inode portal认证一直显示正在断开
2021-03-12提问
  • 1收藏,1412浏览
粉丝:0人 关注:4人
从日志看,服务器地址变成了1.0.0.1,请问为什么服务器地址会改变?能不能固定这个服务器地址。
C:\Program Files (x86)\iNode\iNode Client\Log\iNodePortal.2021031205.log日志如下:
[2021-03-12 08:38:12] [DtlCmn] [6474] Utlicmp Ping4: the ip is 1.0.0.1
[2021-03-12 08:38:13] [Err] [6474] Utlicmp Ping4: Call to IcmpSendEcho failed.Returned error: 11010
[2021-03-12 08:38:13] [Dbg] [6474] Portal CoTime: Detect Portal network fault.
[2021-03-12 08:38:13] [Dbg] [63b8] CPortalMgr::recvPortalHelloPacket there is no online connecton, just return.
[2021-03-12 08:38:17] [DtlCmn] [6474] Portal CoTime: Detect Portal server ipv4/ipv6 is 1.0.0.1
[2021-03-12 08:38:17] [DtlCmn] [6474] Utlicmp Ping4: the ip is 1.0.0.1
[2021-03-12 08:38:18] [Err] [6474] Utlicmp Ping4: Call to IcmpSendEcho failed.Returned error: 11010
[2021-03-12 08:38:18] [Dbg] [6474] Portal CoTime: Detect Portal network fault.
[2021-03-12 08:38:18] [Dbg] [63b8] CPortalMgr::recvPortalHelloPacket there is no online connecton, just return.
[2021-03-12 08:38:22] [DtlCmn] [6474] Portal CoTime: Detect Portal server ipv4/ipv6 is 1.0.0.1
[2021-03-12 08:38:22] [DtlCmn] [6474] Utlicmp Ping4: the ip is 1.0.0.1
[2021-03-12 08:38:23] [Err] [6474] Utlicmp Ping4: Call to IcmpSendEcho failed.Returned error: 11010
[2021-03-12 08:38:23] [Dbg] [6474] Portal CoTime: Detect Portal network fault.
[2021-03-12 08:38:23] [Dbg] [63b8] CPortalMgr::recvPortalHelloPacket there is no online connecton, just return.
[2021-03-12 08:38:27] [DtlCmn] [6474] Portal CoTime: Detect Portal server ipv4/ipv6 is 1.0.0.1
[2021-03-12 08:38:27] [DtlCmn] [6474] Utlicmp Ping4: the ip is 1.0.0.1
[2021-03-12 08:38:28] [Err] [6474] Utlicmp Ping4: Call to IcmpSendEcho failed.Returned error: 11010
[2021-03-12 08:38:28] [Dbg] [6474] Portal CoTime: Detect Portal network fault.
[2021-03-12 08:38:28] [Dbg] [63b8] CPortalMgr::recvPortalHelloPacket there is no online connecton, just return.
[2021-03-12 08:38:32] [DtlCmn] [6474] Portal CoTime: Detect Portal server ipv4/ipv6 is 1.0.0.1
[2021-03-12 08:38:32] [DtlCmn] [6474] Utlicmp Ping4: the ip is 1.0.0.1
[2021-03-12 08:38:33] [Err] [6474] Utlicmp Ping4: Call to IcmpSendEcho failed.Returned error: 11010
[2021-03-12 08:38:33] [Dbg] [6474] Portal CoTime: Detect Portal network fault.
[2021-03-12 08:38:33] [Dbg] [63b8] CPortalMgr::recvPortalHelloPacket there is no online connecton, just return.
[2021-03-12 08:38:37] [DtlCmn] [6474] Portal CoTime: Detect Portal server ipv4/ipv6 is 1.0.0.1
[2021-03-12 08:38:37] [DtlCmn] [6474] Utlicmp Ping4: the ip is 1.0.0.1
[2021-03-12 08:38:38] [Err] [6474] Utlicmp Ping4: Call to IcmpSendEcho failed.Returned error: 11010
[2021-03-12 08:38:38] [Dbg] [6474] Portal CoTime: Detect Portal network fault.
[2021-03-12 08:38:38] [Dbg] [63b8] CPortalMgr::recvPortalHelloPacket there is no online connecton, just return.
[2021-03-12 08:38:43] [DtlCmn] [6474] Portal CoTime: Detect Portal server ipv4/ipv6 is 1.0.0.1
[2021-03-12 08:38:43] [DtlCmn] [6474] Utlicmp Ping4: the ip is 1.0.0.1
[2021-03-12 08:38:43] [Err] [6474] Utlicmp Ping4: Call to IcmpSendEcho failed.Returned error: 11010
[2021-03-12 08:38:43] [Dbg] [6474] Portal CoTime: Detect Portal network fault.
[2021-03-12 08:38:43] [Dbg] [63b8] CPortalMgr::recvPortalHelloPacket there is no online connecton, just return.
[2021-03-12 08:38:48] [DtlCmn] [6474] Portal CoTime: Detect Portal server ipv4/ipv6 is 1.0.0.1
粉丝:144人 关注:0人
建立连接的时候,服务器地址确定,看日志是地址写错了,查看以下
地址是写好的,但是偶尔会自动变成1.0.0.1,比如说电脑待机了 再开起来 可能就自动变成1.0.0.1了
我本潇洒 发表时间:2021-03-12
