H3C S7506E-V 某些端口出现自动关闭,过几分钟又自动开启,交换机上出现以下日志,请问一下这个和光模块端口经常down有关系吗?
%May 14 18:26:49:117 2018 Core_Switch OPTMOD/4/PHONY_MODULE: -Chassis=2-Slot=4; Ten-GigabitEthernet2/4/0/1: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! %May 14 18:26:49:117 2018 Core_Switch OPTMOD/4/PHONY_MODULE: -Chassis=2-Slot=4; Ten-GigabitEthernet2/4/0/4: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! %May 14 18:26:49:118 2018 Core_Switch OPTMOD/4/PHONY_MODULE: -Chassis=2-Slot=4; Ten-GigabitEthernet2/4/0/5: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! %May 14 18:26:49:118 2018 Core_Switch OPTMOD/4/PHONY_MODULE: -Chassis=2-Slot=4; Ten-GigabitEthernet2/4/0/6: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! %May 14 18:26:49:118 2018 Core_Switch OPTMOD/4/PHONY_MODULE: -Chassis=2-Slot=4; Ten-GigabitEthernet2/4/0/7: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! %May 14 18:26:49:118 2018 Core_Switch OPTMOD/4/PHONY_MODULE: -Chassis=2-Slot=4; Ten-GigabitEthernet2/4/0/8: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! %May 14 18:28:53:153 2018 Core_Switch OPTMOD/4/PHONY_MODULE: -Chassis=2-Slot=2; Ten-GigabitEthernet2/2/0/1: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! %May 14 18:28:53:153 2018 Core_Switch OPTMOD/4/PHONY_MODULE: -Chassis=2-Slot=2; Ten-GigabitEthernet2/2/0/2: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof!
(0)
是匹配的,已经用了好多年了,最近才出现的这种情况
(0)
日志内容 [STRING]: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! 参数解释 $1:端口类型和编号 日志等级 4 举例 OPTMOD/4/PHONY_MODULE: GigabitEthernet1/0/13: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! 日志说明 光模块非H3C生产 处理建议 确认光模块兼容性或更换光模块
日志参考:http://www.h3c.com/cn/Service/Document_Software/Document_Center/Switches/Catalog/S7500E/S7500E/Maintenance/Message/H3C_S7500E_Message-R7178-6W101/
但是这些光模块我们已经用了3、4年了都没有出现过这种日志,最近这段时间才有的
光模块经常自动down了,过几分钟又自动up了
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
