某局点WA2600i-AGN与AC建立CAPWAP隧道后不断重启
2021-03-31提问
  • 1收藏,818浏览
客户现场包含AC设备WX2540H以及WA2620i-AGN。
将wa2600a.ipe上传至apimge目录下后连入AP。
随后观察到,AP与AC的CAPWAP隧道建立并正常下载加载版本文件。
最后AP不断重启,其中版本文件从AC软件包中提取,AP在连入前已加载同样的版本文件。
循环重启过程如下:
<WA2620i-AGN>Decompressing file wa2600a-boot.bin to flash:/wa2600a-boot.bin..........
<WA2620i-AGN>..........Done.
Decompressing file wa2600a-system.bin to flash:/wa2600a-system.bin...................................................................
<WA2620i-AGN>..Done.
<WA2620i-AGN>%Mar 9 00:03:09:050 2012 WA2620i-AGN CWC/6/CWC_IMG_DOWNLOAD_COMPLETE: Downloading the image file wa2600a.ipe from AC 10.102.131.200 through the CAPWAP tunnel is complete. %Mar 9 00:03:09:050 2012 WA2620i-AGN CWC/6/CWC_AP_REBOOT: AP in state Image Data is rebooting. Reason: Image was downloaded successfully.
<WA2620i-AGN>%Mar 9 00:03:09:738 2012 WA2620i-AGN APMGR/6/APMGR_LOG_REBOOTCAUSE: Set Wlan Reboot Cause, SubSlot = 65535, DevRebootCause = 8, WlanRebootCause = 1, ulRet = 0.
<WA2620i-AGN>%Mar 9 00:03:16:567 2012 WA2620i-AGN DEV/5/SYSTEM_REBOOT: System is rebooting now.
<WA2620i-AGN> System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare....
The Extend BootWare is self-decompressing................................
Done!
AC版本为version 7.1.064, Release 5435P02 , 型号为WX2540H;AP型号为WA2620i-AGN
该重启问题是否和版本有关?
Xcheng 九段
粉丝:122人 关注:3人
根据反馈信息初步判断是ap之前版本太低,需要多次升级过渡到ac配套的版本即可。
建议先多等下在观察下。
如果等待很长时间,比如1-2小时故障依旧请拨打400热线处理。
