ap的配置如何用命令恢复出厂设置
2021-05-07提问
  • 1收藏,3866浏览
Weng 四段
请问大家,ap怎么用命令恢复出厂设置,我记得有一条命令可以恢复预配置,但是给忘了
粉丝:47人 关注:4人
reset saved-configuration
粉丝:124人 关注:6人
以下是恢复出厂设置的方法,请参考:
方法一:
<H3C>reset saved-configuration   //清空配置
The saved configuration file will be erased. Are you sure? [Y/N]:y   //设备提示保存的配置将会被删除,是否继续。
Configuration file in flash: is being cleared. Please wait ...
MainBoard:
 Configuration file is cleared.   //配置已被清空
<H3C>reboot   //重启交换机
 Current configuration may be lost after the reboot, save current configuration? [Y/N]:n   //设备提示会在重启后丢失当前配置,是否保存当前配置,选择n
This command will reboot the device. Continue? [Y/N]:y   //设备提示设备将会重启,是否继续,选择Y
Now rebooting, please wait...
%Dec 14 20:48:39:352 2019 SW1 DEV/5/SYSTEM_REBOOT: System is rebooting now.
方法二:
<H3C>dir  //通过dir命令查看文件
Directory of flash:
   0 drw-           - Dec 14 2019 20:37:24   diagfile
   1 -rw-        1554 Dec 14 2019 20:50:06   ifindex.dat
   2 -rw-       21632 Dec 14 2019 20:37:24   licbackup
   3 drw-           - Dec 14 2019 20:37:24   license
   4 -rw-       21632 Dec 14 2019 20:37:24   licnormal
   5 drw-           - Dec 14 2019 20:48:38   logfile
   6 -rw-           0 Dec 14 2019 20:37:24   s5820v2_5830v2-cmw710-boot-a7514.bin
   7 -rw-           0 Dec 14 2019 20:37:24   s5820v2_5830v2-cmw710-system-a7514.bin
   8 drw-           - Dec 14 2019 20:37:24   seclog
   9 -rw-        6118 Dec 14 2019 20:50:06   startup.cfg  //这个是启动配置,我们要删除此文件
  10 -rw-      110464 Dec 14 2019 20:50:06   startup.mdb
1046512 KB total (1046300 KB free)
<H3C>delete startup.cfg   //使用删除命令删除startup.cfg这个启动运行的配置文件
Delete flash:/startup.cfg? [Y/N]:y   //设备提示是否要删除,选择Y
Deleting file flash:/startup.cfg... Done.   //设备提示startup.cfg这个文件已删除完成
<H3C>reboot   //重启
粉丝:11人 关注:0人
瘦ap默认就是空配置的,胖ap恢复出厂配置直接reset save
粉丝:11人 关注:21人
<H3C> restore factory-default         //恢复出厂设置
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y         //选择y,确认恢复出厂设置
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
Configuration file does not exist!
<H3C>reboot                         //重启设备
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:n                 //提示是否保存配置,选择n
 This command will reboot the device. Continue? [Y/N]:y     //提示继续重启设备,选择y
#Jan  1 00:23:20:782 2013 H3C DEVM/1/REBOOT:
 Reboot device by command.
%Jan  1 00:23:20:782 2013 H3C DEVM/5/SYSTEM_REBOOT: System is rebooting now.
<H3C>
