路由器启动不了?
2021-06-12提问
  • 1收藏,1307浏览
路由器启动不了
粉丝:17人 关注:2人
软件版本丢失了,需要重新导入版本,方法如下:
2、     Bootrom菜单下升级
21  TFTP方式升级
1)PC上搭建TFTP Sever服务器
注意:一定要选择正确的路径,目录不要太深,不要有中文或特殊字符,否则可能识别不了。
2)使用CRT软件以console口(pc的串口连接到设备的console口)登录到设备,配置串口的相关参数:
重启设备
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Do you want to check SDRAM? [Y/N]
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing....Done.
*                  H3C MSR26-30 BootWare, Version 1.43                     *
Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Jun 17 2014
CPU ID              : 0x1
Memory Type         : DDR3 SDRAM
Memory Size         : 1024MB
Flash Size          : 2MB
Nand Flash size     : 256MB
CPLD Version        : 2.0
PCB Version         : 3.0
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
3必须在出现“Press Ctrl-B to enter Boot Menu...”的2秒钟之内,键入<Ctrl+B>,才能进入BOOT菜单,否则系统将进入程序解压过程;若程序进入解压过程后再希望进入BOOT菜单,则需要重新启动设备。
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 3
4) 进入BOOT菜单后,键入“3后回车,进入以太网子菜单。
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 5
5) 键入“5后回车,选择TFTP方式参数设置
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :tftp             tftp
Load File Name         :MSR26-CMW710-R0106P08.IPE
                       :             MSR26-CMW710-R0106P11.IPE
Target File Name       :main.ipe
                       :boot-tftp.ipe
Server IP Address      :192.168.10.1     192.168.1.2
Local IP Address       :192.168.10.2     192.168.1.1
Subnet Mask            :255.255.255.0   255.255.255.0
Gateway IP Address     :0.0.0.0
6)输入升级的文件名(含后缀),输入服务器地址,本地地址和网关。
Enter your choice(0-5): 2
7键入“2”,更新系统主镜像文件
Loading..................................................................... ............................................................................ .....................................................Done.
60637184 bytes downloaded!
Image file msr26-cmw710-boot-r0106p11.bin is self-decompressing...
Saving file flash:/msr26-cmw710-boot-r0106p11.bin .......................
Done.
Image file msr26-cmw710-system-r0106p11.bin is self-decompressing...
Saving file flash:/msr26-cmw710-system-r0106p11.bin ........................
Image file msr26-cmw710-security-r0106p11.bin is self-decompressing...
Saving file flash:/msr26-cmw710-security-r0106p11.bin ..Done.
Image file msr26-cmw710-voice-r0106p11.bin is self-decompressing...
Saving file flash:/msr26-cmw710-voice-r0106p11.bin .....Done.
Image file msr26-cmw710-data-r0106p11.bin is self-decompressing...
Saving file flash:/msr26-cmw710-data-r0106p11.bin .......Done.
Enter your choice(0-5): 0
8键入“0”,返回主菜单
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
======================================================================Ctrl+Z: Access EXTENDED ASSISTANT MENU
Enter your choice(0-9): 1
9键入“1”,不会再进行硬件自检等步骤,直接重启系统,也可以选择0重启。
