H3C 交换机组网 mstp问题
2021-05-09提问
  • 1收藏,1496浏览
交换机收集的信息
Port21(GigabitEthernet1/0/21) received MSTP-dot1s Packet(Length: 102)
ProtocolVersionID: 03
BPDUType : 02
CIST Root ID : 61440.9c06-1b01-27f5
External RPC : 0
Reg Root ID : 61440.9c06-1b01-27f5
Internal RPC : 0
CIST Bridge ID : 61440.9c06-1b01-27f5
CIST Port ID : 128.12
(Instance)Flags : (00)Desi[ FL ]
*May 8 17:40:24:419 2021 XXXXXXX STP/7/FSMSTATE: Instance 0's port21(GigabitEthernet1/0/21) enters PPM%SENSING state.
*May 8 17:40:24:419 2021 XXXXXXX STP/7/FSMSTATE: Instance 0's port21(GigabitEthernet1/0/21) enters PIM%CURRENT state.
 *May 8 17:40:24:419 2021 XXXXXXX STP/7/FSMSTATE: Instance 0's port21(GigabitEthernet1/0/21) enters PIM%RECEIVE state.
*May 8 17:40:24:419 2021 XXXXXXX STP/7/FSMSTATE: Instance 0's port21(GigabitEthernet1/0/21) enters PIM%INFERIOR_DESIGNATED state.
*May 8 17:40:24:523 2021 XXXXXXX STP/7/FSMSTATE: Instance 0's port21(GigabitEthernet1/0/21) enters PTX%PERIODIC state.
*May 8 17:40:24:523 2021 XXXXXXX STP/7/FSMSTATE: Instance 0's port21(GigabitEthernet1/0/21) enters PTX%MSTP_DOT1S state.
*May 8 17:40:24:524 2021 XXXXXXX STP/7/PKT:
 Port21(GigabitEthernet1/0/21) sent MSTP-dot1s Packet(Length: 102)
BPDUType : 02
CIST Root ID : 32768.b0f9-632e-60b9
External RPC : 20
 Reg Root ID : 32768.b0f9-632e-8909
Internal RPC : 0
 CIST Bridge ID : 32768.b0f9-632e-8909
 CIST Port ID : 128.21
 (Instance)Flags : (00)Desi[ P ]
----[Port21(GigabitEthernet1/0/21)][DISCARDING]----
 Port protocol : Enabled
 Port role : Designated Port (Boundary)
 Port ID : 128.21
 Port cost(Legacy) : COnfig=auto, Active=200
 Desg.bridge/port : 32768.b0f9-632e-8909, 128.21
 Port edged : COnfig=disabled, Active=disabled
 Point-to-Point : COnfig=auto, Active=true
 Transmit limit : 10 packets/hello-time
 TC-Restriction : Disabled
 Role-Restriction : Disabled
 Protection type : NONE
 MST BPDU format : COnfig=auto, Active=802.1s
 Port Config-
 Digest-Snooping : Disabled
 Rapid transition : False
 Num of VLANs mapped : 1
 Port times : Hello 2s MaxAge 20s FwdDelay 15s MsgAge 1s RemHops 20
 BPDU sent : 229
          TCN: 0, Config: 0, RST: 0, MST: 229
 BPDU received : 229
俩交换机通过运营商专线直连
能帮分析下上面的信息,及产生的原因吗?
俩交换机通过运营商专线直连
现在怎么了?
????刷答案的?
zhiliao_2iD0Ik 发表时间:2021-05-09
粉丝:22人 关注:11人
就是些状态机变化,debug stp了?一般不debug这玩意儿
不是啊,有端口discard了啊
粉丝:124人 关注:6人
是部署了MSTP后而业务不通么?
如果是,以下是排查要点,请参考:
1、dis stp root检查根桥是否稳定。
2、dis stp tc检查端口收发TC报文是否频繁增长。
3、检查是否有可能存在环路。
4、检查是否有些端口因为STP的计算和收敛被堵塞掉了。
确实是有端口处于discard了上面的信息已经贴出来了,21口处于堵塞
