H3C三层交换怎么中继连接windows dhcp服务器
(0)
以下是部署DHCP中继的要点,请参考:
1、首先需要确保DHCP服务器的路由可达。
2、其次在交换机上开启DHCP功能,并配置好VLAN IP作为网关,且将VLAN划分到端口。
3、接着在交换机上配置DHCP中继的指向,并指向到DHCP服务器。
4、以下是配参考命令,请参考:
[SWA]dhcp enable
[SWA] interface vlan-interface 5
[SWA -Vlan-interface5] dhcp select relay
[SWA -Vlan-interface5] dhcp relay server-address 192.168.7.100
# 配置VLAN接口6工作在DHCP中继模式。
[SWA] interface vlan-interface 6
[SWA -Vlan-interface6] dhcp select relay
# 配置DHCP服务器的地址。
[SWA -Vlan-interface6] dhcp relay server-address 192.168.7.100
#保存配置
[SWA]save force
(1)
你好 案例https://zhiliao.h3c.com/Theme/details/46422
1)SWB 创建VLAN、相关接口配置为access口和trunk
# 创建VLAN5、6,并将G1/0/2 、G1/0/3口分别加入VLAN5、VLAN6。
<SWB>system-view
[SWB]vlan 5
[SWB-vlan5]port GigabitEthernet 1/0/2
[SWB-vlan5]quit
[SWB]vlan 6
[SWB-vlan6]port GigabitEthernet 1/0/3
[SWB-vlan6]quit
# 将G1/0/1口配置为trunk口,并放通VLAN通过
[SWB]interface GigabitEthernet 1/0/1
[SWB-GigabitEthernet1/0/1]port link-type trunk
[SWB-GigabitEthernet1/0/1]port trunk permit vlan all
[SWB-GigabitEthernet1/0/1]quit
[SWB]save force
2)SWA创建VLAN、相关VLAN接口、地址。
#创建VLAN5、6、7,将G1/0/2加入VLAN7
[SWA]vlan 5 to 7
Please wait... Done.
[SWA]interface GigabitEthernet 1/0/2
[SWA-GigabitEthernet1/0/2]port access vlan 7
[SWA-GigabitEthernet1/0/2]quit
[SWA]interface GigabitEthernet 1/0/1
[SWA-GigabitEthernet1/0/1]port link-type trunk
[SWA-GigabitEthernet1/0/1]port trunk permit vlan all
[SWA-GigabitEthernet1/0/1]quit
# 配置各个VLAN接口地址
[SWA]interface vlan-interface 5
[SWA-Vlan-interface5]ip address 192.168.5.1 255.255.255.0
[SWA-Vlan-interface5]quit
[SWA]interface vlan-interface 6
[SWA-Vlan-interface6]ip address 192.168.6.1 255.255.255.0
[SWA-Vlan-interface6]quit
[SWA]interface vlan-interface 7
[SWA-Vlan-interface7]ip address 192.168.7.1 255.255.255.0
[SWA-Vlan-interface7]quit
3)DHCP 服务器配置地址分配功能,同时网卡配置192.168.7.100/255.255.255.0地址,网关指向192.168.7.1。确认DHCP 服务器能ping通192.168.5.1 192.168.6.1。此处省略DHCP服务器配置。
4)SWA配置DHCP中继。
[SWA]dhcp enable
# 配置DHCP服务器的地址。
#保存配置
[SWA]save force
配置完成后,DHCP客户端可以通过DHCP中继从DHCP服务器获取IP地址及相关配置信息。通过display dhcp relay statistics命令可以显示DHCP中继转发的DHCP报文统计信息。
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
