MSR36-10路由器 BOOTWARE
2018-06-05提问
  • 1收藏,1202浏览
乐蔻 零段
h3c 设备怎么添加 BOOTWARE 密码
ctrl+b进入bootrom界面设置
==========================<EXTENDED-BOOTWARE MENU>========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 这里面没有找到密码
乐蔻 发表时间:2018-06-05
