S5130-EI做irf
2021-04-06提问
  • 1收藏,832浏览
如题,请教  S5130S 可以做IRF吗
两台5130
粉丝:144人 关注:0人
您好,支持的,IRF配置参考
通过两条10G链路将两台S5820V2虚拟化成一台逻辑设备
二、 组网图:
三、 配置步骤:
1、配置S5820V2_1
选择一组SFP+端口作为IRF物理端口,本文中为Ten-GigabitEthernet1/0/1Ten-GigabitEthernet1/0/4。关闭该组中所有端口。为便于配置,下文中将使用接口批量配置功能关闭和开启物理端口。
[H3C] interface range name irf interface ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
[H3C-if-range-irf] shutdown
[H3C-if-range-irf] quit
配置IRF端口1/1,并将它与物理端口Ten-GigabitEthernet1/0/1Ten-GigabitEthernet1/0/2Ten-GigabitEthernet1/0/3Ten-GigabitEthernet1/0/4绑定。
[H3C] irf-port 1/1
[H3C-irf-port1/1] port group interface ten-gigabitethernet 1/0/1
[H3C-irf-port1/1] port group interface ten-gigabitethernet 1/0/2
[H3C-irf-port1/1] port group interface ten-gigabitethernet 1/0/3
[H3C-irf-port1/1] port group interface ten-gigabitethernet 1/0/4
[H3C-irf-port1/1] quit
开启Ten-GigabitEthernet1/0/1Ten-GigabitEthernet1/0/4端口,并保存配置。
[H3C-if-range-irf] undo shutdown
[H3C] save
激活IRF端口下的配置。
[H3C] irf-port-configuration active
2、 配置S5820V2_2
S5820V2_2的成员编号配置为2,并重启设备使新编号生效。
[H3C] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[H3C] quit
reboot
选择一组SFP+端口作为IRF物理端口,本文中为Ten-GigabitEthernet2/0/1Ten-GigabitEthernet2/0/4为例。
重新登录到设备,关闭选定端口组中的所有端口。
[H3C] interface range name irf interface ten-gigabitethernet 2/0/1 to ten-gigabitethernet 2/0/4
配置IRF端口2/2,并将它与物理端口Ten-GigabitEthernet2/0/1Ten-GigabitEthernet2/0/4绑定。
[H3C] irf-port 2/2
[H3C-irf-port2/2] port group interface ten-gigabitethernet 2/0/1
[H3C-irf-port2/2] port group interface ten-gigabitethernet 2/0/2
[H3C-irf-port2/2] port group interface ten-gigabitethernet 2/0/3
[H3C-irf-port2/2] port group interface ten-gigabitethernet 2/0/4
[H3C-irf-port2/2] quit
开启Ten-GigabitEthernet2/0/1Ten-GigabitEthernet2/0/4端口,并保存配置。
[H3C] save
激活IRF端口下的配置。
3S5820V2_1S5820V2_2间将会进行Master竞选,竞选失败的一方将重启,重启完成后,IRF形成。
4、配置验证:
[H3C]display irf
MemberID    Role    Priority  CPU-Mac         Description
  *1        Master  1         5866-ba8c-142d  ---
  +2        Standby 1         5866-ba8c-1496  ---
 The Bridge MAC of the IRF is: 5866-ba8c-142c
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 0
[H3C]display irf link
Member 1
 IRF Port    Interface                       Status
 1           Ten-GigabitEthernet1/0/1        UP
             Ten-GigabitEthernet1/0/2        UP
             Ten-GigabitEthernet1/0/3        DOWN
             Ten-GigabitEthernet1/0/4        DOWN
 2           disable                         --
Member 2
 1           disable                         --
 2           Ten-GigabitEthernet2/0/1        UP
             Ten-GigabitEthernet2/0/2        UP
             Ten-GigabitEthernet2/0/3        DOWN
             Ten-GigabitEthernet2/0/4        DOWN
可见堆叠成功。
四、 配置关键点:
1S5820V2-52QF/S5820V2-54QS-GE交换机上的所有SFP+/QSFP+口以及S5830V2-24S交换机上的所有SFP+口都可以用于IRF连接。如果选择S5820V2-52QF/S5830V2-24S设备的SFP+口作为IRF物理端口,需要注意的是:
· 设备上的SFP+口根据端口编号进行分组,从编号1开始,按端口编号由小到大的顺序,每4SFP+口分为一组。同一组中的所有端口用途必须相同,即当某一端口与IRF端口绑定后,该组内其它端口将不能再作为普通业务端口使用,反之亦然。
· 在将某个SFP+口与IRF端口进行绑定或取消绑定之前,必须先对该SFP+口所在组内的所有SFP+口执行shutdown操作;在完成绑定或取消绑定操作后,再对同组内所有SFP+口执行undo shutdown操作。使用接口批量配置功能可以更快捷的完成以上操作。
2、在将物理口跟堆叠逻辑口绑定前,必须将一组的四个端口全部shutdown,否则会报如下错误:
Check Failed For Reason:
Interfaces Ten-GigabitEthernet1/0/1 to Ten-GigabitEthernet1/0/4 belong to a port group,Please shutdown all of them before changing the working mode.
3、堆叠时必须将该组的四个物理口全部跟一个或两个逻辑口绑定,否则会报错:
Bind all interfaces in the same group to one or two IRF ports or cancel the bindings on all of them.Configuration terminated because it failed on Ten-GigabitEthernet1/0/1.
我这个没有万兆口 我换方法准备用堆叠吧。有堆叠的指导吗
大清朝IT信息部 发表时间:2021-04-06
参考一下链接https://www.h3c.com/cn/d_202004/1284814_30005_0.htm#_Toc37771865
无名之辈 发表时间:2021-04-06
粉丝:124人 关注:6人
支持IRF的。
以下是配置举例:
H3C HCL S5820配置IRF的案例:
网络拓扑图:
图中两台S5820交换机都分别使用万兆口50口、51口进行互联,其中1号设备、2号设备均已在拓扑图中标识清楚,1代表成员1、2代表成员2
配置步骤
1、1号设备设定为IRF 1号成员,2号设备设定为IRF 2号成员。
2、绑定IRF端口。
3、激活IRF功能。
4、检查设备是否已堆叠完成。
配置关键点
1、1号设备关键配置如下:
[H3C]irf member 1 renumber 1     //将1号设备设定为成员1
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]:y
[H3C]int range Ten-GigabitEthernet 1/0/50 to Ten-GigabitEthernet 1/0/51
[H3C-if-range]shutdown
[H3C-if-range]quit
[H3C]irf-port 1/1  //将物理端口绑定到IRF端口
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/1]quit
[H3C-if-range]undo shutdown
[H3C-if-range]quit
[H3C]irf-port-configuration active  //激活IRF
[H3C]save
2、2号设备关键配置点如下:
[H3C]irf member 1 renumber 2  //将2号设备设定为成员2
[H3C-if-range]quit
[H3C]irf-port 1/2  //将物理端口绑定到IRF端口
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/2]quit
[H3C-if-range]quit
[H3C]save
3、分别将成员1设备、成员2设备重启
4、测试
<H3C>dis irf  //查看IRF的信息,看到成员1和成员2的设备信息都在一起
 *+1        Master  1         30bd-490a-0104  ---
   2        Standby 1         30bd-525e-0204  ---
 The bridge MAC of the IRF is: 30bd-490a-0100
 Auto upgrade                : yes
 Domain ID                   : 0
<H3C>
<H3C>dis irf link  //查看成员1、成员2 IRF链路的状态均为UP
Member 1
 1         Ten-GigabitEthernet1/0/50             UP
           Ten-GigabitEthernet1/0/51             UP
 2         disable                               --
Member 2
 1         disable                               --
 2         Ten-GigabitEthernet2/0/50             UP
           Ten-GigabitEthernet2/0/51             UP
<H3C>
<H3C>dis irf configuration  //查看IRF的配置信息
 MemberID NewID    IRF-Port1                     IRF-Port2
 1        1        Ten-GigabitEthernet1/0/50     disable
 2        2        disable                       Ten-GigabitEthernet2/0/50
<H3C>
<H3C>dis irf topology  //查看IRF的拓扑信息
                              Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 2           DIS        ---           UP         1           30bd-490a-0104
 1           UP         2             DIS        ---         30bd-490a-0104
<H3C>
至此S5820交换机的IRF已配置完成!
粉丝:17人 关注:5人
可以做irf堆叠。
前提是确保两台设备的型号,版本等都是一样的。
堆叠口一般是万兆端口进行堆叠,或者10G端口堆叠。
