s5130怎么加网段
2021-04-10提问
  • 1收藏,818浏览
s5130怎么添加网段
s5130怎么添加网段
粉丝:226人 关注:0人
您好,参考
vlan 11
dhcp server ip-pool 11
gateway-list 192.168.11.254
network 192.168.11.0 mask 255.255.255.0
dns-list 61.134.1.4 221.11.1.67
expired day 0 hour 1
interface Vlan-interface11
ip address 192.168.11.254 255.255.255.0
interface GigabitEthernet0/0/17
port link-mode bridge
port access vlan 11
粉丝:19人 关注:3人
新加网段注意要划分vlan,对应端口加进vlan里面,然后在int vlan xxx 里面配置网关就好了
粉丝:124人 关注:6人
正常创建VLAN,配置VLAN IP,将VLAN划分端口就可以了。
如果有需求实现IP的自动获取,还需要配置DHCP。以下是配置参考命令:
将交换机的名字修改为SW1:
[H3C]sysname SW1
在交换机分别创建VLAN 10、VLAN 20:
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]vlan 20
[SW1-vlan20]quit
VLAN 10的IP设置为:192.168.10.1 255.255.255.0:
[SW1]int vlan 10
[SW1-Vlan-interface10]ip address 192.168.10.1 24
[SW1-Vlan-interface10]quit
VLAN 20的IP设置为:192.168.20.1 255.255.255.0:
[SW1]int vlan 20
[SW1-Vlan-interface20]ip address 192.168.20.1 24
[SW1-Vlan-interface20]quit
将GI1/0/1端口划分到VLAN 10:
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-type access
[SW1-GigabitEthernet1/0/1]port access vlan 10
[SW1-GigabitEthernet1/0/1]quit
将GI1/0/2端口划分到VLAN 20:
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]port link-type access
[SW1-GigabitEthernet1/0/2]port access vlan 20
[SW1-GigabitEthernet1/0/2]quit
开启DHCP功能:
[SW1]dhcp enable
创建DHCP地址池,命名为VLAN10,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan10
[SW1-dhcp-pool-vlan10]network 192.168.10.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan10]gateway-list 192.168.10.1
[SW1-dhcp-pool-vlan10]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan10]quit
[SW1]
创建DHCP地址池,命名为VLAN20,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan20
[SW1-dhcp-pool-vlan20]network 192.168.20.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan20]gateway-list 192.168.20.1
[SW1-dhcp-pool-vlan20]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan20]quit
