多wan的网关如何让多网口都可以自动获取ipv6地址?
2021-05-21提问
  • 1收藏,1606浏览
路由器是多wan的,全是三层,没有二层网口。
GE0、GE1、GE3 都是三层网口,GE0和GE1连接交换机,GE3连接光猫(光猫桥接模式),并PPPOE拨号。配置后,现在可以实现 GE0 成功获得联通宽带分配的ipv6地址,如何让 GE0、GE1和GE2等 都可以获得?
之前就是创建ipv6 地址池(本例名字是ge0ipv6)和前缀池(本例是1),通过 ipv6 dhcp client pd 1 rapid-commit option-group 1 把信息填充到池里面,但是我发现GE0用了这个池之后,GE1就无法再使用了。
粉丝:148人 关注:1人
G3口连的光猫,G3口才能获得运营商的ipv6,另外的是获取不到的
# dhcp server ip-pool ge0 gateway-list 10.28.0.1 network 10.28.0.0 mask 255.255.255.0 address range 10.28.0.101 10.28.0.200 dns-list 10.28.0.1 forbidden-ip-range 10.28.0.1 10.28.0.1 static-bind ip-address 10.28.0.11 mask 255.255.255.0 hardware-address 085b-d6f4-8076 description ShenLiyang # dhcp server ip-pool ge1 gateway-list 10.28.1.1 network 10.28.1.0 mask 255.255.255.0 address range 10.28.1.101 10.28.1.200 dns-list 10.28.1.1 forbidden-ip-range 10.28.1.1 10.28.1.1 # ipv6 dhcp pool ge0ipv6 option-group 1 # controller Cellular0/0 # interface Dialer3 mtu 1492 ppp chap password cipher $c$3$vGSdC5n8D1UDzqQNjCfKsdO3pSAgQ/48Aw== ppp chap user SL10012046@E ppp ipcp dns admit-any ppp ipcp dns request ppp pap local-user SL10012046@E password cipher $c$3$Rz99HEepvjJX4eNVVbYVTGAa/ZEkzzBBfg== dialer bundle enable dialer-group 4 dialer timer idle 0 dialer timer autodial 5 ip address ppp-negotiate tcp mss 1280 nat outbound ipv6 address auto link-local ipv6 address dhcp-alloc ipv6 dhcp client pd 1 rapid-commit option-group 1 # interface NULL0 # interface GigabitEthernet0/0 port link-mode route description LAN-interface ip address 10.28.0.1 255.255.255.0 tcp mss 1280 ipv6 dhcp select server ipv6 dhcp server apply pool ge0ipv6 ipv6 address 1 1::1/64 ipv6 nd autoconfig other-flag undo ipv6 nd ra halt # interface GigabitEthernet0/1 port link-mode route description LAN-interface ip address 10.28.1.1 255.255.255.0 tcp mss 1280 # interface GigabitEthernet0/2 port link-mode route combo enable copper # interface GigabitEthernet0/3 port link-mode route description Single_Line1 combo enable copper pppoe-client dial-bundle-number 3 # interface GigabitEthernet0/4 port link-mode route # interface GigabitEthernet0/5 port link-mode route #
Slymitec 发表时间:2021-05-21
是可以获得的
