有没有linux高手!重金求能刷白牌交换机系统的
2021-05-30提问
  • 1收藏,1659浏览
粉丝:0人 关注:2人
设置列表
  • 有序列表
  • 无序列表
白牌交换机!
powerpc D2020的芯片 48口万兆SFP+ 4口40GBqsfp接口
以前是有系统的,下架的时候系统被删了部分文件,不启动!
有问题自检报错如下↓
U-Boot 2009.11(XORPLUS Beta 3.3.0)-svn1380 (Jul 03 2013 - 13:30:32) CPU0: P2020, Version: 2.1, (0x80e20021) Core: E500, Version: 5.1, (0x80211051) Clock Configuration: CPU0:1200 MHz, CPU1:1200 MHz, CCB:400 MHz, DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:25 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled I2C: ready DRAM: Configuring DDR for 800 MT/s data rate DDR: 2 GB FLASH: 64 MB L2: 512 KB enabled NAND: 1024 MiB EEPROM: NXID v0 eTSEC2 is in sgmii mode. eTSEC3 is in sgmii mode. PCIE2: disabled PCIE1 connected to Slot 2 as Root Complex (base addr ffe0a000) Scanning PCI bus 01 01 00 14e4 b846 0200 00 PCIE1 on bus 00 - 01 In: serial Out: serial Err: serial Net: get_phy_info: find the matched ID. get_phy_info: find the matched ID. eTSEC3: No support for PHY id ffffffff; assuming generic eTSEC2, eTSEC3 USB: PHY Init Hit Ctrl^C to stop autoboot: 0 Creating 1 MTD partitions on "nand0": 0x000010000000-0x000040000000 : "mtd=5" Bad block table found at page 524224, version 0x01 Bad block table found at page 524160, version 0x01 nand_read_bbt: Bad block at 0x112e0000 nand_read_bbt: Bad block at 0x12f40000 nand_read_bbt: Bad block at 0x29ee0000 nand_read_bbt: Bad block at 0x2d1c0000 nand_read_bbt: Bad block at 0x30c60000 UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=5" UBI: MTD device size: 768 MiB UBI: number of good PEBs: 6135 UBI: number of bad PEBs: 9 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 6135 UBI: number of PEBs reserved for bad PEB handling: 61 UBI: max/mean erase counter: 4/2 UBI: mtd1 is detached from ubi0 Creating 1 MTD partitions on "nand0": 0x000010000000-0x000040000000 : "mtd=5" UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=5" UBI: MTD device size: 768 MiB UBI: number of good PEBs: 6135 UBI: number of bad PEBs: 9 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 6135 UBI: number of PEBs reserved for bad PEB handling: 61 UBI: max/mean erase counter: 4/2 UBIFS: recovery needed UBIFS: recovery deferred UBIFS: mounted UBI device 0, volume 0, name "rootfs" UBIFS: mounted read-only UBIFS: file system size: 741758976 bytes (724374 KiB, 707 MiB, 5749 LEBs) UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: LZO UBIFS: reserved for root: 0 bytes (0 KiB) Loading file '/boot/uImage' to addr 0x01000000 with size 3548542 (0x0036257e)... Done Loading file '/boot/p2020rdb.dtb' to addr 0x00c00000 with size 11755 (0x00002deb )... Done WARNING: adjusting available memory to 30000000 ## Booting kernel from Legacy Image at 01000000 ... Image Name: Linux-2.6.32 Created: 2018-09-05 7:52:45 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 3548478 Bytes = 3.4 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 00c00000 Booting using the fdt blob at 0xc00000 Uncompressing Kernel Image ... OK Using P2020 RDB machine description Memory CAM mapping: 256/256/256 Mb, residual: 1280Mb Linux version 2.6.32 (lijing@bb-sys-nsi-sti01.bb01.baidu.com) (gcc version 4.2.2 ) #1 SMP Wed Sep 5 15:52:37 CST 2018 CPU maps initialized for 1 thread per core Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->255 PCI host bridge /pcie@ffe09000 ranges: MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000 IO 0x00000000ffc20000..0x00000000ffc2ffff -> 0x0000000000000000 /pcie@ffe09000: PCICSRBAR @ 0x0 /pcie@ffe09000: WARNING: Outbound window cfg leaves gaps in memory map. Adjustin g the memory map could reduce unnecessary bounce buffering. /pcie@ffe09000: DMA window size is 0x0 Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->0 PCI host bridge /pcie@ffe0a000 ranges: MEM 0x00000000c0000000..0x00000000dfffffff -> 0x00000000c0000000 IO 0x00000000ffc30000..0x00000000ffc3ffff -> 0x0000000000000000 /pcie@ffe0a000: PCICSRBAR @ 0xfff00000 MPC85xx RDB board from Freescale Semiconductor Zone PFN ranges: DMA 0x00000000 -> 0x00030000 Normal 0x00030000 -> 0x00030000 HighMem 0x00030000 -> 0x00080000 Movable zone start PFN for each node early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x00080000 MMU: Allocated 1088 bytes of context maps for 255 contexts PERCPU: Embedded 8 pages/cpu @c1c0f000 s8216 r8192 d16360 u65536 pcpu-alloc: s8216 r8192 d16360 u65536 alloc=16*4096 pcpu-alloc: [0] 0 [0] 1 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520192 Kernel command line: ubi.mtd=9 root=ubi0:rootfs rw cOnsole=ttyS0,115200 rootfsty pe=ubifs ramdisk_size=3000000 cache-sram-size=0x10000 PID hash table entries: 4096 (order: 2, 16384 bytes) Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Memory: 2071660k/2097152k available (6824k kernel code, 24636k reserved, 276k da ta, 153k bss, 252k init) Kernel virtual memory layout: * 0xfffe0000..0xfffff000 : fixmap * 0xff800000..0xffc00000 : highmem PTEs * 0xff7da000..0xff800000 : early ioremap * 0xf1000000..0xff7da000 : vmalloc & ioremap SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 Hierarchical RCU implementation. NR_IRQS:512 mpic: Setting up MPIC " OpenPIC " version 1.2 at ffe40000, max 2 CPUs mpic: ISU size: 256, shift: 8, mask: ff mpic: Initializing for 256 sources clocksource: timebase mult[5000000] shift[22] registered Console: colour dummy device 80x25 Mount-cache hash table entries: 512 mpic: requesting IPIs ... Processor 1 found. Brought up 2 CPUs xor: measuring software checksum speed 8regs : 1415.000 MB/sec 8regs_prefetch: 1225.000 MB/sec 32regs : 1523.000 MB/sec 32regs_prefetch: 1350.000 MB/sec xor: using function: 32regs (1523.000 MB/sec) NET: Registered protocol family 16 PCI: Probing PCI hardware pci 0001:01:00.0: ignoring class b20 (doesn't match header type 01) pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold pci 0001:01:00.0: PME# disabled pci 0001:02:00.0: PME# supported from D0 D3hot D3cold pci 0001:02:00.0: PME# disabled pci 0001:01:00.0: PCI bridge, secondary bus 0001:02 pci 0001:01:00.0: IO window: 0x00-0xffff pci 0001:01:00.0: MEM window: 0xc0000000-0xdfffffff pci 0001:01:00.0: PREFETCH window: disabled pci 0001:01:00.0: enabling device (0106 -> 0107) bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb raid6: int32x1 146 MB/s raid6: int32x2 247 MB/s raid6: int32x4 377 MB/s raid6: int32x8 338 MB/s raid6: using algorithm int32x4 (377 MB/s) Freescale Elo / Elo Plus DMA driver Switching to clocksource timebase NET: Registered protocol family 2 IP route cache hash table entries: 32768 (order: 5, 131072 bytes) TCP established hash table entries: 131072 (order: 8, 1048576 bytes) TCP bind hash table entries: 65536 (order: 7, 524288 bytes) TCP: Hash tables configured (established 131072 bind 65536) TCP reno registered NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. fsl-elo-dma ffe0c300.dma: Probe the Freescale DMA driver for fsl,eloplus-dma con troller at 0xffe0c300... fsl-elo-dma ffe0c300.dma: #0 (fsl,eloplus-dma-channel), irq 76 fsl-elo-dma ffe0c300.dma: #1 (fsl,eloplus-dma-channel), irq 77 fsl-elo-dma ffe0c300.dma: #2 (fsl,eloplus-dma-channel), irq 78 fsl-elo-dma ffe0c300.dma: #3 (fsl,eloplus-dma-channel), irq 79 fsl-elo-dma ffe21300.dma: Probe the Freescale DMA driver for fsl,eloplus-dma con troller at 0xffe21300... fsl-elo-dma ffe21300.dma: #0 (fsl,eloplus-dma-channel), irq 20 fsl-elo-dma ffe21300.dma: #1 (fsl,eloplus-dma-channel), irq 21 fsl-elo-dma ffe21300.dma: #2 (fsl,eloplus-dma-channel), irq 22 fsl-elo-dma ffe21300.dma: #3 (fsl,eloplus-dma-channel), irq 23 audit: initializing netlink socket (disabled) type=2000 audit(0.372:1): initialized highmem bounce pool size: 64 pages Installing knfsd (copyright (C) 1996 okir@monad.swb.de). Slow work thread pool: Starting up Slow work thread pool: Ready NTFS driver 2.1.29 [Flags: R/O]. JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. SGI XFS with security attributes, large block/inode numbers, no debug enabled msgmni has been set to 1487 alg: No test for stdrng (krng) async_tx: api initialized (async) io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered (default) kennisis_cpld:CPLD driver init kennisis_cpld:led_cpld_base = f111c000 Generic non-volatile memory driver v1.1 Serial: 8250/16550 driver, 2 ports, IRQ sharing enabled serial8250.0: ttyS0 at MMIO 0xffe04600 (irq = 42) is a 16550A console [ttyS0] enabled brd: module loaded loop: module loaded nbd: registered device at major 43 st: Version 20081215, fixed bufsize 32768, s/g segs 256 ec000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 ec000000.nor: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. RedBoot partition parsing not available Creating 4 MTD partitions on "ec000000.nor": 0x000000000000-0x000003900000 : "jffs2" ftl_cs: FTL header not found. 0x000003b00000-0x000003f00000 : "kernel" ftl_cs: FTL header not found. 0x000003f00000-0x000003f80000 : "dtb" ftl_cs: FTL header not found. 0x000003f80000-0x000004000000 : "u-boot" ftl_cs: FTL header not found. NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) RedBoot partition parsing not available Creating 6 MTD partitions on "ffa00000.flash": 0x000000000000-0x000000100000 : "NAND (RO) U-Boot Image" ftl_cs: FTL header not found. 0x000000100000-0x000000200000 : "NAND (RO) DTB Image" ftl_cs: FTL header not found. 0x000000200000-0x000000600000 : "NAND (RO) Linux Kernel Image" ftl_cs: FTL header not found. 0x000000600000-0x00000fe00000 : "NAND (RW) JFFS2 Root File System" ftl_cs: FTL header not found. 0x00000fe00000-0x000010000000 : "NAND (RW) Test Area" ftl_cs: FTL header not found. 0x000010000000-0x000040000000 : "NAND (RW) Writable User Area" ftl_cs: FTL header not found. eLBC NAND device at 0xffa00000, bank 1 UBI: attaching mtd9 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 UBI: attached mtd9 to ubi0 UBI: MTD device name: "NAND (RW) Writable User Area" UBI: MTD device size: 768 MiB UBI: number of good PEBs: 6135 UBI: number of bad PEBs: 9 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 6135 UBI: number of PEBs reserved for bad PEB handling: 61 UBI: max/mean erase counter: 4/2 UBI: image sequence number: 1275472773 UBI: background thread "ubi_bgt0d" started, PID 1077 fsl_m25p80 spi28672.0: unrecognized JEDEC id ffffff fsl_m25p80 spi28672.0: found UNKNOWN, expected s25sl128b ffe07000.spi: Freescale eSPI Controller driver at 0xf1134000 (irq = 59) Fixed MDIO Bus: probed e1000e: Intel(R) PRO/1000 Network Driver - 1.0.2-k2 e1000e: Copyright (c) 1999-2008 Intel Corporation. IEEE1588: ptp-timer devicepresent in the system IEEE1588: ptp-timer initialized eth0: Gianfar Ethernet Controller Version 1.4-skbr1.1.4, 92:68:01:10:00:00 eth0: Running with NAPI enabled eth0: :RX BD ring size for Q[0]: 128 eth0:TX BD ring size for Q[0]: 128 IEEE1588: ptp-timer devicepresent in the system IEEE1588: ptp-timer initialized eth1: Gianfar Ethernet Controller Version 1.4-skbr1.1.4, 00:e0:ec:25:33:fd eth1: Running with NAPI enabled eth1: :RX BD ring size for Q[0]: 128 eth1:TX BD ring size for Q[0]: 128 IEEE1588: ptp-timer devicepresent in the system IEEE1588: ptp-timer initialized eth2: Gianfar Ethernet Controller Version 1.4-skbr1.1.4, 00:e0:ec:25:33:fe eth2: Running with NAPI enabled eth2: :RX BD ring size for Q[0]: 128 eth2:TX BD ring size for Q[0]: 128 Freescale PowerQUICC MII Bus: probed Freescale PowerQUICC MII Bus: probed Freescale PowerQUICC MII Bus: probed tun: Universal TUN/TAP device driver, 1.6 tun: (C) 1999-2004 Max Krasnyansky <maxk@***.***> ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 fsl-ehci fsl-ehci.0: irq 28, io base 0xffe22000 fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. i2c /dev entries driver rtc-ds1307 0-0068: rtc core: registered ds1339 as rtc0 thermal_driver: thermal driver init thermal_driver: Create totally 15 class sys files md: raid6 personality registered for level 6 md: raid5 personality registered for level 5 md: raid4 personality registered for level 4 sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman ricoh-mmc: Ricoh MMC Controller disabling driver ricoh-mmc: Copyright(c) Philip Langdale mmc0: SDHCI controller on ffe2e000.sdhci [ffe2e000.sdhci] using DMA wbsd: Winbond W83L51xD SD/MMC card interface driver wbsd: Copyright(c) Pierre Ossman via_sdmmc: VIA SD/MMC Card Reader driver (C) 2008 VIA Technologies, Inc. Netfilter messages via NETLINK v0.30. nf_conntrack version 0.5.0 (16384 buckets, 65536 max) CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or sysctl net.netfilter.nf_conntrack_acct=1 to enable it. xt_time: kernel timezone is -0000 TCP cubic registered Initializing XFRM netlink socket NET: Registered protocol family 10 NET: Registered protocol family 17 NET: Registered protocol family 15 802.1Q VLAN Support v1.8 Ben Greear <greearb@***.***> All bugs added by David S. Miller <davem@redhat.com> rtc-ds1307 0-0068: setting system clock to 2020-12-01 04:15:07 UTC (1606796107) md: Waiting for all devices to be available before autodetect md: If you don't use raid, use raid=noautodetect md: Autodetecting RAID arrays. md: Scanned 0 and added 0 devices. md: autorun ... md: ... autorun DONE. UBIFS: recovery needed UBIFS: recovery completed UBIFS: mounted UBI device 0, volume 0, name "rootfs" UBIFS: file system size: 741758976 bytes (724374 KiB, 707 MiB, 5749 LEBs) UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root: 0 bytes (0 KiB) VFS: Mounted root (ubifs filesystem) on device 0:13. Freeing unused kernel memory: 252k init Warning: unable to open an initial console. Kernel panic - not syncing: No init found. Try passing init= option to kernel. Rebooting in 180 seconds..
完好机器自检↓
U-Boot 2009.11(XORPLUS Beta 3.3.1)-svn1431 (Aug 26 2013 - 19:31:34) CPU0: P2020, Version: 2.1, (0x80e20021) Core: E500, Version: 5.1, (0x80211051) Clock Configuration: CPU0:1200 MHz, CPU1:1200 MHz, CCB:400 MHz, DDR:400 MHz (800 MT/s data rate) (Asynchronous), LBC:25 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled I2C: ready DRAM: Configuring DDR for 800 MT/s data rate DDR: 2 GB FLASH: 64 MB L2: 512 KB enabled NAND: 1024 MiB EEPROM: NXID v0 eTSEC2 is in sgmii mode. eTSEC3 is in sgmii mode. PCIE2: disabled PCIE1 connected to Slot 2 as Root Complex (base addr ffe0a000) Scanning PCI bus 01 01 00 14e4 b846 0200 00 PCIE1 on bus 00 - 01 In: serial Out: serial Err: serial Net: get_phy_info: find the matched ID. get_phy_info: find the matched ID. eTSEC3: No support for PHY id ffffffff; assuming generic eTSEC2, eTSEC3 USB: PHY Init Hit Ctrl^C to stop autoboot: 0 Creating 1 MTD partitions on "nand0": 0x000010000000-0x000040000000 : "mtd=5" Bad block table found at page 524224, version 0x01 Bad block table found at page 524160, version 0x01 UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=5" UBI: MTD device size: 768 MiB UBI: number of good PEBs: 6140 UBI: number of bad PEBs: 4 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 6140 UBI: number of PEBs reserved for bad PEB handling: 61 UBI: max/mean erase counter: 10563/8187 UBI: mtd1 is detached from ubi0 Creating 1 MTD partitions on "nand0": 0x000010000000-0x000040000000 : "mtd=5" UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=5" UBI: MTD device size: 768 MiB UBI: number of good PEBs: 6140 UBI: number of bad PEBs: 4 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 6140 UBI: number of PEBs reserved for bad PEB handling: 61 UBI: max/mean erase counter: 10563/8187 UBIFS: recovery needed UBIFS: recovery deferred UBIFS: mounted UBI device 0, volume 0, name "rootfs" UBIFS: mounted read-only UBIFS: file system size: 741758976 bytes (724374 KiB, 707 MiB, 5749 LEBs) UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: LZO UBIFS: reserved for root: 0 bytes (0 KiB) Loading file '/boot/uImage' to addr 0x01000000 with size 3548542 (0x0036257e)... Done Loading file '/boot/p2020rdb.dtb' to addr 0x00c00000 with size 11755 (0x00002deb )... Done WARNING: adjusting available memory to 30000000 ## Booting kernel from Legacy Image at 01000000 ... Image Name: Linux-2.6.32 Created: 2018-09-05 7:52:45 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 3548478 Bytes = 3.4 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 00c00000 Booting using the fdt blob at 0xc00000 Uncompressing Kernel Image ... OK Using P2020 RDB machine description Memory CAM mapping: 256/256/256 Mb, residual: 1280Mb Linux version 2.6.32 (lijing@bb-sys-nsi-sti01.bb01.baidu.com) (gcc version 4.2.2 ) #1 SMP Wed Sep 5 15:52:37 CST 2018 CPU maps initialized for 1 thread per core Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->255 PCI host bridge /pcie@ffe09000 ranges: MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000 IO 0x00000000ffc20000..0x00000000ffc2ffff -> 0x0000000000000000 /pcie@ffe09000: PCICSRBAR @ 0x0 /pcie@ffe09000: WARNING: Outbound window cfg leaves gaps in memory map. Adjustin g the memory map could reduce unnecessary bounce buffering. /pcie@ffe09000: DMA window size is 0x0 Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->0 PCI host bridge /pcie@ffe0a000 ranges: MEM 0x00000000c0000000..0x00000000dfffffff -> 0x00000000c0000000 IO 0x00000000ffc30000..0x00000000ffc3ffff -> 0x0000000000000000 /pcie@ffe0a000: PCICSRBAR @ 0xfff00000 MPC85xx RDB board from Freescale Semiconductor Zone PFN ranges: DMA 0x00000000 -> 0x00030000 Normal 0x00030000 -> 0x00030000 HighMem 0x00030000 -> 0x00080000 Movable zone start PFN for each node early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x00080000 MMU: Allocated 1088 bytes of context maps for 255 contexts PERCPU: Embedded 8 pages/cpu @c1c0f000 s8216 r8192 d16360 u65536 pcpu-alloc: s8216 r8192 d16360 u65536 alloc=16*4096 pcpu-alloc: [0] 0 [0] 1 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520192 Kernel command line: ubi.mtd=9 root=ubi0:rootfs rw rootflags=sync cOnsole=ttyS0, 115200 rootfstype=ubifs ramdisk_size=3000000 cache-sram-size=0x10000 PID hash table entries: 4096 (order: 2, 16384 bytes) Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Memory: 2071660k/2097152k available (6824k kernel code, 24636k reserved, 276k da ta, 153k bss, 252k init) Kernel virtual memory layout: * 0xfffe0000..0xfffff000 : fixmap * 0xff800000..0xffc00000 : highmem PTEs * 0xff7da000..0xff800000 : early ioremap * 0xf1000000..0xff7da000 : vmalloc & ioremap SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 Hierarchical RCU implementation. NR_IRQS:512 mpic: Setting up MPIC " OpenPIC " version 1.2 at ffe40000, max 2 CPUs mpic: ISU size: 256, shift: 8, mask: ff mpic: Initializing for 256 sources clocksource: timebase mult[5000000] shift[22] registered Console: colour dummy device 80x25 Mount-cache hash table entries: 512 mpic: requesting IPIs ... Processor 1 found. Brought up 2 CPUs xor: measuring software checksum speed 8regs : 1415.000 MB/sec 8regs_prefetch: 1225.000 MB/sec 32regs : 1523.000 MB/sec 32regs_prefetch: 1350.000 MB/sec xor: using function: 32regs (1523.000 MB/sec) NET: Registered protocol family 16 PCI: Probing PCI hardware pci 0001:01:00.0: ignoring class b20 (doesn't match header type 01) pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold pci 0001:01:00.0: PME# disabled pci 0001:02:00.0: PME# supported from D0 D3hot D3cold pci 0001:02:00.0: PME# disabled pci 0001:01:00.0: PCI bridge, secondary bus 0001:02 pci 0001:01:00.0: IO window: 0x00-0xffff pci 0001:01:00.0: MEM window: 0xc0000000-0xdfffffff pci 0001:01:00.0: PREFETCH window: disabled pci 0001:01:00.0: enabling device (0106 -> 0107) bio: create slab <bio-0> at 0 vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb raid6: int32x1 146 MB/s raid6: int32x2 247 MB/s raid6: int32x4 377 MB/s raid6: int32x8 338 MB/s raid6: using algorithm int32x4 (377 MB/s) Freescale Elo / Elo Plus DMA driver Switching to clocksource timebase NET: Registered protocol family 2 IP route cache hash table entries: 32768 (order: 5, 131072 bytes) TCP established hash table entries: 131072 (order: 8, 1048576 bytes) TCP bind hash table entries: 65536 (order: 7, 524288 bytes) TCP: Hash tables configured (established 131072 bind 65536) TCP reno registered NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. fsl-elo-dma ffe0c300.dma: Probe the Freescale DMA driver for fsl,eloplus-dma con troller at 0xffe0c300... fsl-elo-dma ffe0c300.dma: #0 (fsl,eloplus-dma-channel), irq 76 fsl-elo-dma ffe0c300.dma: #1 (fsl,eloplus-dma-channel), irq 77 fsl-elo-dma ffe0c300.dma: #2 (fsl,eloplus-dma-channel), irq 78 fsl-elo-dma ffe0c300.dma: #3 (fsl,eloplus-dma-channel), irq 79 fsl-elo-dma ffe21300.dma: Probe the Freescale DMA driver for fsl,eloplus-dma con troller at 0xffe21300... fsl-elo-dma ffe21300.dma: #0 (fsl,eloplus-dma-channel), irq 20 fsl-elo-dma ffe21300.dma: #1 (fsl,eloplus-dma-channel), irq 21 fsl-elo-dma ffe21300.dma: #2 (fsl,eloplus-dma-channel), irq 22 fsl-elo-dma ffe21300.dma: #3 (fsl,eloplus-dma-channel), irq 23 audit: initializing netlink socket (disabled) type=2000 audit(0.372:1): initialized highmem bounce pool size: 64 pages Installing knfsd (copyright (C) 1996 okir@monad.swb.de). Slow work thread pool: Starting up Slow work thread pool: Ready NTFS driver 2.1.29 [Flags: R/O]. JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. SGI XFS with security attributes, large block/inode numbers, no debug enabled msgmni has been set to 1487 alg: No test for stdrng (krng) async_tx: api initialized (async) io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered (default) kennisis_cpld:CPLD driver init kennisis_cpld:led_cpld_base = f111c000 Generic non-volatile memory driver v1.1 Serial: 8250/16550 driver, 2 ports, IRQ sharing enabled serial8250.0: ttyS0 at MMIO 0xffe04600 (irq = 42) is a 16550A console [ttyS0] enabled brd: module loaded loop: module loaded nbd: registered device at major 43 st: Version 20081215, fixed bufsize 32768, s/g segs 256 ec000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank Amd/Fujitsu Extended Query Table at 0x0040 ec000000.nor: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. RedBoot partition parsing not available Creating 4 MTD partitions on "ec000000.nor": 0x000000000000-0x000003900000 : "jffs2" ftl_cs: FTL header not found. 0x000003b00000-0x000003f00000 : "kernel" ftl_cs: FTL header not found. 0x000003f00000-0x000003f80000 : "dtb" ftl_cs: FTL header not found. 0x000003f80000-0x000004000000 : "u-boot" ftl_cs: FTL header not found. NAND device: Manufacturer ID: 0x01, Chip ID: 0xd3 (AMD NAND 1GiB 3,3V 8-bit) RedBoot partition parsing not available Creating 6 MTD partitions on "ffa00000.flash": 0x000000000000-0x000000100000 : "NAND (RO) U-Boot Image" ftl_cs: FTL header not found. 0x000000100000-0x000000200000 : "NAND (RO) DTB Image" ftl_cs: FTL header not found. 0x000000200000-0x000000600000 : "NAND (RO) Linux Kernel Image" ftl_cs: FTL header not found. 0x000000600000-0x00000fe00000 : "NAND (RW) JFFS2 Root File System" ftl_cs: FTL header not found. 0x00000fe00000-0x000010000000 : "NAND (RW) Test Area" ftl_cs: FTL header not found. 0x000010000000-0x000040000000 : "NAND (RW) Writable User Area" ftl_cs: FTL header not found. eLBC NAND device at 0xffa00000, bank 1 UBI: attaching mtd9 to ubi0 UBI: physical eraseblock size: 131072 bytes (128 KiB) UBI: logical eraseblock size: 129024 bytes UBI: smallest flash I/O unit: 2048 UBI: sub-page size: 512 UBI: VID header offset: 512 (aligned 512) UBI: data offset: 2048 UBI: attached mtd9 to ubi0 UBI: MTD device name: "NAND (RW) Writable User Area" UBI: MTD device size: 768 MiB UBI: number of good PEBs: 6140 UBI: number of bad PEBs: 4 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 1 UBI: available PEBs: 0 UBI: total number of reserved PEBs: 6140 UBI: number of PEBs reserved for bad PEB handling: 61 UBI: max/mean erase counter: 10563/8187 UBI: image sequence number: 1983074429 UBI: background thread "ubi_bgt0d" started, PID 1077 fsl_m25p80 spi28672.0: unrecognized JEDEC id ffffff fsl_m25p80 spi28672.0: found UNKNOWN, expected s25sl128b ffe07000.spi: Freescale eSPI Controller driver at 0xf1134000 (irq = 59) Fixed MDIO Bus: probed e1000e: Intel(R) PRO/1000 Network Driver - 1.0.2-k2 e1000e: Copyright (c) 1999-2008 Intel Corporation. IEEE1588: ptp-timer devicepresent in the system IEEE1588: ptp-timer initialized eth0: Gianfar Ethernet Controller Version 1.4-skbr1.1.4, 00:00:00:00:00:00 eth0: Running with NAPI enabled eth0: :RX BD ring size for Q[0]: 128 eth0:TX BD ring size for Q[0]: 128 IEEE1588: ptp-timer devicepresent in the system IEEE1588: ptp-timer initialized eth1: Gianfar Ethernet Controller Version 1.4-skbr1.1.4, 00:e0:ec:25:82:30 eth1: Running with NAPI enabled eth1: :RX BD ring size for Q[0]: 128 eth1:TX BD ring size for Q[0]: 128 IEEE1588: ptp-timer devicepresent in the system IEEE1588: ptp-timer initialized eth2: Gianfar Ethernet Controller Version 1.4-skbr1.1.4, 00:e0:ec:25:82:31 eth2: Running with NAPI enabled eth2: :RX BD ring size for Q[0]: 128 eth2:TX BD ring size for Q[0]: 128 Freescale PowerQUICC MII Bus: probed Freescale PowerQUICC MII Bus: probed Freescale PowerQUICC MII Bus: probed tun: Universal TUN/TAP device driver, 1.6 tun: (C) 1999-2004 Max Krasnyansky <maxk@***.***> ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 fsl-ehci fsl-ehci.0: irq 28, io base 0xffe22000 fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. i2c /dev entries driver rtc-ds1307 0-0068: rtc core: registered ds1339 as rtc0 thermal_driver: thermal driver init thermal_driver: Create totally 15 class sys files md: raid6 personality registered for level 6 md: raid5 personality registered for level 5 md: raid4 personality registered for level 4 sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman ricoh-mmc: Ricoh MMC Controller disabling driver ricoh-mmc: Copyright(c) Philip Langdale mmc0: SDHCI controller on ffe2e000.sdhci [ffe2e000.sdhci] using DMA wbsd: Winbond W83L51xD SD/MMC card interface driver wbsd: Copyright(c) Pierre Ossman via_sdmmc: VIA SD/MMC Card Reader driver (C) 2008 VIA Technologies, Inc. Netfilter messages via NETLINK v0.30. nf_conntrack version 0.5.0 (16384 buckets, 65536 max) CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or sysctl net.netfilter.nf_conntrack_acct=1 to enable it. xt_time: kernel timezone is -0000 TCP cubic registered Initializing XFRM netlink socket NET: Registered protocol family 10 NET: Registered protocol family 17 NET: Registered protocol family 15 802.1Q VLAN Support v1.8 Ben Greear <greearb@***.***> All bugs added by David S. Miller <davem@redhat.com> rtc-ds1307 0-0068: setting system clock to 2020-11-30 06:39:47 UTC (1606718387) md: Waiting for all devices to be available before autodetect md: If you don't use raid, use raid=noautodetect md: Autodetecting RAID arrays. md: Scanned 0 and added 0 devices. md: autorun ... md: ... autorun DONE. UBIFS: parse sync UBIFS: recovery needed UBIFS: recovery completed UBIFS: mounted UBI device 0, volume 0, name "rootfs" UBIFS: file system size: 741758976 bytes (724374 KiB, 707 MiB, 5749 LEBs) UBIFS: journal size: 9033728 bytes (8822 KiB, 8 MiB, 71 LEBs) UBIFS: media format: w4/r0 (latest is w4/r0) UBIFS: default compressor: lzo UBIFS: reserved for root: 0 bytes (0 KiB) VFS: Mounted root (ubifs filesystem) on device 0:13. Freeing unused kernel memory: 252k init linux_kernel_bde: module license 'Proprietary' taints kernel. Disabling lock debugging due to kernel taint linux-kernel-bde (1230): Payload size of 256 bytes may not be supported by all P CIe bridges by default. Checking file system integrity on '/dev/mmcblk01' ... File system OK net.netfilter.nf_conntrack_acct = 1 net.ipv6.conf.all.forwarding = 1 System initiating...Please wait... Please choose which to start: XorPlus or System shell: (Will choose default entry if no input in 10 seconds.) [1] XorPlus * default [2] System shell Enter your choice (1,2): XorPlus L2/L3 switch system is selected. txbd[0]: addr, vaddr = 0x2f13d000,0xef13d000 rxbd[0]: addr,vaddr=0x2f13d400,0xef13d400 ADDRCONF(NETDEV_UP): eth0: link is not ready net eth1: could not attach to PHY ifconfig: SIOCSIFFLAGS: No such device Switch Manager starting ... ... Waiting for synchronizing configuration. Synchronize configuration OK. Baidu Switch OS Welcome to XorPlus on XorPlus XorPlus> XorPlus> file list ./ drwxr-xr-x 18 506 users 1464 Nov 30 14:41 . drwxr-xr-x 18 506 users 1464 Nov 30 14:41 .. drwxr-xr-x 2 root xorp 6112 Nov 30 14:39 bin drwxrwxr-x 2 root xorp 296 Nov 29 21:33 boot -rwxrwxrwx 1 root root 1020344 Jul 5 2014 busybox drwxrwxrwx 2 root xorp 160 Nov 29 21:34 cftmp drwxr-xr-x 6 1003 1003 13240 Nov 30 14:39 dev drwxrwxr-x 8 root xorp 2760 Nov 30 14:41 etc drwxrwxr-x 10 root xorp 12848 Nov 29 21:33 lib -rw-r--r-- 1 root root 8453976 Nov 6 2013 lib.tar.gz drwxrwxr-x 3 505 506 224 Jul 2 2018 libexec lrwxrwxrwx 1 root root 11 Nov 29 21:33 linuxrc -> bin/busybox drwxrwxr-x 5 root xorp 352 Dec 27 2016 mnt drwxrwxr-x 2 root xorp 160 Dec 27 2016 opt drwxr-xr-x 9 root xorp 680 Nov 29 21:34 pica dr-xr-xr-x 81 root root 0 Jan 1 1970 proc drwxr-xr-x 2 root xorp 5168 Nov 29 21:34 sbin -rw-r--r-- 1 root root 268 Nov 30 14:41 snmpv3_boot_counter drwxr-xr-x 11 root root 0 Jan 1 1970 sys drwxrwxrwx 7 root xorp 140 Nov 30 14:41 tmp drwxr-xr-x 8 root xorp 544 Sep 5 2018 usr drwxrwxr-x 5 root xorp 416 Dec 27 2016 var XorPlus>
粉丝:7人 关注:2人
如硬件故障,请收集相关信息打400判断一下
不是H3C的
zhiliao_6YNMi 发表时间:2021-05-30
粉丝:124人 关注:6人
具体是什么型号的设备。
硬件故障的可咨询下400-810-0504开case协助处理。
软件版本文件丢失的,可在官网下载软件版本文件重新导入并引导看下是否能正常启动。
不是H3C的
wtchen 知了小白
这个应该是百度的交换机吧
正常应该是能设置的
