F100-C-G2防火墙
2021-05-31提问
  • 1收藏,883浏览
在web上新增一个公网地址,需要任何地方局域网能访问到这个IP地址所属的服务器,目前防火墙上已经有一个同网段的公网地址了,如何设置能将新的公网地址放行,本人萌新,请大佬们可以讲细致些,万分感谢
粉丝:125人 关注:6人
以下是防火墙将内网服务器映射到外网的参考案例:
组网说明:
本案例采用H3C HCL模拟器的F1060来模拟NAT server典型组网配置,内网和外网在网络拓扑图中已经有了明确的标识,FW1作为内网的出口设备,不仅保护内网的安全,也提供地址转换的服务。内网申请了202.1.100.2-202.1.100.3这两个公网地址,其中202.1.100.2用于FW1与外网互联使用。202.1.100.3用于给内网的WEB服务器转换并对外网提供WEB服务。由于模拟器及物理机的局限性,因此采用H3C HCL模拟器的S5820交换机开启WEB功能模拟成WEB服务器。
配置步骤
1、按照网络拓扑图正确配置IP地址
2、Web_server开启WEB功能,并创建相应账户及赋予权限
3、FW1配置NAT地址转换,并配置默认路由指向外网
4、FW1配置nat server,并发布内网的WEB服务器
配置关键点
Web_server:
<H3C>sys
[H3C]sysname web_server
[web_server]int gi 1/0/1
[web_server-GigabitEthernet1/0/1]port link-mode route
[web_server-GigabitEthernet1/0/1]des <connect to FW1>
[web_server-GigabitEthernet1/0/1]ip address 10.0.0.2 30
[web_server-GigabitEthernet1/0/1]quit
[web_server]ip route-static 0.0.0.0 0.0.0.0 10.0.0.1
[web_server]ip http enable
[web_server]ip https enable
[web_server]local-user admin
New local user added.
[web_server-luser-manage-admin]password simple admin
[web_server-luser-manage-admin]service-type http https
[web_server-luser-manage-admin]authorization-attribute user-role network-admin
[web_server-luser-manage-admin]quit
[web_server]
ISP:
<H3C>sys
[H3C]sysname ISP
[ISP]int gi 0/1
[ISP-GigabitEthernet0/1]ip address 202.103.224.254 24
[ISP-GigabitEthernet0/1]quit
[ISP]int gi 0/0
[ISP-GigabitEthernet0/0]des <connect to FW1>
[ISP-GigabitEthernet0/0]ip address 202.1.100.1 28
[ISP-GigabitEthernet0/0]quit
FW1:
<H3C>sys
[H3C]sysname FW1
[FW1]acl basic 2001
[FW1-acl-ipv4-basic-2001]rule 0 permit source any
[FW1-acl-ipv4-basic-2001]quit
[FW1]
[FW1]zone-pair security source trust destination untrust
[FW1-zone-pair-security-Trust-Untrust]packet-filter 2001
[FW1-zone-pair-security-Trust-Untrust]quit
[FW1]
[FW1]zone-pair security source untrust destination trust
[FW1-zone-pair-security-Untrust-Trust]packet-filter 2001
[FW1-zone-pair-security-Untrust-Trust]quit
[FW1]
[FW1]zone-pair security source trust destination local
[FW1-zone-pair-security-Trust-Local]packet-filter 2001
[FW1-zone-pair-security-Trust-Local]quit
[FW1]
[FW1]zone-pair security source local destination trust
[FW1-zone-pair-security-Local-Trust]packet-filter 2001
[FW1-zone-pair-security-Local-Trust]quit
[FW1]
[FW1]zone-pair security source untrust destination local
[FW1-zone-pair-security-Untrust-Local]packet-filter 2001
[FW1-zone-pair-security-Untrust-Local]quit
[FW1]
[FW1]zone-pair security source local destination untrust
[FW1-zone-pair-security-Local-Untrust]packet-filter 2001
[FW1-zone-pair-security-Local-Untrust]quit
[FW1]int gi 1/0/3
[FW1-GigabitEthernet1/0/3]des <connect to web_server>
[FW1-GigabitEthernet1/0/3]ip address 10.0.0.1 30
[FW1-GigabitEthernet1/0/3]quit
[FW1]security-zone name Trust
[FW1-security-zone-Trust]import interface GigabitEthernet 1/0/3
[FW1-security-zone-Trust]quit
FW1 NAT及NAT server关键配置点:
[FW1]acl basic 2000
[FW1-acl-ipv4-basic-2000]rule 0 permit source any
[FW1-acl-ipv4-basic-2000]quit
[FW1]int gi 1/0/4
[FW1-GigabitEthernet1/0/4]des <connect to ISP>
[FW1-GigabitEthernet1/0/4]ip address 202.1.100.2 28
[FW1-GigabitEthernet1/0/4]nat outbound 2000
[FW1-GigabitEthernet1/0/4]nat server protocol tcp global 202.1.100.3 80 inside 10.0.0.2 80
[FW1-GigabitEthernet1/0/4]nat server protocol tcp global 202.1.100.3 443 inside 10.0.0.2 443
[FW1-GigabitEthernet1/0/4]quit
[FW1]ip route-static 0.0.0.0 0.0.0.0 202.1.100.1
[FW1]security-zone name Untrust
[FW1-security-zone-Untrust]import interface GigabitEthernet 1/0/4
[FW1-security-zone-Untrust]quit
物理机填写IP地址:
物理机打开浏览器,输入网址:https://202.1.100.3 ,可以登陆到web服务器
输入用户名、密码,点击登录:
登陆成功:
查看FW1 NAT的显示信息:
[FW1]dis nat session verbose
Slot 1:
Total sessions found: 0
Slot 1:
Initiator:
  Source      IP/port: 202.103.224.68/50855
  Destination IP/port: 202.1.100.3/443
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/4
  Source security zone: Untrust
Responder:
  Source      IP/port: 10.0.0.2/443
  Destination IP/port: 202.103.224.68/50855
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/3
  Source security zone: Trust
State: TCP_ESTABLISHED
Application: HTTPS
Rule ID: 0
Rule name:
Start time: 2020-03-07 10:34:53  TTL: 596s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Initiator:
  Source      IP/port: 202.103.224.68/50853
  Protocol: TCP(6)
Responder:
  Destination IP/port: 202.103.224.68/50853
  Protocol: TCP(6)
Application: HTTPS
Rule ID: 0
Rule name:
Start time: 2020-03-07 10:34:52  TTL: 596s
Initiator:
  Source      IP/port: 202.103.224.68/50860
  Protocol: TCP(6)
Responder:
  Destination IP/port: 202.103.224.68/50860
  Protocol: TCP(6)
Application: HTTPS
Rule ID: 0
Rule name:
Initiator:
  Source      IP/port: 202.103.224.68/50852
  Protocol: TCP(6)
Responder:
  Destination IP/port: 202.103.224.68/50852
  Protocol: TCP(6)
Application: HTTPS
Rule ID: 0
Rule name:
Initiator:
  Source      IP/port: 202.103.224.68/50861
  Protocol: TCP(6)
Responder:
  Destination IP/port: 202.103.224.68/50861
  Protocol: TCP(6)
Application: HTTPS
Rule ID: 0
Rule name:
Start time: 2020-03-07 10:34:53  TTL: 597s
Initiator:
  Source      IP/port: 202.103.224.68/50859
  Protocol: TCP(6)
Responder:
  Destination IP/port: 202.103.224.68/50859
  Protocol: TCP(6)
Application: HTTPS
Rule ID: 0
Rule name:
Total sessions found: 6
谢谢老板,我借鉴下
zhiliao_iSDVl7 发表时间:2021-05-31
Xcheng 九段
粉丝:122人 关注:3人
感谢,我先看下
