超融合存储日志告警
  • 1收藏,1973浏览
粉丝:0人 关注:2人
超融合服务器是正常运行的,但是从后台日志中发现了如下报错:
2020-04-01 19:33:01.647015-[ERROR]-[TGT]-[pid:48512][target.c][tgt_cmd_io_error_print][line:2956]:cmd(0x7f0b97ca2650) return host(BGZ-UIS-06,***.***.redhat:server191,172.16.100.11), for lun 0 of op 9e1000 not ok, error code is [2, (05, 2000)].
2020-04-01 19:33:01.662925-[ERROR]-[TGT]-[pid:48512][target.c][tgt_cmd_io_error_print][line:2956]:cmd(0x7f0b97ca2650) return host(BGZ-UIS-06,***.***.redhat:server191,172.16.100.11), for lun 0 of op 9e1000 not ok, error code is [2, (05, 2000)].
2020-04-01 19:33:01.689198-[ERROR]-[TGT]-[pid:48512][target.c][tgt_cmd_io_error_print][line:2956]:cmd(0x7f0b97ca2650) return host(BGZ-UIS-06,***.***.redhat:server191,172.16.100.11), for lun 0 of op 9e1000 not ok, error code is [2, (05, 2000)].
2020-04-01 19:33:01.704359-[ERROR]-[TGT]-[pid:48512][target.c][tgt_cmd_io_error_print][line:2956]:cmd(0x7f0b97ca30d0) return host(BGZ-UIS-06,***.***.redhat:server191,172.16.100.11), for lun 0 of op 9e1000 not ok, error code is [2, (05, 2000)].
2020-04-01 19:33:01.721180-[ERROR]-[TGT]-[pid:48512][target.c][tgt_cmd_io_error_print][line:2956]:cmd(0x7f0b97ca30d0) return host(BGZ-UIS-06,***.***.redhat:server191,172.16.100.11), for lun 0 of op 9e1000 not ok, error code is [2, (05, 2000)].
2020-04-01 19:33:01.737401-[ERROR]-[TGT]-[pid:48512][target.c][tgt_cmd_io_error_print][line:2956]:cmd(0x7f0b97ca30d0) return host(BGZ-UIS-06,***.***.
尝试了共享存储暂停,删除,重启服务器等,还是报错2021-04-06 09:24:21.551781-[ERROR]-[TGT]-[pid:8893][target.c][tgt_io_error][line:3074]:scsi cmd(0x7fe77d11e4d0) error code is [2, (05, 2000)].
2021-04-06 09:24:21.551908-[ERROR]-[TGT]-[pid:8893][target.c][tgt_io_error][line:3039]:scsi cmd(0x7fe77d11e4d0) a1 08 2e 00 01 00 00 00 40 ec 00 00 00 00 00 00 failed.
2021-04-06 09:24:21.551925-[ERROR]-[TGT]-[pid:8893][target.c][tgt_io_error][line:3041]:scsi cmd(0x7fe77d11e4d0) from host(BGZ-UIS-06, ***.***.redhat:server191, 172.16.100.11) to target 512 lun .diskpool_hdd.rbd/defaultBlock_hdd failed.
2021-04-06 09:24:21.551936-[ERROR]-[TGT]-[pid:8893][target.c][tgt_io_error][line:3074]:scsi cmd(0x7fe77d11e4d0) error code is [2, (05, 2000)].
2021-04-06 09:24:21.573123-[WARN]-[TGT]-[pid:8893][scsi.c][scsi_cmd_perform][line:720]:no find lun 0, host_lun_id 4
2021-04-06 09:24:21.573132-[ERROR]-[TGT]-[pid:8893][target.c][tgt_io_error][line:3039]:scsi cmd(0x7fe77d11e4d0) a1 06 20 00 00 00 00 00 40 e5 00 00 00 00 00 00 failed.
2021-04-06 09:24:21.573136-[ERROR]-[TGT]-[pid:8893][target.c][tgt_io_error][line:3041]:scsi cmd(0x7fe77d11e4d0) from host(BGZ-UIS-06, ***.***.redhat:server191, 172.16.100.11) to target 512 lun (null) failed.
2021-04-06 09:24:21.573139-[ERROR]-[TGT]-[pid:8893][target.c][tgt_io_error][line:3074]:scsi cmd(0x7fe77d11e4d0) error code is [2, (05, 2500)].
2021-04-06 09:24:21.573210-[ERROR]-[TGT]-[pid:8893][target.c][tgt_io_error][line:3039]:scsi cmd(0x7fe77d11e4d0) a1 08 2e 00 01
粉丝:226人 关注:0人
您好,后台ceph -s查看是否是health ok状态。如果出现较频繁建议联系400排查下原因。
67 九段
粉丝:57人 关注:4人
是不是现场变更过存储的高可用地址,或者是变更过存储的target信息
从日志中看是访问不到这个target信息了。
