交换机
2021-05-28提问
  • 1收藏,1002浏览
粉丝:4人 关注:0人
交换机上联双链路,是否有实现方式实现:
1.链路1和链路2正常时候,链路1的端口up然后链路2的端口弄成down;
2.链路1异常、链路2正常时候,链路1的端口弄成down,然后链路2端口弄成up;
恢复后自动恢复为情况1
求大佬教
1.7.1  单Smart Link组配置举例
·     在图1-2所示的组网中,Device C和Device D为Smart Link设备,Device A、Device B和Device E为相关设备。Device C和Device D上VLAN 1~30的流量分别双上行到Device A。
·     通过配置,在Device C和Device D上分别实现双上行链路的灵活备份。
图1-2 单Smart Link组配置组网图
(1)     配置Device C
# 创建VLAN 1~30,将这些VLAN都映射到MSTI 1上,并激活MST域的配置。
<DeviceC> system-view
[DeviceC] vlan 1 to 30
[DeviceC-mst-region] instance 1 vlan 1 to 30
[DeviceC-mst-region] quit
# 分别关闭端口GigabitEthernet1/0/1和GigabitEthernet1/0/2,在这两个端口上分别关闭生成树协议,并将端口配置为Trunk端口且允许VLAN 1~30通过。
[DeviceC-GigabitEthernet1/0/1] shutdown
[DeviceC-GigabitEthernet1/0/1] undo stp enable
[DeviceC-GigabitEthernet1/0/1] port trunk permit vlan 1 to 30
[DeviceC-GigabitEthernet1/0/2] shutdown
[DeviceC-GigabitEthernet1/0/2] undo stp enable
[DeviceC-GigabitEthernet1/0/2] port link-type trunk
[DeviceC-GigabitEthernet1/0/2] port trunk permit vlan 1 to 30
# 创建Smart Link组1,并配置其保护VLAN为MSTI 1所映射的VLAN。
[DeviceC] smart-link group 1
[DeviceC-smlk-group1] protected-vlan reference-instance 1
# 配置Smart Link组1的主端口为GigabitEthernet1/0/1,从端口为GigabitEthernet1/0/2。
[DeviceC-smlk-group1] port gigabitethernet 1/0/1 primary
[DeviceC-smlk-group1] port gigabitethernet 1/0/2 secondary
# 在Smart Link组1中开启发送Flush报文的功能,并指定发送Flush报文的控制VLAN为VLAN 10。
[DeviceC-smlk-group1] flush enable control-vlan 10
[DeviceC-smlk-group1] quit
# 重新开启端口GigabitEthernet1/0/1和GigabitEthernet1/0/2。
[DeviceC-GigabitEthernet1/0/1] undo shutdown
[DeviceC-GigabitEthernet1/0/2] undo shutdown
(2)     配置Device D
<DeviceD> system-view
[DeviceD] vlan 1 to 30
[DeviceD-mst-region] instance 1 vlan 1 to 30
[DeviceD-mst-region] quit
[DeviceD] interface gigabitethernet 1/0/1
[DeviceD-GigabitEthernet1/0/1] shutdown
[DeviceD-GigabitEthernet1/0/1] undo stp enable
[DeviceD-GigabitEthernet1/0/1] port link-type trunk
[DeviceD-GigabitEthernet1/0/1] port trunk permit vlan 1 to 30
[DeviceD-GigabitEthernet1/0/1] quit
[DeviceD-GigabitEthernet1/0/2] shutdown
[DeviceD-GigabitEthernet1/0/2] undo stp enable
[DeviceD-GigabitEthernet1/0/2] port link-type trunk
[DeviceD-GigabitEthernet1/0/2] port trunk permit vlan 1 to 30
[DeviceD] smart-link group 1
[DeviceD-smlk-group1] protected-vlan reference-instance 1
[DeviceD-smlk-group1] port gigabitethernet 1/0/1 primary
[DeviceD-smlk-group1] port gigabitethernet 1/0/2 secondary
# 在Smart Link组1中开启发送Flush报文的功能,并指定发送Flush报文的控制VLAN为VLAN 20。
[DeviceD-smlk-group1] flush enable control-vlan 20
[DeviceD-smlk-group1] quit
[DeviceD-GigabitEthernet1/0/1] undo shutdown
[DeviceD-GigabitEthernet1/0/2] undo shutdown
(3)     配置Device B
# 创建VLAN 1~30。
[DeviceB] vlan 1 to 30
# 将端口GigabitEthernet1/0/1配置为Trunk端口且允许VLAN 1~30通过,在该端口上开启接收Flush报文的功能,并指定接收Flush报文的控制VLAN为VLAN 10和20。
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 1 to 30
[DeviceB-GigabitEthernet1/0/1] smart-link flush enable control-vlan 10 20
# 将端口GigabitEthernet1/0/2配置为Trunk端口且允许VLAN 1~30通过,在该端口上关闭生成树协议并开启接收Flush报文的功能,并指定接收Flush报文的控制VLAN为VLAN 20。
[DeviceB-GigabitEthernet1/0/2] port trunk permit vlan 1 to 30
[DeviceB-GigabitEthernet1/0/2] undo stp enable
[DeviceB-GigabitEthernet1/0/2] smart-link flush enable control-vlan 20
# 将端口GigabitEthernet1/0/3配置为Trunk端口且允许VLAN 1~30通过,在该端口上关闭生成树协议并开启接收Flush报文的功能,并指定接收Flush报文的控制VLAN为VLAN 10。
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] port link-type trunk
[DeviceB-GigabitEthernet1/0/3] port trunk permit vlan 1 to 30
[DeviceB-GigabitEthernet1/0/3] undo stp enable
[DeviceB-GigabitEthernet1/0/3] smart-link flush enable control-vlan 10
(4)     配置Device E
# 创建VLAN 1~30。
<DeviceE> system-view
[DeviceE] vlan 1 to 30
[DeviceE] interface gigabitethernet 1/0/1
[DeviceE-GigabitEthernet1/0/1] port link-type trunk
[DeviceE-GigabitEthernet1/0/1] port trunk permit vlan 1 to 30
[DeviceE-GigabitEthernet1/0/1] smart-link flush enable control-vlan 10 20
[DeviceE-GigabitEthernet1/0/1] quit
# 将端口GigabitEthernet1/0/2配置为Trunk端口且允许VLAN 1~30通过,在该端口上关闭生成树协议并开启接收Flush报文的功能,并指定接收Flush报文的控制VLAN为VLAN 10。
[DeviceE] interface gigabitethernet 1/0/2
[DeviceE-GigabitEthernet1/0/2] port link-type trunk
[DeviceE-GigabitEthernet1/0/2] port trunk permit vlan 1 to 30
[DeviceE-GigabitEthernet1/0/2] undo stp enable
[DeviceE-GigabitEthernet1/0/2] smart-link flush enable control-vlan 10
[DeviceE-GigabitEthernet1/0/2] quit
# 将端口GigabitEthernet1/0/3配置为Trunk端口且允许VLAN 1~30通过,在该端口上关闭生成树协议并开启接收Flush报文的功能,并指定接收Flush报文的控制VLAN为VLAN 20。
[DeviceE] interface gigabitethernet 1/0/3
[DeviceE-GigabitEthernet1/0/3] port link-type trunk
[DeviceE-GigabitEthernet1/0/3] port trunk permit vlan 1 to 30
[DeviceE-GigabitEthernet1/0/3] undo stp enable
[DeviceE-GigabitEthernet1/0/3] smart-link flush enable control-vlan 20
[DeviceE-GigabitEthernet1/0/3] quit
(5)     配置Device A
# 创建VLAN 1~30。
[DeviceA] vlan 1 to 30
# 分别将端口GigabitEthernet1/0/1和GigabitEthernet1/0/2配置为Trunk端口且允许VLAN 1~30通过,在这些端口上开启接收Flush报文的功能,并指定接收Flush报文的控制VLAN为VLAN 10和20。
[DeviceA-GigabitEthernet1/0/1] port trunk permit vlan 1 to 30
[DeviceA-GigabitEthernet1/0/1] smart-link flush enable control-vlan 10 20
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 1 to 30
[DeviceA-GigabitEthernet1/0/2] smart-link flush enable control-vlan 10 20
通过使用display smart-link group命令可以查看设备上Smart Link组的信息:
# 显示Device C上Smart Link组的信息。
[DeviceC] display smart-link group 1
Smart link group 1 information:
  Device ID       : 000f-e23d-5af0
  Preemption mode : None
  Preemption delay: 1(s)
  Control VLAN    : 10
  Protected VLAN  : Reference Instance 1
  Member                  Role      State   Flush-count     Last-flush-time
  GE1/0/1                 PRIMARY   ACTIVE  5               16:45:20 2012/04/21
  GE1/0/2                 SECONDARY STANDBY 1               16:37:20 2012/04/21
通过使用display smart-link flush命令可以查看设备上收到的Flush报文信息:
# 显示Device B上收到的Flush报文信息。
[DeviceB] display smart-link flush
 Received flush packets                             : 5
 Receiving interface of the last flush packet       : GigabitEthernet1/0/3
 Receiving time of the last flush packet            : 16:50:21 2012/04/21
 Device ID of the last flush packet                 : 000f-e23d-5af0
 Control VLAN of the last flush packet              : 10
粉丝:124人 关注:6人
目前还没有这个功能实现。
链路检测的可以使用NQA或BFD检测来实现,正常的时候两条物理链路都正常,检测到链路断开以后,会触发track,切换路由走备用链路出去。主链路恢复了会切换回来。
