S5500
2021-06-12提问
  • 1收藏,658浏览
创建了vlan10,设置端口1/0/1-1/0/2属于vlan10,设置了端口IP为192.168.10.1,下面怎么设置让接在这两个端口上面的设备自动获取到10段的IP地址,并且上网,请高手告诉我,谢谢!新手,麻烦详细讲~
粉丝:124人 关注:6人
使用DHCP来实现,以下是配置参考命令:
将交换机的名字修改为SW1:
[H3C]sysname SW1
在交换机分别创建VLAN 10、VLAN 20:
[SW1]vlan 10
[SW1-vlan10]quit
[SW1]vlan 20
[SW1-vlan20]quit
VLAN 10的IP设置为:192.168.10.1 255.255.255.0:
[SW1]int vlan 10
[SW1-Vlan-interface10]ip address 192.168.10.1 24
[SW1-Vlan-interface10]quit
VLAN 20的IP设置为:192.168.20.1 255.255.255.0:
[SW1]int vlan 20
[SW1-Vlan-interface20]ip address 192.168.20.1 24
[SW1-Vlan-interface20]quit
将GI1/0/1端口划分到VLAN 10:
[SW1]int gi 1/0/1
[SW1-GigabitEthernet1/0/1]port link-type access
[SW1-GigabitEthernet1/0/1]port access vlan 10
[SW1-GigabitEthernet1/0/1]quit
将GI1/0/2端口划分到VLAN 20:
[SW1]int gi 1/0/2
[SW1-GigabitEthernet1/0/2]port link-type access
[SW1-GigabitEthernet1/0/2]port access vlan 20
[SW1-GigabitEthernet1/0/2]quit
开启DHCP功能:
[SW1]dhcp enable
创建DHCP地址池,命名为VLAN10,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan10
[SW1-dhcp-pool-vlan10]network 192.168.10.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan10]gateway-list 192.168.10.1
[SW1-dhcp-pool-vlan10]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan10]quit
[SW1]
创建DHCP地址池,命名为VLAN20,分配网段、子网掩码、默认网关、DNS:
[SW1]dhcp server ip-pool vlan20
[SW1-dhcp-pool-vlan20]network 192.168.20.0 mask 255.255.255.0
[SW1-dhcp-pool-vlan20]gateway-list 192.168.20.1
[SW1-dhcp-pool-vlan20]dns-list 114.114.114.114
[SW1-dhcp-pool-vlan20]quit
粉丝:17人 关注:2人
需要在交换机上配置DHCP功能,方法如下:
Switch BSwitch C分别作为DHCP客户端和BOOTP客户端,从DHCP服务器Switch A获取IP地址
2-1 静态绑定地址组网图
(1)     配置接口的IP地址
[SwitchA-Vlan-interface2] ip address 10.1.1.1 24
(2)     配置DHCP服务
启用DHCP服务。
[SwitchA] dhcp enable
配置VLAN接口2工作在DHCP服务器模式。
[SwitchA-Vlan-interface2] dhcp select server
创建DHCP地址池0
[SwitchA] dhcp server ip-pool 0
配置采用静态绑定方式为Switch B分配IP地址。
[SwitchA-dhcp-pool-0] network 10.1.1.0 mask 255.255.255.0
配置域名服务器、网关地址。
[SwitchA-dhcp-pool-0] dns-list 10.1.1.2
[SwitchA-dhcp-pool-0] gateway-list 10.1.1.1
[SwitchA-dhcp-pool-0] quit
[SwitchA]
配置完成后,Switch BSwitch C可以从DHCP服务器Switch A分别申请到IP地址10.1.1.510.1.1.6,并获取相关网络配置参数。通过display dhcp server ip-in-use命令可以查看DHCP服务器为客户端分配的IP地址。
[SwitchA] display dhcp server ip-in-use
                 Hardware address
10.1.1.5         0030-3030-662e-6532-  Jan 21 14:27:27 2014  Static(C)
                 3030-2e30-3030-322d-
                 4574-6865-726e-6574
10.1.1.6         000f-e200-01c0        Jan 21 14:27:27 2014  Static(C)
