F100-C-A3 网通但不能使用https,IPsec VPN不会主动连
2021-03-11提问
  • 1收藏,1589浏览
威. 零段
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
一台F100和一台PC,最简单的网络,无其他设备
g1/0/1接的是电信pppoe,并且拨号成功,拿到动态公网IP
g1/0/3接的是一台电脑,使用IP 192.168.101.1/24,电脑端获得DHCP地址192.168.101.2/24
现象:
电脑(192.168.101.2/24)可以ping通公网IP:223.5.5.5。但电脑使用浏览器访问https网站无法访问,纯http的网站好像可以。security-policy ip里的rule3已经做了全放通。
作为分支端,和中心端的防火墙做IPsec VPN不会主动连,被动接受中心端的连接,VPN却可以UP。中心端内网IP主机可以ping通分支端的内网IP,但反过来不行(10.1.10.10可以ping通192.168.101.2,但101.2不能ping通10.10)
所有配置如下:
[H3C]display current-configuration
 version 7.1.064, Release 9524P27
 sysname H3C
context Admin id 1
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 dialer-group 1 rule ip permit
 dhcp enable
 password-recovery enable
vlan 1
vlan 100
object-group ip address shanghaigongsi
 security-zone Untrust
 0 network subnet 116.222.222.222 255.255.255.248
object-group ip address shanghaigongsi2
dhcp server ip-pool GuideSecDHCPPool
 gateway-list 192.168.101.1
 network 192.168.101.0 mask 255.255.255.0
 dns-list 223.5.5.5
dhcp server ip-pool pool192
 gateway-list 192.168.102.1
 network 192.168.102.0 mask 255.255.255.0
 dns-list 223.5.5.5
controller Cellular1/0/0
interface Dialer0
 mtu 1492
 ppp chap password cipher $fwfgewfwfdsfdsfwzf1XA2FS4RqUMR5T8I7
 ppp chap user ad12345678
 ppp ipcp dns admit-any
 ppp ipcp dns request
 ppp pap local-user ad12345678 password cipher $crewrewgcCfdafdsafsastlg+jgts6aysw8
 dialer bundle enable
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
 nat outbound description GuideNat
 nat outbound 3000
 ipsec apply policy to_ShangHaiJinQiao
interface NULL0
interface Vlan-interface100
 ip address 192.168.102.1 255.255.255.0
interface GigabitEthernet1/0/0
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
 description GuideWan Interface
 bandwidth 100000
 pppoe-client dial-bundle-number 0
 description GuideLan Interface
 ip address 192.168.101.1 255.255.255.0
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/4
 port link-mode bridge
 port access vlan 100
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/3
 import interface GigabitEthernet1/0/4 vlan 100
security-zone name DMZ
security-zone name Untrust
 import interface Dialer0
 import interface GigabitEthernet1/0/1
security-zone name Management
 import interface GigabitEthernet1/0/0
 import interface GigabitEthernet1/0/2
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 authentication-mode scheme
 user-role network-admin
line class usb
line class vty
line aux 0
line con 0
line vty 0 63
 ip route-static 0.0.0.0 0 Dialer0
 ssh server enable
acl advanced 3000
 rule 0 deny ip source 192.168.101.0 0.0.0.255 destination 10.1.0.0 0.0.255.255
 rule 40 permit ip source 192.168.101.0 0.0.0.255
 rule 50 permit ip
acl advanced name to_ShangHaiJinQiao
 rule 0 permit ip source 192.168.101.0 0.0.0.255 destination 10.1.0.0 0.0.255.255
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOhbabIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ==
 service-type ssh terminal https
 authorization-attribute user-role level-3
 ipsec logging negotiation enable
ipsec transform-set to_ShangHaiJinQiao
 esp encryption-algorithm 3des-cbc
 esp authentication-algorithm md5
ipsec policy to_ShangHaiJinQiao 65535 isakmp
 security acl name to_ShangHaiJinQiao
 remote-address 116.222.222.222
 ike-profile to_ShangHaiJinQiao
 sa duration time-based 28800
 sa duration traffic-based 1843200
nat global-policy
 rule name natrule1
  source-zone Trust
  destination-zone Untrust
 ike logging negotiation enable
ike profile to_ShangHaiJinQiao
 keychain to_ShangHaiJinQiao
 dpd interval 10 on-demand
 exchange-mode aggressive
 local-identity fqdn wh
 match remote identity fqdn jq
 match local address Dialer0
 proposal 65535
ike proposal 65534
 dh group2
 sa duration 3600
ike proposal 65535
 dh group2
ike keychain to_ShangHaiJinQiao
 pre-shared-key hostname jq key cipher $cgfdgsdsdy+4SGEXRxDpISblA==
 ip https port 10002
 ip http enable
 ip https enable
 webui log enable
netshare-control
inspect logging parameter-profile av_logging_default_parameter
inspect logging parameter-profile ips_logging_default_parameter
inspect logging parameter-profile url_logging_default_parameter
 loadbalance isp file flash:/lbispinfo_v1.5.tp
traffic-policy
 rule 1 name GuideAVCPolicy
  action qos profile guideavcprofile1
  source-zone Trust
  destination-zone DMZ
 profile name guideavcprofile1
  bandwidth downstream guaranteed 100000
  bandwidth downstream maximum 100000
security-policy ip
 rule 8 name tojq
  action pass
  counting enable
  destination-ip shanghaigongsi2
 rule 7 name GuideSecPolicy
  action pass
  source-zone Trust
 rule 6 name r3icmp
  action pass
  counting enable
  service ping
 rule 1 name shanghai
  action pass
  source-zone Untrust
  destination-zone Trust
 rule 2 name r2
  action pass
  counting enable
  source-zone Management
 rule 3 name r3
  action pass
  counting enable
 rule 4 name r4
  action pass
  source-zone Local
  destination-zone Management
 rule 5 name r5
  action pass
  source-zone Untrust
  destination-zone Local
ips logging parameter-profile ips_logging_default_parameter
anti-virus logging parameter-profile av_logging_default_parameter
return
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
粉丝:5人 关注:1人
出接口的nat outbound 删掉,只留一个nat out 3000,打不开https的问题,试一下修改tcp mss为1024
非常感谢,tcp mss1024解决了https的问题,但vpn还是有问题
威. 发表时间:2021-03-11
