MSR30-60
2018-06-04提问
  • 1收藏,1594浏览
8122这个号码被叫不通,主叫无问题。
 entity 1 voip
   address sip proxy
   description Created by WEB Guide
   match-template .T
  entity 110 voip
   address ras
   fast-connect
   match-template [1-8]...
  entity 120 voip
   address ras
   fast-connect
   match-template 9[1-2]......
  entity 130 voip
   address ras
   fast-connect
   match-template 9[3-9].......
  entity 140 voip
   address ras
   fast-connect
   match-template 927......
  entity 150 voip
   address ip 10.36.251.228
   fast-connect
   caller-permit 80..$
   caller-permit 81..$
   caller-permit 88..$
   match-template 0.T
   outband h225
  entity 8101 pots
   line 9/0
   description 8100
   match-template 8100
  entity 8102 pots
   line 9/1
   description 8102
   match-template 8102
  entity 8103 pots
   line 9/2
   description 8103
   match-template 8103
  entity 8104 pots
   line 9/3
   description 8104
   match-template 8104
  entity 8106 pots
   line 9/5
   description 8106
   match-template 8106
  entity 8107 pots
   line 9/6
   description 8107
   match-template 8107
  entity 8108 pots
   line 9/7
   description 8108
   match-template 8108
  entity 8109 pots
   line 9/8
   description 8109
   match-template 8109
  entity 8110 pots
   line 9/9
   description 8169
   match-template 8169
  entity 8111 pots
   line 9/10
   description 8111
   match-template 8111
  entity 8112 pots
   line 9/11
   description 8112
   match-template 8112
  entity 8113 pots
   line 9/12
   description 8113
   match-template 8113
  entity 8114 pots
   line 9/13
   description 8114
   match-template 8114
  entity 8115 pots
   line 9/14
   description 8115
   match-template 8115
  entity 8116 pots
   line 9/15
   description 8116
   match-template 8190
  entity 8117 pots
   line 10/0
   description 8117
   match-template 8117
  entity 8118 pots
   line 10/1
   description 8118
   match-template 8118
  entity 8119 pots
   line 10/2
   description 8119
   match-template 8119
  entity 8120 pots
   line 10/3
   description 8136
   match-template 8136
  entity 8121 pots
   line 10/4
   description 8121
   match-template 8121
  entity 8122 pots
   line 10/5
   description 8122
   match-template 8122
  entity 8123 pots
   line 10/6
   description 8123
   match-template 8123
  entity 8124 pots
   line 10/7
   description 8110
   match-template 8110
  entity 8125 pots
   line 10/8
   description 8125
   match-template 8125
  entity 8126 pots
   line 10/9
   description 8126
   match-template 8126
  entity 8127 pots
   line 10/10
   description 8127
   match-template 8127
  entity 8128 pots
   line 10/11
   match-template 8160
  entity 8129 pots
   line 10/12
   description 8129
   match-template 8129
  entity 8131 pots
   line 10/14
   description 8131
   match-template 8131
  entity 8132 pots
   line 10/15
   description 8132
   match-template 8132
  entity 8141 pots
   line 10/13
   description 8141
   match-template 8141
return
看样子应该是号码没在服务器上注册,重新开启一下注册,让号码到服务器上注册下
jlubao 五段
粉丝:5人 关注:3人
其他电话有问题吗?
没有问题。我吧8122删除过一次。然后重新配置了一次,就没被叫了。
zhiliao_20062 发表时间:2018-06-04
