliao_Marsd 发表时间:2021-03-09
当然还要改路由: ip route-static 80.23.1.0 255.255.255.0 80.16.1.1和 ip route-static 0.0.0.0 0.0.0.0 80.16.1.2
落啦耳朵 发表时间:2021-03-09
