MSR30-60 修改号码后,被叫失败
2018-06-04提问
  • 1收藏,1849浏览
undo entity 8105
line 9/4
entity 8122 pots
description 8122
match-template 8122
使用如上命令,修改了9/4的端口电话号码。修改后。话机能正常呼出,不能呼入。内线,外线呼入都不行。
设备配置如下。
<JXMWR_JXSSBS_MSR3060>dis cu
 version 5.20, Release 2207P02, Standard
 sysname JXMWR_JXSSBS_MSR3060
 domain default enable system
 router id 10.36.251.254
 telnet server enable
 dar p2p signature-file cfa0:/p2p_default.mtd
 port-security enable
vlan 1
vlan 100 to 101
vlan 103
radius scheme system
 primary authentication 127.0.0.1 1645
 primary accounting 127.0.0.1 1646
 user-name-format without-domain
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password simple sbs
 authorization-attribute level 3
 service-type telnet
 service-type web
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
interface Serial4/0
 link-protocol ppp
 ip address 10.36.253.74 255.255.255.252
 ospf network-type p2p
interface Virtual-Ethernet103
interface NULL0
interface Vlan-interface103
interface GigabitEthernet0/0
 port link-mode route
 ip address 10.36.251.238 255.255.255.240
interface GigabitEthernet0/1
 ip address 10.36.251.254 255.255.255.240
ospf 1
 import-route static
 area 0.0.0.0
  network 10.36.251.0 0.0.0.127
  network 10.36.253.72 0.0.0.3
  network 10.36.251.240 0.0.0.15
  network 10.36.251.224 0.0.0.15
voice-setup
 sip
  registrar ipv4 10.36.240.226 port 1719
  register-enable on
 sip-server
  call-rule-set
  call-route
 dial-program
  terminator #
  entity 1 voip
   address sip proxy
   description Created by WEB Guide
   match-template .T
  entity 110 voip
   address ras
   fast-connect
   match-template [1-8]...
  entity 120 voip
   address ras
   fast-connect
   match-template 9[1-2]......
  entity 130 voip
   address ras
   fast-connect
   match-template 9[3-9].......
  entity 140 voip
   address ras
   fast-connect
   match-template 927......
  entity 150 voip
   address ip 10.36.251.228
   fast-connect
   caller-permit 80..$
   caller-permit 81..$
   caller-permit 88..$
   match-template 0.T
   outband h225
  entity 8101 pots
   line 9/0
   description 8100
   match-template 8100
  entity 8102 pots
   line 9/1
   description 8102
   match-template 8102
  entity 8103 pots
   line 9/2
   description 8103
   match-template 8103
  entity 8104 pots
   line 9/3
   description 8104
   match-template 8104
  entity 8105 pots
   line 9/4
   description 8122
   match-template 8122
  entity 8106 pots
   line 9/5
   description 8106
   match-template 8106
  entity 8107 pots
   line 9/6
   description 8107
   match-template 8107
  entity 8108 pots
   line 9/7
   description 8108
   match-template 8108
  entity 8109 pots
   line 9/8
   description 8109
   match-template 8109
  entity 8110 pots
   line 9/9
   description 8169
   match-template 8169
  entity 8111 pots
   line 9/10
   description 8111
   match-template 8111
  entity 8112 pots
   line 9/11
   description 8112
   match-template 8112
  entity 8113 pots
   line 9/12
   description 8113
   match-template 8113
  entity 8114 pots
   line 9/13
   description 8114
   match-template 8114
  entity 8115 pots
   line 9/14
   description 8115
   match-template 8115
  entity 8116 pots
   line 9/15
   description 8116
   match-template 8190
  entity 8117 pots
   line 10/0
   description 8117
   match-template 8117
  entity 8118 pots
   line 10/1
   description 8118
   match-template 8118
  entity 8119 pots
   line 10/2
   description 8119
   match-template 8119
  entity 8120 pots
   line 10/3
   description 8136
   match-template 8136
  entity 8121 pots
   line 10/4
   description 8121
   match-template 8121
  entity 8122 pots
   line 10/5
   description 8122
   match-template 8122
  entity 8123 pots
   line 10/6
   description 8123
   match-template 8123
  entity 8124 pots
   line 10/7
   description 8110
   match-template 8110
  entity 8125 pots
   line 10/8
   description 8125
   match-template 8125
  entity 8126 pots
   line 10/9
   description 8126
   match-template 8126
  entity 8127 pots
   line 10/10
   description 8127
   match-template 8127
  entity 8128 pots
   line 10/11
   match-template 8160
  entity 8129 pots
   line 10/12
   description 8129
   match-template 8129
  entity 8131 pots
   line 10/14
   description 8131
   match-template 8131
  entity 8132 pots
   line 10/15
   description 8132
   match-template 8132
  entity 8141 pots
   line 10/13
   description 8141
   match-template 8141
 aaa-client
 gk-client
  gk-id ST_GK gk-addr 10.36.240.226 1719
  gw-address 10.36.251.238
  gw-id S-SBS-MSR3060-GW
  ras-on
subscriber-line9/0
subscriber-line9/1
subscriber-line9/2
subscriber-line9/3
subscriber-line9/4
subscriber-line9/5
subscriber-line9/6
subscriber-line9/7
subscriber-line9/8
subscriber-line9/9
subscriber-line9/10
subscriber-line9/11
subscriber-line9/12
subscriber-line9/13
subscriber-line9/14
subscriber-line9/15
subscriber-line10/0
subscriber-line10/1
subscriber-line10/2
subscriber-line10/3
subscriber-line10/4
subscriber-line10/5
subscriber-line10/6
subscriber-line10/7
subscriber-line10/8
subscriber-line10/9
subscriber-line10/10
subscriber-line10/11
subscriber-line10/12
subscriber-line10/13
subscriber-line10/14
subscriber-line10/15
 ip route-static 10.36.251.0 255.255.255.128 10.36.251.252
 ip route-static 10.36.251.128 255.255.255.192 10.36.251.252
 ip route-static 192.168.201.0 255.255.255.0 10.36.251.252
 ip route-static 192.168.202.0 255.255.255.0 10.36.251.252
 snmp-agent
 snmp-agent local-engineid 000007DB7F00000100003949
 snmp-agent community read jxsl
 snmp-agent community write jxsl2
 snmp-agent sys-info version all
 undo snmp-agent trap enable voice dial
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface tty 13
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
实体8105和实体8122的match-template都是8122,收到呼叫就不知道给谁了,冲突了,删除一个没用的
粉丝:7人 关注:3人
看不懂。。等大神解答
给你一个双击,给你一个关注
zhiliao_20062 发表时间:2018-06-04
