WAP4320胖切瘦不成功,是需要下载瘦版本吗?
2021-03-11提问
  • 1收藏,818浏览
BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fat.bin! The main application file does not exist--flash:/wa4300s_fat.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails!
粉丝:40人 关注:3人
瘦版本在AC上获取,将AP与AC互联互通,AP切完瘦之后直接注册到AC即可
需要怎么注册一下...
黄高兴 发表时间:2021-03-11
BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fit.bin! The main application file does not exist--flash:/wa4300s_fit.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin! The secure application file does not exist--flash:/secure.bin! Booting App fails! Trying to get the IP address from the DHCP server...... DHCP server's IP address is 10.1.1.1 Client's assigned address is 10.1.1.2 DNS domain name got from DHCP server is DNS server's IP address is 8.8.8.8 Default Gateway's IP address is 10.1.1.1 This client's subnet mask is 255.255.255.0 The length of option 43 is: 0 Change State : Idle to Broadcast Discovery Change State : Broadcast Discovery to Unicast Discovery get ac [***.***]'s ip...
黄高兴 发表时间:2021-03-11
先看AC和AP的匹配关系,通过AC的版本说明书中的配套FIT AP列表查看;在AC上配置Ap的模板或者开启自动注册,具体的可参考官网的配置手册或者案例集http://h3c.com/cn/d_202006/1308030_30005_0.htm
Johnny囧尼 发表时间:2021-03-11
看样子是已经切成功了,就是AP没瘦版本而已
回复Johnny囧尼:
瘦ap版本怎么上传一下啊
黄高兴 发表时间:2021-03-11
粉丝:144人 关注:0人
<h3c>ap-mode fit
目前命令行都进去
黄高兴 发表时间:2021-03-11
这是胖切瘦的命令,隐藏命令,需要输入全,然后瘦的就没有版本了,需要控制器下发获取
无名之辈 发表时间:2021-03-11
粉丝:22人 关注:11人
没有ac的话找下周围同型号的ap copy一份下来传上去
