H3C SSL VPN和ipset vpn的配置案例
2021-04-13提问
  • 1收藏,2002浏览
麻烦给我发一下H3C SSL VPN和ipset vpn的配置案例
总公司和分公司vpn
粉丝:22人 关注:1人
SSL VPN配置示例:
IP接入配置举例(缺省证书)
interface SSLVPN-AC1
 ip address 10.1.1.100 255.255.255.0
acl advanced 3000
 rule 0 permit ip source 10.1.1.0 0.0.0.255 destination 20.2.2.0 0.0.0.255
sslvpn ip address-pool sslvpnpool 10.1.1.1 10.1.1.10
sslvpn gateway gw
 ip address 1.1.1.2 port 4430
 service enable
sslvpn context ctxip
 gateway gw domain domainip
 ip-tunnel interface SSLVPN-AC1
 ip-tunnel address-pool sslvpnpool mask 255.255.255.0
 ip-route-list rtlist
  include 20.2.2.0 255.255.255.0
 policy-group resourcegrp
  filter ip-tunnel acl 3000
  ip-tunnel access-route ip-route-list rtlist
 service enable
local-user sslvpnuser class network
 password simple 123456
 service-type sslvpn
 authorization-attribute sslvpn-policy-group resourcegrp
[H3C]display sslvpn gateway
Gateway name: gw
  Operation state: Up
  IP: 1.1.1.2  Port: 4430
  Front VPN instance: Not configured
[H3C]display sslvpn context
Context name: ctxip
  Operation state: Up
  AAA domain: Not specified
  Certificate authentication: Disabled
  Password authentication: Enabled
  Authentication use: All
  Dynamic password: Disabled
  Code verification: Disabled
  Default policy group: Not configured
  Associated SSL VPN gateway: gw
    Domain name: domainip
  Maximum users allowed: 1048575
  Idle timeout: 30 min
IPsec野蛮模式配置示例:
RTA------------------------------------------------------------------RTB
RTA分部:
192.168.1.0/24 1.1.1.1/24 1.1.1.2/24 192.168.2.0/24
interface LoopBack0
ip address 192.168.1.1 255.255.255.255
interface GigabitEthernet0/0
ip address 1.1.1.1 255.255.255.0
ipsec apply policy policy1
ip route-static 0.0.0.0 0 1.1.1.2
acl advanced 3000
rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.2.0 0.0.0.255
ipsec transform-set tran1
esp encryption-algorithm aes-cbc-128
esp authentication-algorithm sha1
ipsec policy policy1 1 isakmp
transform-set tran1
security acl 3000
remote-address 1.1.1.2
ike-profile 1
ike identity fqdn RTA
ike profile 1
keychain 1
exchange-mode aggressive
match remote identity fqdn RTB
proposal 1
ike proposal 1
encryption-algorithm 3des-cbc
authentication-algorithm md5
ike keychain 1
pre-shared-key address 1.1.1.2 255.255.255.0 key simple 123
RTB:总部
interface LoopBack0
ip address 192.168.2.1 255.255.255.255
ip address 1.1.1.2 255.255.255.0
ipsec apply policy 1
ip route-static 0.0.0.0 0 1.1.1.1
acl advanced 3000
rule 0 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
ipsec policy-template template1 1
transform-set tran1
#可以不写ACL
#security acl 3000
ike-profile 1
ipsec policy 1 1 isakmp template template1
ike identity fqdn RTB
ike profile 1
keychain 1
match remote identity fqdn RTA
proposal 1
ike proposal 1
ike keychain 1
pre-shared-key hostname RTA key simple 123
粉丝:124人 关注:6人
以下是IPSEC VPN的配置案例:
组网说明:
本案例采用H3C HCL模拟器的F1060防火墙来模拟IPSEC+IKE预共享密钥的典型组网配置。在网络拓扑图中存在子网1和子网2.为了保障子网1和子网2相互传输数据的安全性,因此需要在FW1与FW2采用IKE预共享的方式建立IPSEC VPN隧道。
配置步骤
配置思路:
1、按照网络拓扑图正确配置IP地址
2、FW1与FW2的互联接口加入安全域,并放通域间策略
3、FW1与FW2建立IPSEC VPN隧道,采用IKE预共享的方式
配置关键点
ISP:
sys
[H3C]sysname ISP
[ISP]int gi 0/0
[ISP-GigabitEthernet0/0]des
[ISP-GigabitEthernet0/0]ip address 202.1.100.1 30
[ISP-GigabitEthernet0/0]quit
[ISP]int gi 0/1
[ISP-GigabitEthernet0/1]des
[ISP-GigabitEthernet0/1]ip address 202.2.100.1 30
[ISP-GigabitEthernet0/1]quit
[ISP]ip route-static 192.168.1.0 255.255.255.0 202.1.100.2
[ISP]ip route-static 172.16.1.0 255.255.255.0 202.2.100.2
FW1:
sys
[H3C]sysname FW1
[FW1]int gi 1/0/3
[FW1-GigabitEthernet1/0/3]ip address 192.168.1.1 24
[FW1-GigabitEthernet1/0/3]quit
[FW1]int gi 1/0/2
[FW1-GigabitEthernet1/0/2]des
[FW1-GigabitEthernet1/0/2]ip address 202.1.100.2 30
[FW1-GigabitEthernet1/0/2]quit
[FW1]ip route-static 0.0.0.0 0.0.0.0 202.1.100.1
[FW1]security-zone name Trust
[FW1-security-zone-Trust]import interface GigabitEthernet 1/0/3
[FW1-security-zone-Trust]quit
[FW1]security-zone name Untrust
[FW1-security-zone-Untrust]import interface GigabitEthernet 1/0/2
[FW1-security-zone-Untrust]quit
[FW1]zone-pair security source trust destination untrust
[FW1-zone-pair-security-Trust-Untrust]packet-filter 2001
[FW1-zone-pair-security-Trust-Untrust]quit
[FW1]
[FW1]zone-pair security source untrust destination trust
[FW1-zone-pair-security-Untrust-Trust]packet-filter 2001
[FW1-zone-pair-security-Untrust-Trust]quit
[FW1]
[FW1]zone-pair security source trust destination local
[FW1-zone-pair-security-Trust-Local]packet-filter 2001
[FW1-zone-pair-security-Trust-Local]quit
[FW1]
[FW1]zone-pair security source local destination trust
[FW1-zone-pair-security-Local-Trust]packet-filter 2001
[FW1-zone-pair-security-Local-Trust]quit
[FW1]
[FW1]zone-pair security source untrust destination local
[FW1-zone-pair-security-Untrust-Local]packet-filter 2001
[FW1-zone-pair-security-Untrust-Local]quit
[FW1]
[FW1]zone-pair security source local destination untrust
[FW1-zone-pair-security-Local-Untrust]packet-filter 2001
[FW1-zone-pair-security-Local-Untrust]quit
FW1 IPSEC+IKE预共享密钥 关键配置点:
[FW1]acl advanced 3000
[FW1-acl-ipv4-adv-3000]rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 172.16.1.0 0.0.0.255
[FW1-acl-ipv4-adv-3000]quit
[FW1]ike keychain james
[FW1-ike-keychain-james]pre-shared-key address 202.2.100.2 255.255.255.252 key simple james
[FW1-ike-keychain-james]quit
[FW1]ike proposal 1
[FW1-ike-proposal-1]quit
[FW1]ike profile james
[FW1-ike-profile-james]keychain james
[FW1-ike-profile-james]proposal 1
[FW1-ike-profile-james]match remote identity address 202.2.100.2 255.255.255.252
[FW1-ike-profile-james]quit
[FW1]ipsec transform-set james
[FW1-ipsec-transform-set-james]protocol esp
[FW1-ipsec-transform-set-james]encapsulation-mode tunnel
[FW1-ipsec-transform-set-james]esp authentication-algorithm md5
[FW1-ipsec-transform-set-james]esp encryption-algorithm des-cbc
[FW1-ipsec-transform-set-james]quit
[FW1]ipsec policy james 1 isakmp
[FW1-ipsec-policy-isakmp-james-1]security acl 3000
[FW1-ipsec-policy-isakmp-james-1]transform-set james
[FW1-ipsec-policy-isakmp-james-1]ike-profile james
[FW1-ipsec-policy-isakmp-james-1]remote-address 202.2.100.2
[FW1-ipsec-policy-isakmp-james-1]quit
[FW1]int gi 1/0/2
[FW1-GigabitEthernet1/0/2]ipsec apply policy james
FW2:
sys
[FW2]int gi 1/0/3
[FW2-GigabitEthernet1/0/3]ip address 172.16.1.1 24
[FW2-GigabitEthernet1/0/3]quit
[FW2]int gi 1/0/2
[FW2-GigabitEthernet1/0/2]des
[FW2-GigabitEthernet1/0/2]ip address 202.2.100.2 30
[FW2-GigabitEthernet1/0/2]quit
[FW2]ip route-static 0.0.0.0 0.0.0.0 202.2.100.1
[FW2]security-zone name Trust
[FW2-security-zone-Trust]import interface GigabitEthernet 1/0/3
[FW2-security-zone-Trust]quit
[FW2]security-zone name Untrust
[FW2-security-zone-Untrust]import interface GigabitEthernet 1/0/2
[FW2-security-zone-Untrust]quit
[FW2]acl basic 2001
[FW2-acl-ipv4-basic-2001]rule 0 permit source any
[FW2-acl-ipv4-basic-2001]quit
[FW2]
[FW2]zone-pair security source trust destination untrust
[FW2-zone-pair-security-Trust-Untrust]packet-filter 2001
[FW2-zone-pair-security-Trust-Untrust]quit
[FW2]
[FW2]zone-pair security source untrust destination trust
[FW2-zone-pair-security-Untrust-Trust]packet-filter 2001
[FW2-zone-pair-security-Untrust-Trust]quit
[FW2]
[FW2]zone-pair security source trust destination local
[FW2-zone-pair-security-Trust-Local]packet-filter 2001
[FW2-zone-pair-security-Trust-Local]quit
[FW2]
[FW2]zone-pair security source local destination trust
[FW2-zone-pair-security-Local-Trust]packet-filter 2001
[FW2-zone-pair-security-Local-Trust]quit
[FW2]
[FW2]zone-pair security source untrust destination local
[FW2-zone-pair-security-Untrust-Local]packet-filter 2001
[FW2-zone-pair-security-Untrust-Local]quit
[FW2]
[FW2]zone-pair security source local destination untrust
[FW2-zone-pair-security-Local-Untrust]packet-filter 2001
[FW2-zone-pair-security-Local-Untrust]quit
FW2 IPSEC+IKE预共享密钥 关键配置点:
[FW2]acl advanced 3000
[FW2-acl-ipv4-adv-3000]rule 0 permit ip source 172.16.1.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[FW2-acl-ipv4-adv-3000]quit
[FW2]ike keychain james
[FW2-ike-keychain-james]pre-shared-key address 202.1.100.2 255.255.255.252 key simple james
[FW2-ike-keychain-james]quit
[FW2]ike proposal 1
[FW2-ike-proposal-1]quit
[FW2]ike profile james
[FW2-ike-profile-james]keychain james
[FW2-ike-profile-james]proposal 1
[FW2-ike-profile-james]match remote identity address 202.1.100.2 255.255.255.252
[FW2-ike-profile-james]quit
[FW2]ipsec transform-set james
[FW2-ipsec-transform-set-james]protocol esp
[FW2-ipsec-transform-set-james]encapsulation-mode tunnel
[FW2-ipsec-transform-set-james]esp authentication-algorithm md5
[FW2-ipsec-transform-set-james]esp encryption-algorithm des-cbc
[FW2-ipsec-transform-set-james]quit
[FW2]ipsec policy james 1 isakmp
[FW2-ipsec-policy-isakmp-james-1]security acl 3000
[FW2-ipsec-policy-isakmp-james-1]ike-profile james
[FW2-ipsec-policy-isakmp-james-1]transform-set james
[FW2-ipsec-policy-isakmp-james-1]remote-address 202.1.100.2
[FW2-ipsec-policy-isakmp-james-1]quit
[FW2]int gi 1/0/2
[FW2-GigabitEthernet1/0/2]ipsec apply policy james
测试:
物理机都填写IP地址:
PC之间可以相互PING通:
查看FW1的IPSEC显示信息:
查看FW2的IPSEC显示信息:
至此,F1060 IPSEC+IKE预共享密钥典型组网配置案例已完成!
以下是SSL VPN的配置案例:
组网及说明
组网说明:
本案例采用H3C HCL模拟器来模拟SSL VPN IP接入(缺省证书)单臂(直连)的组网。内网和外网均已在网络拓扑图中有了明确的说明。本案例使用F1060防火墙作为SSL_VPN网关,用于提供SSL VPN IP的接入,另外也是内网的出口设备。
特别说明:
1、由于模拟器的局限性,因此使用S5820交换机开启WEB功能模拟成为WEB服务器
2、需要自行在官网下载inode管理中心安装,并定制后生成inode客户端后再安装客户端
配置步骤
1、按照网络拓扑图正确配置IP地址
2、SW1开启WEB功能,并创建账户赋予权限
3、SSL_VPN开启NAT地址转换功能,并配置默认路由指向外网
4、SSL_VPN配置SSL VPN功能
配置关键点
1、第一阶段调试(基础网络配置)
SW1:
<H3C>sys
[H3C]sysname SW1
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-mode route
[SW1-GigabitEthernet1/0/1]des <connect to SSL_VPN>
[SW1-GigabitEthernet1/0/1]ip address 10.0.0.1 24
[SW1-GigabitEthernet1/0/1]quit
[SW1]ip route-static 0.0.0.0 0.0.0.0 10.0.0.2
[SW1]ip http enable
[SW1]ip https enable
[SW1]local-user admin
New local user added.
[SW1-luser-manage-admin]password simple admin
[SW1-luser-manage-admin]service-type http https
[SW1-luser-manage-admin]authorization-attribute user-role network-admin
[SW1-luser-manage-admin]quit
SSL_VPN:
<H3C>sys
[H3C]sysname SSL_VPN
[SSL_VPN]int gi 1/0/3
[SSL_VPN-GigabitEthernet1/0/3]des <connect to SW1>
[SSL_VPN-GigabitEthernet1/0/3]ip address 10.0.0.2 24
[SSL_VPN-GigabitEthernet1/0/3]quit
[SSL_VPN]acl basic 2000
[SSL_VPN-acl-ipv4-basic-2000]rule 0 permit source any
[SSL_VPN-acl-ipv4-basic-2000]quit
[SSL_VPN]int gi 1/0/2
[SSL_VPN-GigabitEthernet1/0/2]des <connect to WAN>
[SSL_VPN-GigabitEthernet1/0/2]ip address 192.168.200.200 24
[SSL_VPN-GigabitEthernet1/0/2]nat outbound 2000
[SSL_VPN-GigabitEthernet1/0/2]quit
[SSL_VPN]ip route-static 0.0.0.0 0.0.0.0 192.168.200.1
[SSL_VPN]security-zone name trust
[SSL_VPN-security-zone-Trust]import interface GigabitEthernet 1/0/3
[SSL_VPN-security-zone-Trust]quit
[SSL_VPN]security-zone name Untrust
[SSL_VPN-security-zone-Untrust]import interface GigabitEthernet 1/0/2
[SSL_VPN-security-zone-Untrust]quit
[SSL_VPN]acl basic 2001
[SSL_VPN-acl-ipv4-basic-2001]rule 0 permit source any
[SSL_VPN-acl-ipv4-basic-2001]quit
[SSL_VPN]
[SSL_VPN]zone-pair security source trust destination untrust
[SSL_VPN-zone-pair-security-Trust-Untrust]packet-filter 2001
[SSL_VPN-zone-pair-security-Trust-Untrust]quit
[SSL_VPN]
[SSL_VPN]zone-pair security source untrust destination trust
[SSL_VPN-zone-pair-security-Untrust-Trust]packet-filter 2001
[SSL_VPN-zone-pair-security-Untrust-Trust]quit
[SSL_VPN]
[SSL_VPN]zone-pair security source trust destination local
[SSL_VPN-zone-pair-security-Trust-Local]packet-filter 2001
[SSL_VPN-zone-pair-security-Trust-Local]quit
[SSL_VPN]
[SSL_VPN]zone-pair security source local destination trust
[SSL_VPN-zone-pair-security-Local-Trust]packet-filter 2001
[SSL_VPN-zone-pair-security-Local-Trust]quit
[SSL_VPN]
[SSL_VPN]zone-pair security source untrust destination local
[SSL_VPN-zone-pair-security-Untrust-Local]packet-filter 2001
[SSL_VPN-zone-pair-security-Untrust-Local]quit
[SSL_VPN]
[SSL_VPN]zone-pair security source local destination untrust
[SSL_VPN-zone-pair-security-Local-Untrust]packet-filter 2001
[SSL_VPN-zone-pair-security-Local-Untrust]quit
[SSL_VPN]
第一阶段测试:
外网终端填写IP地址
外网终端能PING通SSL_VPN的外网地址,PING不到私网地址
2、第二阶段调试(SSL VPN配置):
SSL VPN IP接入配置关键点:
SSL_VPN:
[SSL_VPN]acl advanced 3000
[SSL_VPN-acl-ipv4-adv-3000]rule 0 permit ip source any
[SSL_VPN-acl-ipv4-adv-3000]quit
[SSL_VPN]sslvpn ip address-pool weijianing 172.16.1.2 172.16.1.254
[SSL_VPN]int SSLVPN-AC 1
[SSL_VPN-SSLVPN-AC1]ip address 172.16.1.1 24
[SSL_VPN-SSLVPN-AC1]quit
[SSL_VPN]sslvpn gateway james
[SSL_VPN-sslvpn-gateway-james]ip address 192.168.200.200
[SSL_VPN-sslvpn-gateway-james]service enable
[SSL_VPN-sslvpn-gateway-james]quit
[SSL_VPN]sslvpn context james
[SSL_VPN-sslvpn-context-james]gateway james
[SSL_VPN-sslvpn-context-james]ip-tunnel address-pool weijianing mask 24
[SSL_VPN-sslvpn-context-james]ip-tunnel interface SSLVPN-AC 1
[SSL_VPN-sslvpn-context-james]ip-route-list james
[SSL_VPN-sslvpn-context-james-route-list-james]include 10.0.0.0 24
[SSL_VPN-sslvpn-context-james-route-list-james]quit
[SSL_VPN-sslvpn-context-james]policy-group ip
[SSL_VPN-sslvpn-context-james-policy-group-ip]filter ip-tunnel acl 3000
[SSL_VPN-sslvpn-context-james-policy-group-ip]ip-tunnel access-route ip-route-list james
[SSL_VPN-sslvpn-context-james-policy-group-ip]quit
[SSL_VPN-sslvpn-context-james]service enable
[SSL_VPN-sslvpn-context-james]quit
[SSL_VPN]local-user weijianing class network
[SSL_VPN-luser-network-weijianing]password simple weijianing
[SSL_VPN-luser-network-weijianing]service-type sslvpn
[SSL_VPN-luser-network-weijianing]authorization-attribute sslvpn-policy-group ip
[SSL_VPN-luser-network-weijianing]quit
[SSL_VPN-security-zone-Untrust]import interface SSLVPN-AC 1
第二阶段测试:
外网终端打开浏览器,输入网址:https://192.168.200.200
输入用户名、密码,点击“登陆”:
打开inode客户端:
输入网关、用户名、密码,点击“连接”:
SSL VPN建立连接成功
此时外网终端可以PING通内网WEB服务器
同时也可以打开WEB服务器网页:
SSL VPN信息显示:
至此,SSL VPN IP接入(缺省证书)单臂(直连)的典型组网配置案例已完成!
