F1020怎么查看流量是否正常
2021-03-22提问
  • 1收藏,1044浏览
两台防火墙堆叠后,做了冗余备份,一端口断开后,怎么查看防火墙是否自动切换到备端口,如何查看流量是否正常
粉丝:95人 关注:1人
查看冗余组状态即可。
# 显示冗余组信息。可以看到优先级高的Node 1为主节点,Node 1和Node 2下面的成员接口都处于UP状态。
[Sysname-redundancy-group-aaa] display redundancy group aaa
Redundancy group aaa (ID 1):
  Node ID      Slot       Priority   Status        Track weight
  1            Slot1      100        Primary       255
  2            Slot2      50         Secondary     255
Preempt delay time remained     : 0    min
Preempt delay timer setting     : 1    min
Remaining hold-down time        : 0    sec
Hold-down timer setting         : 1    sec
Manual switchover request       : No
Member interfaces:
Member failover groups:
Node 1:
  Node member     Physical status
      GE1/0/1     UP
      GE1/0/2     UP
  Track info:
    Track    Status       Reduced weight     Interface
    1        Positive     255                GE1/0/1
    2        Positive     255                GE1/0/2
Node 2:
      GE2/0/1     UP
      GE2/0/2     UP
  Track info:
    3        Positive       255              GE2/0/1
    4        Positive       255              GE2/0/2
(2)     冗余组内主备倒换后的显示信息
# 手工关闭接口GigabitEthernet1/0/2,显示冗余组信息。可以看到优先级低的Node 2为主节点,Node 1的成员接口GigabitEthernet1/0/2故障(DOWN),GigabitEthernet1/0/1被协议关闭(DOWN(redundancy down)),Node 2的成员接口转发报文。
[Sysname-redundancy-group-aaa] quit
[Sysname-GigabitEthernet1/0/2] shutdown
[Sysname-GigabitEthernet1/0/2] display redundancy group aaa
  1            Slot1      100        Secondary     -255
  2            Slot2      50         Primary       255
Member interfaces:
Node 1:
      GE1/0/1       DOWN(redundancy down)
      GE1/0/2       DOWN
  Track info:
    1         Negative     255                GE1/0/1
    2         Negative     255                GE1/0/2 (Fault)
Node 2:
      GE2/0/1   UP
      GE2/0/2   UP
  Track info:
粉丝:145人 关注:1人
配置snmp,监控端口流量
粉丝:22人 关注:11人
长ping测试不就好了
粉丝:15人 关注:12人
<F1070>dis redundancy group
Redundancy group Internet (ID 1):
2 Slot2 50 Secondary -255
Preempt delay time remained : 0 sec
Preempt delay timer setting : 2 sec
Member interfaces:
Node 1:
GE1/0/4 UP
Track info:
1 Positive 255 N/A
3 Positive 255 N/A
Node 2:
GE2/0/1 UP
Track info:
2 Negative 255 N/A
4 Negative 255 N/A
注意字段Status 和 Track weight,一般1框的Status显示secondary就是切换成功了,可以在2框查看设备的业务口流量大小,来进一步确认2框接口有流量上来:
<F1070>dis int g 1/0/1
Current state: UP
Line protocol state: UP
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 3c8c-40b4-0926
IPv6 packet frame type: Ethernet II, hardware address: 3c8c-40b4-0926
Media type is twisted pair, loopback not set, promiscuous mode not set
1000Mb/s, Full-duplex, link type is autonegotiation
Output flow-control is disabled, input flow-control is disabled
Last link flapping: 2 weeks 4 days 18 hours 10 minutes
Last clearing of counters: 09:08:03 Wed 03/10/2021
Current system time:2021-03-23 14:29:29 Beijing+08:00:00
Last time when physical state changed to up:2021-03-04 20:19:08 Beijing+08:00:00
Last time when physical state changed to down:2021-03-04 20:15:57 Beijing+08:00:00
Peak input rate: 7543 bytes/sec, at 2021-03-11 22:13:04
Peak output rate: 62 bytes/sec, at 2021-03-10 09:08:29
Last 5 second input: 8 packets/sec 802 bytes/sec 0%    //关注这个字段
Last 5 second output: 0 packets/sec 0 bytes/sec 0%
Input (total): 7946948 packets, 777251528 bytes
0 unicasts, 2969516 broadcasts, 4977432 multicasts, 0 pauses
Input (normal): 7946948 packets, 777251528 bytes
Input: 0 input errors, 0 runts, 0 giants, - throttles
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, - parity errors
Output (total): 38082 packets, 11919666 bytes
0 unicasts, 0 broadcasts, 38082 multicasts, 0 pauses
Output (normal): 38082 packets, 11919666 bytes
Output: 0 output errors, 0 underruns, - buffer failures
0 lost carrier, 0 no carrier
