V7 H3C level 级别
2021-06-01提问
  • 1收藏,1611浏览
V7版H3C交换机level 0-15分别是什么权限
<Sysname> display role
Role: network-admin
  Description: Predefined network admin role has access to all commands on the d
evice
  VLAN policy: permit (default)
  Interface policy: permit (default)
  VPN instance policy: permit (default)
  Rule    Perm   Type  Scope         Entity
  sys-1   permit       command       *
  sys-2   permit RWX   web-menu      -
  sys-3   permit RWX   xml-element   -
  sys-4   deny         command       display security-logfile summary
  sys-5   deny         command       system-view ; info-center securi
                                     ty-logfile directory *
  sys-6   deny         command       security-logfile save
  sys-7   permit RW-   oid           1
  R:Read W:Write X:Execute
Role: network-operator
  Description: Predefined network operator role has access to all read commands
on the device
  sys-1   permit       command       display *
  sys-2   permit       command       xml
  sys-3   permit       command       system-view ; probe ; display *
  sys-4   deny         command       display history-command all
  sys-5   deny         command       display exception *
  sys-6   deny         command       display cpu-usage configuration
  sys-7   deny         command       display kernel exception *
  sys-8   deny         command       display kernel deadloop *
  sys-9   deny         command       display kernel starvation *
  sys-10  deny         command       display kernel reboot *
  sys-11  deny         command       display memory trace *
  sys-12  deny         command       display kernel memory *
  sys-13  permit       command       system-view ; local-user *
  sys-14  permit       command       system-view ; switchto *
  sys-15  permit R--   web-menu      -
  sys-16  permit R--   xml-element   -
  sys-17  deny         command       display security-logfile summary
  sys-18  deny         command       system-view ; info-center securi
  sys-19  deny         command       security-logfile save
  sys-20  deny         command       system-view ; local-user-import
  sys-21  deny         command       system-view ; local-user-export
  sys-22  permit R--   oid           1
Role: mdc-admin
  Description: Predefined MDC admin role has access to all commands within an MD
C
  sys-4   deny   RWX   feature       mdc
  sys-5   deny   RWX   feature       install
  sys-6   deny   RWX   feature       irf
  sys-7   permit       command       display version *
  sys-8   permit       command       display copyright
  sys-9   permit       command       system-view ; probe ; display sy
                                     stem internal version *
  sys-13  deny   RWX   feature       vcf
  sys-14  deny   RWX   feature       smartmc
  sys-15  permit       command       display mdc *
  sys-19  deny         command       display security-logfile summary
  sys-20  deny         command       system-view ; info-center securi
  sys-21  deny         command       security-logfile save
  sys-22  permit RW-   oid           1
  sys-23  deny         command       display fips status
  sys-27  deny         command       display crypto version
  sys-30  deny         command       system-view ; fips mode enable
  sys-31  deny         command       system-view ; undo fips mode ena
                                     ble
  sys-37  deny         command       system-view ; max-ecmp-num *
  sys-38  deny         command       display max-ecmp-num
  sys-43  deny         command       system-view ; interface * ; usin
                                     g tengige *
  sys-44  deny         command       system-view ; interface * ; undo
                                      using tengige *
  sys-45  deny         command       system-view ; interface * ; usin
                                     g fortygige *
  sys-46  deny         command       system-view ; interface * ; undo
                                      using fortygige *
  sys-47  deny         command       system-view ; interface * ; usin
                                     g hundredgige *
  sys-48  deny         command       system-view ; interface * ; undo
                                      using hundredgige *
  sys-49  deny         command       system-view ; interface * ; usin
                                     g twentygige *
  sys-50  deny         command       system-view ; interface * ; undo
                                      using twentygige *
  sys-51  deny         command       system-view ; interface * ; usin
                                     g twenty-fivegige *
  sys-52  deny         command       system-view ; interface * ; undo
                                      using twenty-fivegige *
  sys-53  deny         command       system-view ; using hundredgige-
                                     from-fortygige *
  sys-55  deny         command       system-view ; using fortygige-fr
                                     om-hundredgige *
  sys-60  deny         command       system-view ; probe; display sys
                                     tem internal file *
  sys-61  deny         command       system-view ; probe; display sys
                                     tem internal hook *
  sys-62  deny         command       system-view ; probe; hook *
  sys-68  deny         command       system-view ; clock *
  sys-69  deny         command       system-view ; undo clock *
  sys-70  deny         command       system-view ; version check igno
                                     re
  sys-71  deny         command       system-view ; undo version check
                                      ignore
  sys-72  deny         command       system-view ; version auto-updat
                                     e enable
  sys-73  deny         command       system-view ; undo version auto-
                                     update enable
  sys-78  deny         command       system-view ; switch-fabric *
  sys-79  deny         command       system-view ; undo switch-fabric
  sys-80  deny         command       system-view ; fabric load-sharin
                                     g mode *
  sys-81  deny         command       system-view ; memory-threshold *
  sys-82  deny         command       system-view ; undo memory-thresh
                                     old *
  sys-88  deny         command       system-view ; password-recovery
                                     enable
  sys-89  deny         command       system-view ; undo password-reco
                                     very enable
  sys-98  deny         command       system-view ; monitor kernel *
  sys-99  deny         command       system-view ; undo monitor kerne
                                     l *
  sys-108 deny         command       system-view ; poe *
  sys-109 deny         command       system-view ; undo poe *
  sys-110 permit       command       system-view ; poe-profile *
  sys-111 permit       command       system-view ; undo poe-profile *
  sys-112 deny         command       system-view ; system-working-mod
                                     e *
  sys-113 deny         command       system-view ; undo system-workin
                                     g-mode
  sys-119 deny         command       system-view ; forward-path-detec
                                     tion enable
  sys-120 deny         command       system-view ; hardware-failure-d
                                     etection *
  sys-121 deny         command       system-view ; undo hardware-fail
                                     ure-detection *
  sys-122 deny         command       system-view ; forward-path-detec
                                     tion enable
  sys-123 deny         command       system-view ; undo forward-path-
                                     detection enable
  sys-124 deny         command       system-view ; hardware-failure-p
                                     rotection aggregation
  sys-125 deny         command       system-view ; undo hardware-fail
                                     ure-protection aggregation
  sys-127 deny         command       display debugging dev
  sys-128 deny         command       clock *
  sys-132 deny         command       display alarm *
  sys-138 deny         command       display hardware-failure-detecti
                                     on
  sys-141 deny         command       display memory-threshold *
  sys-142 deny         command       display power-supply *
  sys-145 deny         command       display system-working-mode
  sys-150 deny         command       display system stable state mdc
  sys-153 deny         command       restore factory-default
  sys-154 deny         command       reset scheduler logfile
  sys-155 deny         command       bootrom *
  sys-162 deny         command       display poe device
  sys-164 deny         command       display poe pse *
  sys-165 deny         command       display poe-power
  sys-167 deny         command       display kernel exception *
  sys-168 deny         command       display kernel deadloop *
  sys-169 deny         command       display kernel starvation *
  sys-170 deny         command       display kernel reboot *
  sys-171 deny         command       display kernel memory *
  sys-172 deny         command       kernel memory trace *
  sys-173 deny         command       undo kernel memory trace *
  sys-175 deny         command       reset kernel *
  sys-177 deny         command       reboot slot *
  sys-183 deny         command       format *
  sys-184 deny         command       mount *
  sys-185 deny         command       umount *
  sys-186 deny         command       fixdisk *
  sys-187 deny         command       fdisk *
Role: mdc-operator
  Description: Predefined MDC operator role has access to all read commands with
in an MDC
  sys-3   deny         command       display history-command all
  sys-4   deny         command       display exception *
  sys-5   deny         command       display cpu-usage configuration
  sys-6   deny         command       display kernel exception *
  sys-7   deny         command       display kernel deadloop *
  sys-8   deny         command       display kernel starvation *
  sys-9   deny         command       display kernel reboot *
  sys-10  deny         command       display memory trace *
  sys-11  deny         command       display kernel memory *
  sys-12  permit       command       system-view ; local-user *
  sys-20  permit R--   oid           1
  sys-21  deny         command       display alarm *
  sys-27  deny         command       display hardware-failure-detecti
                                     on
  sys-30  deny         command       display memory-threshold *
  sys-31  deny         command       display power-supply *
  sys-34  deny         command       display system-working-mode
  sys-39  deny         command       display system stable state mdc
  sys-44  deny         command       display poe device
  sys-46  deny         command       display poe pse *
  sys-47  deny         command       display poe-power *
  sys-49  deny         command       display smartmc *
Role: level-0
  Description: Predefined level-0 role
  sys-1   permit       command       tracert *
  sys-2   permit       command       telnet *
  sys-3   permit       command       ping *
  sys-4   permit       command       ssh2 *
  sys-5   permit       command       super *
  sys-6   permit       command       mtrace *
Role: level-1
  Description: Predefined level-1 role
  sys-5   permit       command       display *
  sys-6   permit       command       super *
  sys-7   deny         command       display history-command all
  sys-8   permit       command       mtrace *
Role: level-2
  Description: Predefined level-2 role
Role: level-3
  Description: Predefined level-3 role
Role: level-4
  Description: Predefined level-4 role
Role: level-5
  Description: Predefined level-5 role
Role: level-6
  Description: Predefined level-6 role
Role: level-7
  Description: Predefined level-7 role
Role: level-8
  Description: Predefined level-8 role
Role: level-9
  Description: Predefined level-9 role
  sys-1   permit RWX   feature       -
  sys-2   deny   RWX   feature       device
  sys-3   deny   RWX   feature       filesystem
  sys-4   permit       command       display *
  sys-5   deny         command       display history-command all
Role: level-10
  Description: Predefined level-10 role
Role: level-11
  Description: Predefined level-11 role
Role: level-12
  Description: Predefined level-12 role
Role: level-13
  Description: Predefined level-13 role
Role: level-14
  Description: Predefined level-14 role
Role: level-15
  Description: Predefined level-15 role
Role: security-audit
  Description: Predefined security audit role only has access to commands for th
e security log administrator
  sys-1   deny         command       *
  sys-2   permit       command       display security-logfile summary
  sys-3   permit       command       system-view ; info-center securi
  sys-4   permit       command       security-logfile save
  sys-5   permit       command       cd *
  sys-6   permit       command       copy *
  sys-7   permit       command       delete *
  sys-8   permit       command       dir *
  sys-9   permit       command       mkdir *
  sys-10  permit       command       more *
  sys-11  permit       command       move *
  sys-12  permit       command       rmdir *
  sys-13  permit       command       pwd
  sys-14  permit       command       rename *
  sys-15  permit       command       undelete *
  sys-16  permit       command       ftp *
  sys-17  permit       command       sftp *
Role: guest-manager
  Description: Predefined guest manager role can't access to commands
  sys-1   permit RWX   xml-element   useraccounts/approveguest/
  sys-2   permit RWX   xml-element   useraccounts/exportguestaccount/
  sys-3   permit RWX   xml-element   useraccounts/generateguestaccoun
                                     t/
  sys-4   permit RWX   xml-element   useraccounts/guest/
  sys-5   permit RWX   xml-element   useraccounts/guestconfigure/
  sys-6   permit RWX   xml-element   useraccounts/importguestaccount/
  sys-7   permit RWX   xml-element   useraccounts/exportguesttemplet/
  sys-8   permit RWX   xml-element   rpc/
  sys-9   deny         command       *
粉丝:22人 关注:1人
系统预定义的用户角色名和对应的权限
用户角色名
权限
可操作系统所有功能和资源(除安全日志文件管理相关命令display security-logfile summaryinfo-center security-logfile directorysecurity-logfile save之外)
·         可执行系统所有功能和资源的相关display命令(除display history-command alldisplay security-logfile summary等命令,具体请通过display role命令查看)
·         如果用户采用本地认证方式登录系统并被授予该角色,则可以修改自己的密码
·         可执行进入XML视图的命令
·         可允许用户操作所有读类型的XML元素
·         可允许用户操作所有读类型的OID
level-n (n = 015)
·         level-0:可执行命令pingtracertssh2telnetsuper,且管理员可以为其配置权限
·         level-1:具有level-0用户角色的权限,并且可执行系统所有功能和资源的相关display命令(除display history-command all之外),以及管理员可以为其配置权限
·         level-2level-8level-10level-14:无缺省权限,需要管理员为其配置权限
·         level-9:可操作系统中绝大多数的功能和所有的资源,且管理员可以为其配置权限,但不能操作display history-command all命令、RBAC的命令(Debug命令除外)、文件管理、设备管理以及本地用户特性。对于本地用户,若用户登录系统并被授予该角色,可以修改自己的密码
·         level-15:具有与network-admin角色相同的权限
security-audit
安全日志管理员,仅具有安全日志文件的读、写、执行权限,具体如下:
·         可执行安全日志文件管理相关的命令(display security-logfile summaryinfo-center security-logfile directorysecurity-logfile save)。安全日志文件管理相关命令的介绍,请参见“网络管理与监控”中的“信息中心”
·         可执行安全日志文件操作相关的命令,例如more显示安全日志文件内容;dirmkdir操作安全日志文件目录等,具体命令的介绍请参见“基础配置命令参考”中的“文件系统管理”
以上权限,仅安全日志管理员角色独有,其它任何角色均不具备
该角色不能被授权给从当前用户线登录系统的用户
feihuo 七段
粉丝:7人 关注:0人
可操作该MDC所有功能和资源(除安全日志文件管理相关命令display security-logfile summaryinfo-center security-logfile directorysecurity-logfile save之外),但不包括操作仅缺省MDC支持,非缺省MDC不支持的功能的权限
·         可执行该MDC所有功能和资源的相关display命令(除display history-command alldisplay security-logfile summary等命令,具体请通过display role命令查看),但不包括仅缺省MDC支持,非缺省MDC不支持的功能的相关display命令的执行权限
·         可执行进入XML视图的命令
·         可允许用户操作所有读类型的Web菜单选项
·         可允许用户操作所有读类型的OID
level-n (n = 0~15)
·         level-2~level-8和level-10~level-14:无缺省权限,需要管理员为其配置权限
·         level-9:可操作系统中绝大多数的功能和所有的资源,且管理员可以为其配置权限,但不能操作display history-command all命令、RBAC的命令(Debug命令除外)、MDC、文件管理、设备管理以及本地用户特性。对于本地用户,若用户登录系统并被授予该角色,可以修改自己的密码
·         level-15:在缺省MDC中,具有与network-admin角色相同的权限;在非缺省MDC中,具有与mdc-admin角色相同的权限
security-audit
guest-manager
来宾用户管理员,只能查看和配置与来宾有关的web页面,没有控制命令行的权限
02-RBAC配置-新华三集团-H3C
