H3C S3100-26TP-SI
2018-05-23提问
  • 1收藏,1547浏览
H3C S3100-26TP-SI
一个端口下 VLAN 137 ,需要限制源ip 访问
端口下不支持packet-filter 求解
[sw-22-Ethernet1/0/3]? Ethernet interface view commands: arp Add static ARP entry broadcast-suppression Specify the broadcast storm control description Specify interface description dhcp-snooping DHCP snooping display Display current system information dot1x Specify 802.1X configuration information duplex Status of duplex enable Enable function flow-control Flow control command flow-interval Set interval of interface statistic garp Generic Attribute Registration Protocol gvrp GARP VLAN Registration Protocol igmp IGMP command igmp-snooping IGMP snooping lacp Configure LACP Protocol line-rate Limit the rate of the outbound or inbound packets of the interface link-delay Set port link-detect delay time lldp Link Layer Discovery Protocol(802.1ab) loopback Specify loopback of current port loopback-detection Detect if loopback exists mac-address Specify configuration about mac-address mac-authentication Specify MAC authentication configuration information mdi Specify mdi type mirroring-group Specify mirroring-group mirroring-port Specify mirroring port monitor-port Specify monitor port multicast Specify multicast configuration information multicast-suppression Specify the multicast storm control ndp Neighbor discovery protocol nslookup Query Internet name servers ntdp Specify NTDP configuration information ping Ping function port Specify Port link-type characteristics port-security Specify port-security configuration information priority Specify priority quit Exit from current command view return Exit to User View rmon Specify RMON save Save current configuration shutdown Shut down this interface speed Specify speed of current port storm-constrain Port storm-constrain stp Spanning tree protocol tracemac Trace MAC function tracert Trace route function undo Cancel current setting virtual-cable-test Display virtual cable test information vlan-vpn Specify VLAN VPN (Virtual Private Net) information [sw-22-Ethernet1/0/3]
粉丝:18人 关注:11人
难怪你不愿意透露姓名,透露姓名这么发问题会被打你知道吗?
另外你版本有问题吧,我查是支持的
http://www.h3c.com/cn/Service/Document_Software/Document_Center/Switches/Catalog/S3100/S3100-EI/Configure/Operation_Manual/H3C_S3100_OM-Release_22XX(V1.00)/
粉丝:2人 关注:3人
没看懂你发的东西呀
这个端口是二层口吧,建议把ACL做到int vlan 137接口上。inbound或者outbound要看具体情况。
