H3C防火墙H3C SecPath F1000-S是否支持透明部署模式
2021-04-14提问
  • 1收藏,1076浏览
[H3C]display version
 H3C Comware Software Comware software, Version 3.40, Release 1623
 Copyright (c) 2004-2007 Hangzhou H3C Technologies Co., Ltd.
 All rights reserved.
 Without the owner's prior written consent, no decompiling nor reverse-engineering shall be allowed.
H3C SecPath F1000-S uptime is 0 week, 0 day, 0 hour, 41 minutes
该设备是否支持web登录以及透明模式部署
桥接进主干网络
粉丝:124人 关注:6人
H3C防火墙H3C SecPath F1000-S支持透明部署模式
以下是部署要点,请参考:
1、防火墙上创建VLAN,并将VLAN以trunk的方式在端口进行配置,并trunk相应的VLAN通过。
2、防火墙上涉及到的物理端口和vlan需加入安全域并放通安全策略或域间策略。
3、防火墙的物理端口默认在路由模式,需要切换为bridge才能进行trunk配置,以下是参考命令:
int gi 1/0/1
port link-mode bridge
没有这样的命令 [H3C-GigabitEthernet0/1]po [H3C-GigabitEthernet0/1]po [H3C-GigabitEthernet0/1]br [H3C-GigabitEthernet0/1]bridge ? vlanid-transparent-transmit Config vlanid transparent transmit [H3C-GigabitEthernet0/1]bridge-s [H3C-GigabitEthernet0/1]bridge-set ? INTEGER<1-255> Bridge set number for bridging fast-forwarding Enable fast-forwarding for the interface [H3C-GigabitEthernet0/1]bridge-set 1 [H3C-GigabitEthernet0/1]di sthis ^ % Unrecognized command found at '^' position. [H3C-GigabitEthernet0/1]br [H3C-GigabitEthernet0/1]bridge-s [H3C-GigabitEthernet0/1]bridge-set f [H3C-GigabitEthernet0/1]bridge-set fast-forwarding ? inbound Enable fast input on the interface outbound Enable fast output on the interface <cr> [H3C-GigabitEthernet0/1]bridge-set fast-forwarding in [H3C-GigabitEthernet0/1]bridge-set fast-forwarding inbound [H3C-GigabitEthernet0/1]interface GigabitEthernet 0/0 [H3C-GigabitEthernet0/0]interface GigabitEthernet 0/1 [H3C-GigabitEthernet0/1]undo bridge-set fast-forwarding inbound [H3C-GigabitEthernet0/1] [H3C-GigabitEthernet0/1] [H3C-GigabitEthernet0/1]interface GigabitEthernet 0/0 [H3C-GigabitEthernet0/0]bridge-set 1 [H3C-GigabitEthernet0/0]dis this # interface GigabitEthernet0/0 bridge-set 1 只可以这样
zhiliao_rlXmHy 发表时间:2021-04-14
粉丝:230人 关注:0人
您好,支持的
粉丝:94人 关注:0人
可以的,透明方式跟深信服有所不同,基于vlan来做的
[H3C]vlan 100 ^ % Unrecognized command found at '^' position. 没有这个命令
