SAS Controllers
HPE Smart Array Controllers
HP Smart Array P440/2GB FBWC 12Gb 1-port Int SAS Controller
820834-B21
HP Smart Array P440/4GB FBWC 12Gb 1-port Int SAS Controller
726821-B21
HP Smart Array P441/4GB FBWC 12Gb 2-ports Ext SAS Controller
726825-B21
HP Smart Array P840/4GB FBWC 12Gb 2-ports Int SAS Controller
NOTE: 16SFF is limited to P840.
726897-B21
HP Smart Array P841/4GB FBWC 12Gb 4-ports Ext SAS Controller
726903-B21
HP Smart Array P440/4GB FBWC 12Gb 1-port Int FIO SAS Controller
NOTE: Smart Storage Battery included.
NOTE:?Must select battery holder P/N: 786710-B21 when?purchasing the?P440.
NOTE: B140i can't mix with any standup internal controller.
NOTE: HPE ML150 Gen9 Mini SAS P440/P840 Cable Kit must be selected P/N: 784606-B21 for P440 controller (1 cable kit is required for P440x1).
NOTE: HPE ML150 Gen9 PCI BAFFLE Kit (779861-B21) is required when?ordering the?H240 controller card.
761872-B21
HP Smart Array P840/4GB FBWC 12Gb 2-ports Int FIO SAS Controller
NOTE:?B140i can't mix with any standup internal controller.
NOTE: Must select the?P840/4G FIO Controller when an additional drive cage is selected.?
NOTE: Must select P840/4G Controller when apply 16SFF.
NOTE:?Must select battery holder when?purchase P440 P/N: 786710-B21.
NOTE: HPE ML150 Gen9Mini SAS P440/P840 Cable Kit must be selected P/N: 784606-B21 for P840 controller (2 cable kits are required for P840x1).
NOTE:?HPE ML150 Gen9 PCI BAFFLE Kit (779861-B21) is required when ordering?a?controller card.
761874-B21
SAS Controller Options
HP 96W Smart Storage Battery with 145mm Cable for DL/ML/SL Servers
727258-B21
HPE Host Bus Adapter
HP H240 12Gb 2-ports Int Smart Host Bus Adapter
726907-B21
HP H241 12Gb 2-ports Ext Smart Host Bus Adapter
726911-B21
HP H240 12Gb 2-ports Int FIO Smart Host Bus Adapter
NOTE: Must select for H240 controller when selecting a?Tape Drive.
NOTE: Cable Rule:
1 cable kit is required for Hot Plug 4LFF.
2 cable kits are required for below:
- Hot Plug 4+4 LFF (with additional drive cage)
- 8SFF
761873-B21
NOTE: If H240 is the primary controller and if HPE Mfg FIO Enable HBA Mode Setting is selected, then RAID is not allowed.
NOTE: HPE ML150 Gen9 PCI BAFFLE Kit (779861-B21)?is required when ordering a?controller card.
HPE Cable Options
HP ML150 Gen9 Mini SAS H240 Cable Kit
784606-B21
HP ML150 Gen9 Mini SAS P440/P840 Cable Kit
784608-B21
您好 想问问 添加那个型号的卡?
SAS Controllers HPE Smart Array Controllers HP Smart Array P440/2GB FBWC 12Gb 1-port Int SAS Controller 820834-B21 HP Smart Array P440/4GB FBWC 12Gb 1-port Int SAS Controller 726821-B21 HP Smart Array P441/4GB FBWC 12Gb 2-ports Ext SAS Controller 726825-B21 HP Smart Array P840/4GB FBWC 12Gb 2-ports Int SAS Controller NOTE: 16SFF is limited to P840. 726897-B21 HP Smart Array P841/4GB FBWC 12Gb 4-ports Ext SAS Controller 726903-B21 HP Smart Array P440/4GB FBWC 12Gb 1-port Int FIO SAS Controller NOTE: Smart Storage Battery included. NOTE:?Must select battery holder P/N: 786710-B21 when?purchasing the?P440. NOTE: B140i can't mix with any standup internal controller. NOTE: HPE ML150 Gen9 Mini SAS P440/P840 Cable Kit must be selected P/N: 784606-B21 for P440 controller (1 cable kit is required for P440x1). NOTE: HPE ML150 Gen9 PCI BAFFLE Kit (779861-B21) is required when?ordering the?H240 controller card. 761872-B21 HP Smart Array P840/4GB FBWC 12Gb 2-ports Int FIO SAS Controller NOTE: Smart Storage Battery included. NOTE:?B140i can't mix with any standup internal controller. NOTE: Must select the?P840/4G FIO Controller when an additional drive cage is selected.? NOTE: Must select P840/4G Controller when apply 16SFF. NOTE:?Must select battery holder when?purchase P440 P/N: 786710-B21. NOTE: HPE ML150 Gen9Mini SAS P440/P840 Cable Kit must be selected P/N: 784606-B21 for P840 controller (2 cable kits are required for P840x1). NOTE:?HPE ML150 Gen9 PCI BAFFLE Kit (779861-B21) is required when ordering?a?controller card. 761874-B21 SAS Controller Options HP 96W Smart Storage Battery with 145mm Cable for DL/ML/SL Servers 727258-B21 HPE Host Bus Adapter HP H240 12Gb 2-ports Int Smart Host Bus Adapter 726907-B21 HP H241 12Gb 2-ports Ext Smart Host Bus Adapter 726911-B21 HP H240 12Gb 2-ports Int FIO Smart Host Bus Adapter NOTE: Must select for H240 controller when selecting a?Tape Drive. NOTE: Cable Rule: 1 cable kit is required for Hot Plug 4LFF. 2 cable kits are required for below: - Hot Plug 4+4 LFF (with additional drive cage) - 8SFF 761873-B21 NOTE: If H240 is the primary controller and if HPE Mfg FIO Enable HBA Mode Setting is selected, then RAID is not allowed. NOTE: B140i can't mix with any standup internal controller. NOTE: HPE ML150 Gen9 PCI BAFFLE Kit (779861-B21)?is required when ordering a?controller card. HPE Cable Options HP ML150 Gen9 Mini SAS H240 Cable Kit 784606-B21 HP ML150 Gen9 Mini SAS P440/P840 Cable Kit 784608-B21
感谢
关键这个东西 从哪里可以购买呢
联系HPE销售
