MSR830 6EI WINET L2TP OVER IPSEC配置问题
2021-05-02提问
  • 1收藏,888浏览
粉丝:0人 关注:3人
设置列表
  • 有序列表
  • 无序列表
对齐方式
  • 靠左
  • 居中
  • 靠右
H3C MSR830 6EI WINET 配置如下,开通了L2TP OVER IPSEC VPN,但实际无论是手机还是win10 都无法访问,麻烦大神帮忙看下配置有没有问题,实在不懂...多谢
39.77.126.16为路由器拨号后获取的外部地址。
version 7.1.064, Release 0809P34
 sysname H3C
 clock timezone Beijing add 08:00:00
 clock protocol ntp
 ip pool l2tp1 192.168.10.2 192.168.10.255
 dialer-group 1 rule ip permit
 ip load-sharing mode per-flow src-ip global
 dhcp enable
 dhcp server always-broadcast
 dns proxy enable
 lldp global enable
 password-recovery enable
vlan 1
dhcp server ip-pool lan1
 gateway-list 192.168.1.1
 network 192.168.1.0 mask 255.255.255.0
 address range 192.168.1.3 192.168.1.254
 dns-list 192.168.1.1
ddns policy WAN0(GE0/0)
 url ***.***/nic/update?hostname=&myip=
 username carspar
 password cipher XXXX
interface Dialer0
 ppp chap password cipher XXXXXX
 ppp chap user 05XXXX
 ppp ipcp dns admit-any
 ppp ipcp dns request
 ppp pap local-user 05XXXX password cipher XXXXXX=
 dialer bundle enable
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
 nat outbound
 ddns apply policy WAN0(GE0/0) fqdn ***.***
interface Dialer1
interface Dialer2
interface Dialer3
interface Dialer4
interface Dialer5
interface Dialer6
interface Dialer7
interface Dialer8
interface Dialer1023
interface Virtual-Template0
interface Virtual-Template1
 ppp authentication-mode chap domain system
 remote address pool l2tp1
 ip address 192.168.10.1 255.255.255.0
interface NULL0
interface Vlan-interface1
 tcp mss 1280
interface GigabitEthernet0/0
 port link-mode route
 description Single_Line1
 pppoe-client dial-bundle-number 0
 ipsec apply policy 1
interface GigabitEthernet0/1
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
security-zone name Local
security-zone name Trust
security-zone name DMZ
security-zone name Untrust
security-zone name Management
 scheduler logfile size 16
line class console
 user-role network-admin
line class tty
 user-role network-operator
line class vty
line con 0
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 Dialer0
 info-center format unicom
 info-center loghost oasislog.h3c.com
 info-center source default loghost level debugging
 ntp-service enable
 ntp-service unicast-server ***.***
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control update-interval 0
 password-control login idle-time 0
domain system
 authentication ppp local
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 service-type telnet http
local-user carspar class network
 password cipher $c$3$W3PEA3m5v0wdJGVsHV60IKchSQas6LbwcZAo+g==
 service-type ppp
ipsec transform-set 1
 encapsulation-mode transport
 esp encryption-algorithm aes-cbc-128
 esp authentication-algorithm sha1
ipsec transform-set 2
 esp encryption-algorithm aes-cbc-256
ipsec transform-set 3
 esp encryption-algorithm 3des-cbc
ipsec transform-set 4
 esp encryption-algorithm des-cbc
ipsec transform-set 5
 esp encryption-algorithm aes-cbc-192
ipsec transform-set 6
ipsec policy-template 1 1
 transform-set 1 2 3 4 5 6
 ike-profile 1
ipsec policy 1 1 isakmp template 1
l2tp-group 1 mode lns
 allow l2tp virtual-template 1
 undo tunnel authentication
ike profile 1
 keychain 1
 exchange-mode aggressive
 local-identity address 39.77.126.16
 match remote identity address 0.0.0.0 0.0.0.0
 proposal 1 2 3 4 5 6
ike proposal 1
 dh group2
 authentication-algorithm md5
ike proposal 2
 dh group2
ike proposal 3
 dh group2
ike proposal 4
 dh group2
ike proposal 5
 dh group2
ike proposal 6
 dh group2
ike keychain 1
 pre-shared-key address 0.0.0.0 0.0.0.0 key cipher $c$3$K1qJSp4UPhZ7MuGnGphkoc0oCDHY443SeUzaYg==
 ip http enable
wlan global-configuration
 nas-id cm-0-1390588-219801A13FM18600008X
wlan ap-group default-group
 vlan 1
 cloud-management server domain oasis.h3c.com
return
粉丝:11人 关注:21人
看配置L2TP没什么问题,无法访问是拨不上号吗,还是拨号后无法访问内网。
1、把ipsec策略应用到拨号口,物理口的undo
可参考如下案例:
https://zhiliao.h3c.com/Theme/details/77438
https://zhiliao.h3c.com/Theme/details/71091
手机ios拨号显示VPN LT2P服务器未响应,请重试连接...ipsec apply policy也已经做过了...,不知还可能是什么原因呢,多谢!
carspar 发表时间:2021-05-03
百度下终端L2TP拨号设置,先用windows系统试试
二仙桥大爷 发表时间:2021-05-03
hi 搞了多次还是没有搞定,今天也闲鱼找了个人,他也没有搞定,不知可否帮忙解决一下?多谢了!我的联系方式我私信您,非常感谢!
carspar 发表时间:2021-05-16
粉丝:19人 关注:3人
你好,可以参考一下如下案例:
https://zhiliao.h3c.com/Theme/details/4174
粉丝:124人 关注:6人
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display ike proposal
6、display ipsec transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
L2TP VPN故障排查:
1、检查路由是否可达。
2、检查LNS内是否创建了用户名、密码,并赋予了服务权限。
3、检查LNS内是否创建了地址池。
4、检查LNS内是否创建了VT并调用了地址池。
5、检查LNS内是否创建了L2TP组,并调用了VT。
