ipsec vpn 野蛮模式下。ipsec 策略必须配置策略模板吗?
2021-06-07提问
  • 2收藏,1758浏览
粉丝:0人 关注:8人
一开始是直接在R1上配置ipsec policy 3 1 isakmp。R3作为分支pingR1。第一阶段协商成功。第二阶段协商是提示Failed to get IPsec policy for phase 2 responder. Delete IPsec SA.Failed to negotiate IPsec SA。
之后我删除了ipsec policy 3 1 isakmp。重新配置了ipsec 策略模板。在配置IPSec policy 3 1 isakmp temple 3。然后就建立成功了。
所以野蛮模式是必须得配置策略模板吗。
设置列表
  • 有序列表
  • 无序列表
R1:
ipsec transform-set 3
 esp encryption-algorithm des-cbc
 esp authentication-algorithm md5
 transform-set 3
 security acl 3001
 local-address 10.0.0.1
 ike-profile 3
 ike identity fqdn 1
ike profile 3
 keychain 3
 exchange-mode aggressive
 match remote identity fqdn 3
 proposal 1
 ike proposal 1
ike keychain 3
 pre-shared-key hostname 3 key cipher $c$3$uGrkdp/wFj2Qf9Vrb1PqnNFqy8g9kA==
R3:
ipsec transform-set 1
ipsec policy 1 1 isakmp
 transform-set 1
 security acl 3001
 remote-address 10.0.0.1
 ike-profile 1
 ike identity fqdn 3
 ike profile 1
 keychain 1
 match remote identity fqdn 1
 proposal 1
ike proposal 1
ike keychain 1
 pre-shared-key address 10.0.0.1 255.255.255.0 key cipher $c$3$WOPp4+LWsAySfFNfgarhpG2WHMl8Rg==
粉丝:125人 关注:6人
配置IPSEC VPN野蛮模式需要模板,以下是配置案例,请参考:
组网说明:
本案例采用H3C HCL模拟器的F1060防火墙来模拟IPSEC+IKE野蛮模式的典型组网配置。在网络拓扑图中存在子网1和子网2.为了保障子网1和子网2相互传输数据的安全性,因此需要在FW1与FW2采用建立IPSEC VPN隧道,由于FW1的出接口地址不固定,因此采用IKE野蛮模式。
配置步骤
1、按照网络拓扑图正确配置IP地址
2、FW1与FW2的互联接口加入安全域,并放通域间策略
3、FW1与FW2建立IPSEC VPN隧道,采用IKE野蛮模式
配置关键点
ISP:
sys
[H3C]sysname ISP
[ISP]int gi 0/0
[ISP-GigabitEthernet0/0]des
[ISP-GigabitEthernet0/0]ip address 202.1.100.1 24
[ISP-GigabitEthernet0/0]dhcp server apply ip-pool 1
[ISP-GigabitEthernet0/0]quit
[ISP]int gi 0/1
[ISP-GigabitEthernet0/1]des
[ISP-GigabitEthernet0/1]ip address 202.2.100.1 30
[ISP-GigabitEthernet0/1]quit
[ISP]ip route-static 192.168.1.0 255.255.255.0 202.1.100.2
[ISP]ip route-static 172.16.1.0 255.255.255.0 202.2.100.2
[ISP]dhcp enable
[ISP]dhcp server ip-pool 1
[ISP-dhcp-pool-1]network 202.1.100.0 mask 255.255.255.0
[ISP-dhcp-pool-1]gateway-list 202.1.100.1
[ISP-dhcp-pool-1]quit
FW1:
sys
[H3C]sysname FW1
[FW1]int gi 1/0/3
[FW1-GigabitEthernet1/0/3]ip address 192.168.1.1 24
[FW1-GigabitEthernet1/0/3]quit
[FW1]int gi 1/0/2
[FW1-GigabitEthernet1/0/2]des
[FW1-GigabitEthernet1/0/2]ip address dhcp-alloc
[FW1-GigabitEthernet1/0/2]quit
[FW1]ip route-static 0.0.0.0 0.0.0.0 202.1.100.1
[FW1]security-zone name Trust
[FW1-security-zone-Trust]import interface GigabitEthernet 1/0/3
[FW1-security-zone-Trust]quit
[FW1]security-zone name Untrust
[FW1-security-zone-Untrust]import interface GigabitEthernet 1/0/2
[FW1-security-zone-Untrust]quit
[FW1]acl basic 2001
[FW1-acl-ipv4-basic-2001]rule 0 permit source any
[FW1-acl-ipv4-basic-2001]quit
[FW1]
[FW1]zone-pair security source trust destination untrust
[FW1-zone-pair-security-Trust-Untrust]packet-filter 2001
[FW1-zone-pair-security-Trust-Untrust]quit
[FW1]
[FW1]zone-pair security source untrust destination trust
[FW1-zone-pair-security-Untrust-Trust]packet-filter 2001
[FW1-zone-pair-security-Untrust-Trust]quit
[FW1]
[FW1]zone-pair security source trust destination local
[FW1-zone-pair-security-Trust-Local]packet-filter 2001
[FW1-zone-pair-security-Trust-Local]quit
[FW1]
[FW1]zone-pair security source local destination trust
[FW1-zone-pair-security-Local-Trust]packet-filter 2001
[FW1-zone-pair-security-Local-Trust]quit
[FW1]
[FW1]zone-pair security source untrust destination local
[FW1-zone-pair-security-Untrust-Local]packet-filter 2001
[FW1-zone-pair-security-Untrust-Local]quit
[FW1]
[FW1]zone-pair security source local destination untrust
[FW1-zone-pair-security-Local-Untrust]packet-filter 2001
[FW1-zone-pair-security-Local-Untrust]quit
FW1 IPSEC+IKE野蛮模式关键配置点:
[FW1]acl advanced 3000
[FW1-acl-ipv4-adv-3000]rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 172.16.1.0 0.0.0.255
[FW1-acl-ipv4-adv-3000]quit
[FW1]ike identity fqdn fw1
[FW1]ike keychain james
[FW1-ike-keychain-james]pre-shared-key address 202.2.100.2 255.255.255.252 key simple james
[FW1-ike-keychain-james]quit
[FW1]ike proposal 1
[FW1-ike-proposal-1]quit
[FW1]ike profile james
[FW1-ike-profile-james]keychain james
[FW1-ike-profile-james]proposal 1
[FW1-ike-profile-james]match remote identity address 202.2.100.2 255.255.255.252
[FW1-ike-profile-james]exchange-mode aggressive
[FW1-ike-profile-james]quit
[FW1]ipsec transform-set james
[FW1-ipsec-transform-set-james]protocol esp
[FW1-ipsec-transform-set-james]encapsulation-mode tunnel
[FW1-ipsec-transform-set-james]esp authentication-algorithm md5
[FW1-ipsec-transform-set-james]esp encryption-algorithm des-cbc
[FW1-ipsec-transform-set-james]quit
[FW1]ipsec policy james 1 isakmp
[FW1-ipsec-policy-isakmp-james-1]security acl 3000
[FW1-ipsec-policy-isakmp-james-1]transform-set james
[FW1-ipsec-policy-isakmp-james-1]ike-profile james
[FW1-ipsec-policy-isakmp-james-1]remote-address 202.2.100.2
[FW1-ipsec-policy-isakmp-james-1]quit
[FW1]int gi 1/0/2
[FW1-GigabitEthernet1/0/2]ipsec apply policy james
FW2:
sys
[H3C]sysname FW2
[FW2]int gi 1/0/3
[FW2-GigabitEthernet1/0/3]ip address 172.16.1.1 24
[FW2-GigabitEthernet1/0/3]quit
[FW2]int gi 1/0/2
[FW2-GigabitEthernet1/0/2]des
[FW2-GigabitEthernet1/0/2]ip address 202.2.100.2 30
[FW2-GigabitEthernet1/0/2]quit
[FW2]ip route-static 0.0.0.0 0.0.0.0 202.2.100.1
[FW2]security-zone name Untrust
[FW2-security-zone-Untrust]import interface GigabitEthernet 1/0/2
[FW2-security-zone-Untrust]quit
[FW2]security-zone name Trust
[FW2-security-zone-Trust]import interface GigabitEthernet 1/0/3
[FW2-security-zone-Trust]quit
[FW2]zone-pair security source trust destination untrust
[FW2-zone-pair-security-Trust-Untrust]packet-filter 2001
[FW2-zone-pair-security-Trust-Untrust]quit
[FW2]
[FW2]zone-pair security source untrust destination trust
[FW2-zone-pair-security-Untrust-Trust]packet-filter 2001
[FW2-zone-pair-security-Untrust-Trust]quit
[FW2]
[FW2]zone-pair security source trust destination local
[FW2-zone-pair-security-Trust-Local]packet-filter 2001
[FW2-zone-pair-security-Trust-Local]quit
[FW2]
[FW2]zone-pair security source local destination trust
[FW2-zone-pair-security-Local-Trust]packet-filter 2001
[FW2-zone-pair-security-Local-Trust]quit
[FW2]
[FW2]zone-pair security source untrust destination local
[FW2-zone-pair-security-Untrust-Local]packet-filter 2001
[FW2-zone-pair-security-Untrust-Local]quit
[FW2]
[FW2]zone-pair security source local destination untrust
[FW2-zone-pair-security-Local-Untrust]packet-filter 2001
[FW2-zone-pair-security-Local-Untrust]quit
FW2 IPSEC+IKE野蛮模式关键配置点:
[FW2]acl advanced 3000
[FW2-acl-ipv4-adv-3000]rule 0 permit ip source 172.16.1.0 0.0.0.255 destination 192.168.1.0 0.0.0.255
[FW2-acl-ipv4-adv-3000]quit
[FW2]ike identity fqdn fw2
[FW2]ike proposal 1
[FW2-ike-proposal-1]quit
[FW2]ike keychain james
[FW2-ike-keychain-james]pre-shared-key hostname fw1 key simple james
[FW2-ike-keychain-james]quit
[FW2]ike profile james
[FW2-ike-profile-james]keychain james
[FW2-ike-profile-james]proposal 1
[FW2-ike-profile-james]match remote identity fqdn fw1
[FW2-ike-profile-james]exchange-mode aggressive
[FW2-ike-profile-james]quit
[FW2]ipsec transform-set james
[FW2-ipsec-transform-set-james]protocol esp
[FW2-ipsec-transform-set-james]encapsulation-mode tunnel
[FW2-ipsec-transform-set-james]esp authentication-algorithm md5
[FW2-ipsec-transform-set-james]esp encryption-algorithm des-cbc
[FW2-ipsec-transform-set-james]quit
[FW2]ipsec policy-template james 1
[FW2-ipsec-policy-template-james-1]security acl 3000
[FW2-ipsec-policy-template-james-1]transform-set james
[FW2-ipsec-policy-template-james-1]ike-profile james
[FW2-ipsec-policy-template-james-1]quit
[FW2]ipsec policy james 1 isakmp template james
[FW2]int gi 1/0/2
[FW2-GigabitEthernet1/0/2]ipsec apply policy james
测试:
物理机都填写IP地址:
PC之间可以相互PING通:
查看FW1的IPSEC显示信息:
查看FW1出接口配置及获取到的IP地址:
查看ISP DHCP分配出去的地址:
查看FW2的IPSEC显示信息:
