SR8806-X-S 连接运营商线路不通,过交换机后通
2018-06-07提问
  • 1收藏,1458浏览
SR8806-X-S使用MIC-GP4L子卡双绞线连接联通线路:
线路1:历史遗留,联通网线到弱电井,弱电井使用百兆光纤收发器转光纤到机房,再使用光纤收发器转网线接SR8806,不通。
线路2:16年开通,联通光缆到机房,光猫转网线,接入SR8806,不通。
线路3:18年开通,联通光缆到机房,光猫转网线,光猫型号与线路2所用型号不同,接入SR8806,可以上网。
已尝试手段:手动配置路由器前两条线路的接口速度等信息,不成功。
目前的解决方案:线路1和线路2随便找个交换机接入(仅配置了两对直通vlan其他不做配置),再从交换机接出来接入SR8806,可正常使用。
SR8806-X-S Version 7.1.048
SPEX-1204
MIC-GP4L
粉丝:13人 关注:4人
路由器上做了啥业务?纯转发吗?二层还是三层,路由协议是用的啥
目前仅做nat转换,没做其他业务
小白要努力 发表时间:2018-06-07
粉丝:10人 关注:1人
有没有观察过接口的双工状态?协商出来的是全双工还是半双工?
[Server_SW]dis int ten 1/0/1 Ten-GigabitEthernet1/0/1 Current state: UP Line protocol state: UP IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 741f-4a9f-f8f7 Description: Ten-GigabitEthernet1/0/1 Interface Bandwidth: 100000kbps Loopback is not set Media type is twisted pair Port hardware type is 10G_BASE_TX 100Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 10000 Allow jumbo frame to pass Broadcast MAX-ratio: 100% Multicast MAX-ratio: 100% Unicast MAX-ratio: 100% PVID: 4001 Mdi type: automdix Port link-type: access Tagged Vlan: none UnTagged Vlan: 4001 Port priority: 0 [Server_SW]dis int ten 1/0/3 Ten-GigabitEthernet1/0/3 Current state: UP Line protocol state: UP IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 741f-4a9f-f8f9 Description: Ten-GigabitEthernet1/0/3 Interface Bandwidth: 100000kbps Loopback is not set Media type is twisted pair Port hardware type is 10G_BASE_TX 100Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled The Maximum Frame Length is 10000 Allow jumbo frame to pass Broadcast MAX-ratio: 100% Multicast MAX-ratio: 100% Unicast MAX-ratio: 100% PVID: 4002 Mdi type: automdix Port link-type: access Tagged Vlan: none UnTagged Vlan: 4002 Port priority: 0 双工的
抱歉,贴出来换行怎么没有了,双工的
