PC4 ping不同SWA PC4、PC5、SWB互通
配置如下:
Switch A
# system-view
# vlan 1
# vlan 2
# dhcp server ip-pool 0
network 10.1.1.0 mask 255.255.255.0
# dhcp server ip-pool 1
network 10.3.1.0 mask 255.255.255.0
gateway-list 10.3.1.1
# interface Vlan-interface1
# interface Vlan-interface2
ip address 10.2.1.1 255.255.255.0
# interface GigabitEthernet1/0/1
port access vlan 2
# interface GigabitEthernet1/0/2
# dhcp enable
# ip route-static 10.3.1.0 24 10.2.1.2
# Switch B
# system-view
# dhcp enable dhcp relay client-information record
# vlan 1
# vlan 2
ip address 10.3.1.1 255.255.255.0
dhcp select relay
dhcp relay server-address 10.2.1.1
ip verify source ip-address mac-address
ip address 10.2.1.2 255.255.255.0
port access vlan 2
(0)
您好, dhcp server ip-pool 0 缺少网关
(0)
左边是pool 0 右边两台是pool 1
地址池内未配置网关建议加入网关IP配置,然后电脑重新获取一下IP地址再试试
(0)
三台PC地址都获取到了 左边是pool 0 右边两台是pool 1 主要是PC4 ping不到SWA
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
PC4ping不通交换机,交换机可以ping通pc4吗 ?看得到arp地址吗?全部信息贴出来看下
右边的交换机有完整的ARP信息
