第二阶段协商不起来
2021-06-12提问
  • 1收藏,822浏览
设置列表
  • 有序列表
  • 无序列表
V5版本和V7版本对接IPsec VPN ,有IKE SA 没有ipsec sa ,是V5和V7对接有什么需要特比注意的配置吗
粉丝:17人 关注:2人
可参考如下案例检查下配置:
客户现场有多个分支,为了实现总部与分支之间互通,且要确保数据传递的安全性,总部分支之间需要使用ipsec对数据进行加密。由于存在多个分支,为了实现总部配置的简洁性,总部采用模板方式。用设备的loopback地址模拟内网PC
1 步:总部路由器配置
 ike proposal 1   //配置ike  proposal
 encryption-algorithm 3des-cbc
 dh group2
authentication-algorithm md5
ike keychain 1  //创建ike keychain,匹配分支1地址
pre-shared-key address 10.88.142.120 255.255.255.255 key simple 123
ike keychain 2  //创建ike keychain,匹配分支2地址
 pre-shared-key address 10.88.142.121 255.255.255.255 key  simple 123
ike profile 1  //创建ike proflle,关联keychain 1
 keychain 1
 local-identity address 10.153.42.93
 match remote identity address 10.88.142.120 255.255.255.255
 proposal 1
ike profile 2   //创建ike proflle,关联keychain 2
 keychain 2
 match remote identity address 10.88.142.121 255.255.255.255
 proposal 1
ipsec transform-set 1    //配置ipsec安全提议
 encapsulation-mode tunnel
 transform esp
 esp authentication-algorithm md5
 esp encryption-algorithm 3des
ipsec policy-template fz 1  //创建分支模板1
 transform-set 1
 local-address 10.153.42.93
 remote-address 10.88.142.120
 ike-profile 1
ipsec policy-template fz 2  //创建分支模板2
 transform-set 1
 remote-address 10.88.142.121
 ike-profile 2
ipsec policy aaa 1 isakmp template  fz   //创建ipsec策略模板
interface LoopBack0   //配置测试地址
 ip address 1.1.1.1  255.255.255.255
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 10.153.42.93 255.255.255.0
 ipsec apply policy aaa
2 步:分支1V7)路由器配置
acl advanced 3210   //创建ipsec感兴趣流
 rule 0 permit ip source 3.3.3.3  0 destination 1.1.1.1 0
ike keychain 2   //创建ike keychain,指向总部ip地址
 pre-shared-key address 10.153.42.93 255.255.255.255 key simple 123
ike proposal 1   //创建ike proposal
 dh group2
ike profile 1   //创建ike profile,关联ike keychainproposal
 keychain 1
 local-identity address 10.88.142.121  //指本端地址用local-identity address,不要使用match local address
 match remote identity address 10.153.42.93 255.255.255.255
 proposal 1
ipsec transform-set 1   //创建ipsec安全提议
 esp encryption-algorithm 3des-cbc
ipsec policy aaa 1 isakmp     //创建ipsec策略
 transform-set 1
 security acl 3210
 local-address 10.88.142.121
 remote-address 10.153.42.93
 ike-profile 1
 ip address  3.3.3.3  255.255.255.255
interface GigabitEthernet2/0/0   //公网口下发ipsec策略
ip address 10.88.142.121 255.255.255.0
3 步:分支2V5)路由器配置
acl number 3210   //配置ipsec感兴趣流
 rule 0 permit ip source 2.2.2.2  0 destination 1.1.1.1 0
ike proposal 1   //配置ipsec proposal
 dh group2
ike peer 1     //配置ike 对等体
 proposal 1
 pre-shared-key simple 123
 transform esp
ipsec policy aaa 1 isakmp   //配置ipsec策略
 security acl 3210
 ike-peer 1
 transform-set 1
 ip address 2.2.2.2  255.255.255.255
interface GigabitEthernet3/0/0    //公网口下发ipsec策略
 ip address 10.88.142.120  255.255.255.0
 ipsec policy aaa
4 步:分支1与总部互通测试
<FZ1>ping -a 3.3.3.3 2.2.2.2
Ping 2.2.2.2 (2.2.2.2) from 3.3.3.3: 56 data bytes, press CTRL_C to break
56 bytes from 2.2.2.2: icmp_seq=0 ttl=255 time=0.290 ms
56 bytes from 2.2.2.2: icmp_seq=1 ttl=255 time=0.170 ms
56 bytes from 2.2.2.2: icmp_seq=2 ttl=255 time=0.182 ms
56 bytes from 2.2.2.2: icmp_seq=3 ttl=255 time=0.144 ms
56 bytes from 2.2.2.2: icmp_seq=4 ttl=255 time=0.140 ms
--- Ping statistics for 2.2.2.2 ---
round-trip min/avg/max/std-dev = 0.140/0.185/0.290/0.055 ms
[FZ1]dis ike sa
    Connection-ID   Remote                Flag         DOI
    24              10.153.42.93          RD           IPsec
Flags:
RD--READY RL--REPLACED FD-FADING
<FZ1>dis ipsec sa
Interface: GigabitEthernet2/0/0
  IPsec policy: aaa
  Sequence number: 2
  Mode: ISAKMP
    Tunnel id: 0
    Encapsulation mode: tunnel
    Perfect Forward Secrecy:
    Inside VPN:
    Extended Sequence Numbers enable: N
    Traffic Flow Confidentiality enable: N
    Path MTU: 1444
    Tunnel:
        local  address: 10.88.142.121
        remote address: 10.153.42.93
    Flow:
        sour addr: 3.3.3.3/255.255.255.255  port: 0  protocol: ip
        dest addr: 1.1.1.1/255.255.255.255  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 3934162279 (0xea7e8d67)
      Connection ID: 115964116993
      Transform set: ESP-ENCRYPT-3DES-CBC ESP-AUTH-MD5
      SA duration (kilobytes/sec): 1843200/3600
      SA remaining duration (kilobytes/sec): 1843199/2397
      Max received sequence-number: 4
      Anti-replay check enable: Y
      Anti-replay window size: 64
      UDP encapsulation used for NAT traversal: N
      Status: Active
    [Outbound ESP SAs]
      SPI: 2922365795 (0xae2fc363)
      Connection ID: 158913789952
      Max sent sequence-number: 4
      Status: Active
5 步:分支2与总部互通测试
<FZ2> PING 1.1.1.1: 56  data bytes, press CTRL_C to break
    Request time out
    Reply from 1.1.1.1: bytes=56 Sequence=1 ttl=255 time=35 ms
    Reply from 1.1.1.1: bytes=56 Sequence=2 ttl=255 time=47 ms
    Reply from 1.1.1.1: bytes=56 Sequence=3 ttl=255 time=35 ms
    Reply from 1.1.1.1: bytes=56 Sequence=4 ttl=255 time=35 ms
  --- 1.1.1.1 ping statistics ---
    5 packet(s) transmitted
    4 packet(s) received
    20.00% packet loss
    round-trip min/avg/max = 35/38/47 ms
<FZ2X>dis ike sa
    total phase-1 SAs:  1
    connection-id  peer                    flag        phase   doi
     7             10.153.42.93            RD|ST       1       IPSEC
     8             10.153.42.93            RD|ST       2       IPSEC
  flag meaning
  RD--READY ST--STAYALIVE RL--REPLACED FD--FADING TO--TIMEOUT RK—REKEY
<FZ2>dis ipsec sa
Interface: GigabitEthernet3/0/0
    path MTU: 1500
  IPsec policy name: "aaa"
  sequence number: 1
  acl version: ACL4
  mode: isakmp
    PFS: N, DH group: none
    tunnel:
        local  address: 10.88.142.120
    flow:
        sour addr: 2.2.2.2/255.255.255.255  port: 0  protocol: IP
        dest addr: 1.1.1.1/255.255.255.255  port: 0  protocol: IP
    [inbound ESP SAs]
      spi: 0x1FFC45F4(536626676)
      transform: ESP-ENCRYPT-3DES ESP-AUTH-MD5
      in use setting: Tunnel
      connection id: 7
      sa duration (kilobytes/sec): 1843200/3600
      sa remaining duration (kilobytes/sec): 1843199/3560
      anti-replay detection: Enabled
        anti-replay window size(counter based): 32
      udp encapsulation used for nat traversal: N
    [outbound ESP SAs]
      spi: 0x201F0CBD(538905789)
      connection id: 8
6 步:总部ikeipsec sa建立情况
<H3C>dis ike sa
    45              10.88.142.120         RD           IPsec
    44              10.88.142.121         RD           IPsec
Flags:
<H3C>dis ipsec sa
Interface: GigabitEthernet0/0
  IPsec policy: aaa
  Sequence number: 1
  Mode: Template
    Tunnel id: 1
    Inside VPN:
    Path MTU: 1444
    Tunnel:
        local  address: 10.153.42.93
        remote address: 10.88.142.120
    Flow:
        sour addr: 1.1.1.1/255.255.255.255  port: 0  protocol: ip
        dest addr: 2.2.2.2/255.255.255.255  port: 0  protocol: ip
    [Inbound ESP SAs]
      SPI: 538905789 (0x201f0cbd)
      Connection ID: 55834574850
      SA remaining duration (kilobytes/sec): 1843199/3435
      Status: Active
    [Outbound ESP SAs]
      SPI: 536626676 (0x1ffc45f4)
      Connection ID: 47244640259
      Status: Active
  IPsec policy: aaa
  Sequence number: 1
  Mode: Template
    Tunnel id: 0
    Inside VPN:
    Path MTU: 1444
    Tunnel:
        remote address: 10.88.142.121
    Flow:
        dest addr: 3.3.3.3/255.255.255.255  port: 0  protocol: ip
    [Inbound ESP SAs]
      Connection ID: 73014444033
      SA remaining duration (kilobytes/sec): 1843199/2146
      Status: Active
    [Outbound ESP SAs]
      Connection ID: 73014444032
      Status: Active
粉丝:124人 关注:6人
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
