4320i acn v7转v5bin升级失败
2021-06-11提问
  • 1收藏,516浏览
请教各位:V7转V5升级BIN版本时在第二次更新BIN版本,Server IP Address :自动打出了192.168.1.1,我网卡设置了192.168.0.1,所以在后面输入了192.168.0.1,Local IP Address :自动打印192.168.1.253,我在后输入了192.168.0.19,更新不成功,请问要如何解决?谢谢! ==================================================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name :host :wa4300-fat.bin Target File Name :target :wa4300-fat.bin Server IP Address :192.168.1.1 :192.168.0.1 Local IP Address :192.168.1.253 :192.168.0.19 Gateway IP Address :0.0.0.0 BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300_fit.bin! The main application file does not exist--flash:/wa4300_fit.bin! Starting to get the backup application file--flash:/backup.bin! The backup application file does not exist--flash:/backup.bin! Starting to get the secure application file--flash:/secure.bin!
***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 7.13 ** *****************************************************************************Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.Compiled Date : Feb 27 2019CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : DDR2 SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to access EXTENDED-BOOTWARE MENU...Password recovery capability is enabled.Note: The current operating device is flashEnter < Storage Device Operation > to select device.====================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Skip Authentication for Console Login ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+Z: Access EXTENDED ASSISTANT MENUCtrl+F: Format File SystemCtrl+C: Display CopyrightEnter your choice(0-9): Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y...................................................................................................Format success.====================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Skip Authentication for Console Login ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+Z: Access EXTENDED ASSISTANT MENUCtrl+F: Format File SystemCtrl+C: Display CopyrightEnter your choice(0-9): 3====================================================|Note:the operating device is flash ||<1> Download Image Program To SDRAM And Run ||<2> Update Main Image File ||<3> Update Backup Image File ||<4> Download Files(*.*) ||<5> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-5): 5====================================================|Note: '.' = Clear field. || '-' = Go to previous field. || Ctrl+D = Quit. |============================================================================Protocol (FTP or TFTP) :tftp Load File Name :wa4300-fat.bin :Target File Name :wa4300-fat.bin :Server IP Address :192.168.0.1 Local IP Address :192.168.0.19 Subnet Mask :255.255.255.0 Gateway IP Address :0.0.0.0 ====================================================|Note:the operating device is flash ||<1> Download Image Program To SDRAM And Run ||<2> Update Main Image File ||<3> Update Backup Image File ||<4> Download Files(*.*) ||<5> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-5): 1Loading............................................................................................................................................................................................................................Done.11120640 bytes downloaded!Extended BootWare Version is not equal,updating? [Y/N]Updating Extended BootWare..........Done.BootWare updated,System is rebooting now.System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing...............................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 1.17 ** *****************************************************************************Copyright (c) 2004-2020 New H3C Technologies Co., Ltd.Compiled Date : Apr 14 2020CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CRead net params from bootrom failed, use the default valueBootWare Validating...Press Ctrl+B to enter extended boot menu...Starting to get the main application file--flash:/wa4300_fit.bin!The main application file does not exist--flash:/wa4300_fit.bin!Starting to get the backup application file--flash:/backup.bin!The backup application file does not exist--flash:/backup.bin!Starting to get the secure application file--flash:/secure.bin!The secure application file does not exist--flash:/secure.bin!Booting App fails!Trying to get the IP address from the DHCP server......Getting IP Address Failed, the system will reboot. [State : Idle] Reset request, rebooting the APRebooting......System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing...............................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 1.17 ** *****************************************************************************Copyright (c) 2004-2020 New H3C Technologies Co., Ltd.Compiled Date : Apr 14 2020CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to enter extended boot menu...BootWare password: Not required. Please press Enter to continue.Password recovery capability is enabled.Note: The current operating device is flashEnter < Storage Device Operation > to select device.======================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Clear Super Password ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+C: Display CopyrightCtrl+Y: Change AP ModeCtrl+F: Format File SystemEnter your choice(0-9): Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y...................................................................................................Format success.======================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Clear Super Password ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+C: Display CopyrightCtrl+Y: Change AP ModeCtrl+F: Format File SystemEnter your choice(0-9): 3====================================================|Note:the operating device is flash ||<1> Download Application Program To SDRAM And Run ||<2> Update Main Application File ||<3> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-3): 3====================================================|Note: '.' = Clear field. || '-' = Go to previous field. || Ctrl+D = Quit. |============================================================================Protocol (FTP or TFTP) :tftp Load File Name :host :wa4300-fat.binTarget File Name :target :wa4300-fat.binServer IP Address :192.168.1.1 192.168.0.1Local IP Address :192.168.1.253 192.168.0.19Gateway IP Address :0.0.0.0 ====================================================|Note:the operating device is flash ||<1> Download Application Program To SDRAM And Run ||<2> Update Main Application File ||<3> Modify Ethernet Parameter ||<0> Exit To Main Menu || |============================================================================Enter your choice(0-3): 0======================================================|<1> Boot System ||<2> Enter Serial SubMenu ||<3> Enter Ethernet SubMenu ||<4> File Control ||<5> Restore to Factory Default Configuration ||<6> Skip Current System Configuration ||<7> BootWare Operation Menu ||<8> Clear Super Password ||<9> Storage Device Operation ||<0> Reboot |============================================================================Ctrl+C: Display CopyrightCtrl+Y: Change AP ModeCtrl+F: Format File SystemEnter your choice(0-9): 0System is starting...Press Ctrl+D to access BASIC-BOOTWARE MENUBooting Normal Extend BootWareThe Extend BootWare is self-decompressing...............................Done!***************************************************************************** ** H3C WA4320i-ACN BootWare, Version 1.17 ** *****************************************************************************Copyright (c) 2004-2020 New H3C Technologies Co., Ltd.Compiled Date : Apr 14 2020CPU Type : ATHEROS AR9550CPU L1 Cache : 32KBCPU Clock Speed : 720MHzMemory Type : SDRAMMemory Size : 256MBMemory Speed : 560MHzBootWare Size : 512KBFlash Size : 32MBCPLD Version : 006PCB Version : Ver.CBootWare Validating...Press Ctrl+B to enter extended boot menu...Starting to get the main application file--flash:/wa4300_fit.bin!The main application file does not exist--flash:/wa4300_fit.bin!Starting to get the backup application file--flash:/backup.bin!The backup application file does not exist--flash:/backup.bin!Starting to get the secure application file--flash:/secure.bin!The secure application file does not exist--flash:/secure.bin!Booting App fails!Trying to get the IP address from the DHCP server......
粉丝:16人 关注:9人
报错下载的文件不存在,检查一下电脑上 tftp路径下是否存在 wa4300-fat.bin  文件
粉丝:144人 关注:1人
联系400处理下
zhiliao_Qqacjx 知了小白
