Linux+Oracle 安装iMC提示数据库连接失败该如何解决呢?
2021-05-12提问
  • 1收藏,860浏览
游鱼 四段
粉丝:0人 关注:2人
试过修改sys的密码,环境变量也没问题
2021-05-12 21:02:59 [INFO ] [SwingWorker-pool-2-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2381)] className:oracle.jdbc.driver.OracleDriver 2021-05-12 21:02:59 [INFO ] [SwingWorker-pool-2-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2384)] URL: jdbc:oracle:oci:@IMCDB 2021-05-12 21:02:59 [INFO ] [SwingWorker-pool-2-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2388)] password = {PROTECTED} 2021-05-12 21:02:59 [INFO ] [SwingWorker-pool-2-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2390)] user = sys 2021-05-12 21:02:59 [INFO ] [SwingWorker-pool-2-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2390)] internal_logon = sysdba 2021-05-12 21:02:59 [ERROR] [SwingWorker-pool-2-thread-2] [com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog::doWork(2448)] Connect to database error java.sql.SQLException: ORA-12154: TNS: 无法解析指定的连接标识符 at oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:1159) ~[ojdbc8.jar:18.3.0.0.0] at oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:1062) ~[ojdbc8.jar:18.3.0.0.0] at oracle.jdbc.driver.T2CConnection.logon(T2CConnection.java:729) ~[ojdbc8.jar:18.3.0.0.0] at oracle.jdbc.driver.PhysicalConnection.connect(PhysicalConnection.java:782) ~[ojdbc8.jar:18.3.0.0.0] at oracle.jdbc.driver.T2CDriverExtension.getConnection(T2CDriverExtension.java:60) ~[ojdbc8.jar:18.3.0.0.0] at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:704) ~[ojdbc8.jar:18.3.0.0.0] at java.sql.DriverManager.getConnection(DriverManager.java:677) ~[java.sql:?] at java.sql.DriverManager.getConnection(DriverManager.java:189) ~[java.sql:?] at com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog.doWork(DatabaseSelectPanelDescriptor.java:2394) [deploy.jar:?] at com.h3c.imc.deploy.dma.wizard.DatabaseSelectPanelDescriptor$DbConnectCheckingWorkingDialog.doWork(DatabaseSelectPanelDescriptor.java:2096) [deploy.jar:?] at com.h3c.imc.deploy.wizard.WorkingDialog$ProgressWorker.doInBackground(WorkingDialog.java:282) [deploy.jar:?] at javax.swing.SwingWorker$1.call(SwingWorker.java:304) [?:?] at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] at javax.swing.SwingWorker.run(SwingWorker.java:343) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?] at java.lang.Thread.run(Thread.java:834) [?:?]
paner 九段
粉丝:33人 关注:3人
看下现场的报错截图对照下是如下这个案例里的情况么,是的话可以对应查一下:https://zhiliao.h3c.com/theme/details/124042
多谢~但是好像不是一个问题o(╥﹏╥)o
游鱼 发表时间:2021-05-12
