ping丢包
  • 1收藏,1546浏览
Oct 11 2020 02:42:53 109 %%01IFPDT/4/IF_STATE(l)[0]:Interface GigabitEthernet0/0/4 has turned into UP state. Oct 11 2020 02:42:48 109 %%01IFADP/4/PORTDOWNINFO(l)[1]:Interface GigabitEthernet0/0/4 has turned into DOWN state. (Information=Physical state: down, Negotiation: enable, Negotiation complete: no, Local full-duplex(10M: yes, 100M: yes, 1000M: yes), Local half-duplex(10M: yes, 100M: yes, 1000M: no), Remote full-duplex(10M: no, 100M: no, 1000M: no), Remote half-duplex(10M: no, 100M: no, 1000M: no)) Oct 11 2020 02:42:48 109 %%01IFPDT/4/IF_STATE(l)[2]:Interface GigabitEthernet0/0/4 has turned into DOWN state. Oct 10 2020 22:38:33 109 %%01IFPDT/4/IF_STATE(l)[3]:Interface GigabitEthernet0/0/5 has turned into UP state. Oct 10 2020 22:30:32 109 %%01IFPDT/4/IF_STATE(l)[4]:Interface GigabitEthernet0/0/3 has turned into UP state. Oct 10 2020 22:29:35 109 %%01IFADP/4/PORTDOWNINFO(l)[5]:Interface GigabitEthernet0/0/3 has turned into DOWN state. (Information=Physical state: down, Negotiation: enable, Negotiation complete: no, Local full-duplex(10M: yes, 100M: yes, 1000M: yes), Local half-duplex(10M: yes, 100M: yes, 1000M: no), Remote full-duplex(10M: no, 100M: no, 1000M: no), Remote half-duplex(10M: no, 100M: no, 1000M: no)) Oct 10 2020 22:29:35 109 %%01IFPDT/4/IF_STATE(l)[6]:Interface GigabitEthernet0/0/3 has turned into DOWN state. Oct 10 2020 22:27:30 109 %%01IFPDT/4/IF_STATE(l)[7]:Interface GigabitEthernet0/0/3 has turned into UP state. Oct 10 2020 21:55:57 109 %%01IFADP/4/PORTDOWNINFO(l)[8]:Interface GigabitEthernet0/0/3 has turned into DOWN state. (Information=Physical state: down, Negotiation: enable, Negotiation complete: no, Local full-duplex(10M: yes, 100M: yes, 1000M: yes), Local half-duplex(10M: yes, 100M: yes, 1000M: no), Remote full-duplex(10M: no, 100M: no, 1000M: no), Remote half-duplex(10M: no, 100M: no, 1000M: no)) Oct 10 2020 21:55:57 109 %%01IFPDT/4/IF_STATE(l)[9]:Interface GigabitEthernet0/0/3 has turned into DOWN state. Oct 10 2020 21:51:00 109 %%01IFPDT/4/IF_STATE(l)[10]:Interface GigabitEthernet0
pc1——>swA——>swB——>swC——>pc2 ,swA与swC为接入层交换机分别接pc1和pc2,swB为核心交换机,pc1为192.168.1.2,pc2为192.168.2.2,swA、swC与核心swB分别用中继口对接,swB做动态路由,现在pc1去ping pc2,有丢包。日志告警在问题描述,求解为什么会有丢包?该怎样解决
粉丝:124人 关注:6人
PING丢包,以下是排查要点,请参考:
1、检查二层网络内是否有可能存在环路。
2、检查三层网络的路由来回路径是否一致。
3、检查设备间的物理链路是否正常。
4、检查设备的CPU、内存、端口利用率是否高。
5、配置QOS流统确认下丢包的位置。
粉丝:12人 关注:1人
这个跨三层了转发了吧,如果交换机之间是二层接口可能是有环路,如果二层环路没有的话需要做流量统计确认丢包位置了,流统的方法知了的案例库里有搜索流统就可以搜到
