H3C ICG3000F-DP 接入 WA5320-C-EI AP 后找不到设备
  • 1收藏,1489浏览
在Web 配置的 【无线AC】配置中(/wnm/wframe/index.php),设备一栏里面明确写着支持 WA5320-C-EI,但是 AP 通过网线直接插到网关GE1口上,网关配置界面里面却找不到任何 AP,但是 DHCP 分配列表里面给 AP分配了 IPv4 地址,而且通过IP也可以正常Telnet登录AP。
如果把电脑插入GE1,可以正常获得IP地址,上网(GE3接的光猫)也正常。ICG3000F-DP 是 R0821P11 最新固件。
网关配置界面里面却找不到任何 AP,不知道什么原因。
  1. dhcp server ip-pool ge0
  2. gateway-list 10.28.0.1
  3. network 10.28.0.0 mask 255.255.255.0
  4. address range 10.28.0.101 10.28.0.200
  5. dns-list 10.28.0.1
  6. forbidden-ip-range 10.28.0.1 10.28.0.1
  7. static-bind ip-address 10.28.0.11 mask 255.255.255.0 hardware-address 085b-d6f4-8076 description ShenLiyang
  8. #
  9. dhcp server ip-pool ge1
  10. gateway-list 10.28.1.1
  11. network 10.28.1.0 mask 255.255.255.0
  12. address range 10.28.1.101 10.28.1.200
  13. dns-list 10.28.1.1
  14. forbidden-ip-range 10.28.1.1 10.28.1.1
  15. #
  16. ipv6 dhcp pool ge0ipv6
  17. option-group 1
  18. #
  19. controller Cellular0/0
  20. #
  21. interface Dialer3
  22. mtu 1492
  23. ppp chap password cipher $c$3$vGSdC5n8D1UDzqQNjCfKsdO3pSAgQ/48Aw==
  24. ppp chap user SL10012046@E
  25. ppp ipcp dns admit-any
  26. ppp ipcp dns request
  27. ppp pap local-user SL10012046@E password cipher $c$3$Rz99HEepvjJX4eNVVbYVTGAa/ZEkzzBBfg==
  28. dialer bundle enable
  29. dialer-group 4
  30. dialer timer idle 0
  31. dialer timer autodial 5
  32. ip address ppp-negotiate
  33. tcp mss 1280
  34. nat outbound
  35. ipv6 address auto link-local
  36. ipv6 address dhcp-alloc
  37. ipv6 dhcp client pd 1 rapid-commit option-group 1
  38. #
  39. interface NULL0
  40. #
  41. interface GigabitEthernet0/0
  42. port link-mode route
  43. description LAN-interface
  44. ip address 10.28.0.1 255.255.255.0
  45. tcp mss 1280
  46. ipv6 dhcp select server
  47. ipv6 dhcp server apply pool ge0ipv6
  48. ipv6 address 1 1::1/64
  49. ipv6 nd autoconfig other-flag
  50. undo ipv6 nd ra halt
  51. #
  52. interface GigabitEthernet0/1
  53. port link-mode route
  54. description LAN-interface
  55. ip address 10.28.1.1 255.255.255.0
  56. tcp mss 1280
  57. #
  58. interface GigabitEthernet0/2
  59. port link-mode route
  60. combo enable copper
  61. #
  62. interface GigabitEthernet0/3
  63. port link-mode route
  64. description Single_Line1
  65. combo enable copper
  66. pppoe-client dial-bundle-number 3
  67. #
  68. interface GigabitEthernet0/4
  69. port link-mode route
  70. #
  71. interface GigabitEthernet0/5
  72. port link-mode route
  73. #
Xcheng 九段
粉丝:121人 关注:3人
不支持纳管WA5320-C-EI的ap的
仅支持以下wa5320系列ap
WA5320
WA5320H
WA5320E
WA5320i
WA5320-SI
这个和msr3610-x1-dp是不是实际上是完全相同的设备(包括ap的支持)?
zhiliao_YdFiEv 发表时间:2021-05-20
建议和400热线售前工程师或原厂销售代表核实确认。
Xcheng 发表时间:2021-05-20
粉丝:124人 关注:6人
AP无法上线,以下是排查要点,请参考:
1、检查AP出来的网线、水晶头是否有问题。
2、检查基础网络是否可达,比如VLAN透传。
3、检查AC内的授权是否足够使用。
4、检查AC的软件版本是否适配AP。
5、检查AC内是否注册了AP的型号和序列号。
6、检查DHCP内的IP地址是否足够使用。
现在就是怀疑“检查AC的软件版本是否适配AP。”这个情况,不知道icg3000f-dp究竟支不支持
