MSG360-4,默认AP模板问题,led-mode quiet
2021-06-13提问
  • 1收藏,1180浏览
对齐方式
  • 靠左
  • 居中
  • 靠右
出现的问题是:
我把default-group中的led-mode quiet指令删除后(undo led-mode quitet),不知道什么时候,这个指令经过一天又会自动增加回来了,麻烦各位老师,怎么会出现这个问题?怎么才能彻底删除这个指令?感谢
这是AC配置,网关模式 ,MSG360-4
<H3C>dis cu
 version 7.1.064, ESS 5425
 sysname H3C
 clock timezone Beijing add 08:00:00
wlan global-configuration
 nas-id cm-0-1353898-219801A14J9195Q0008J
 wlan band-navigation enable
 telnet server enable
 port-security enable
 dialer-group 1 rule ip permit
 ip redirects enable
 ip unreachables enable
 ip ttl-expires enable
 nat alg h323
 nat alg ils
 nat alg mgcp
 nat alg nbt
 nat alg rsh
 nat alg sccp
 nat alg sip
 nat alg sqlnet
 nat alg tftp
 nat alg xdmcp
 dhcp enable
 dns proxy enable
 ip host H3C 192.168.0.100
 ip host oauthindev.h3c.com 192.168.0.100
 ip host www.spiritapp-wlan-ac.h3c.com 192.168.0.100
 module-proxy work-mode route
 password-recovery enable
vlan 1
vlan 100
object-group ip address drsRule[1]_IPrange
 description traffic_policy_IP_range
 0 network range 192.168.0.200 192.168.0.220
object-group ip address drsRule[3]_IPrange
object-group ip address drsRule[5]_IPrange
 0 network host address 192.168.0.230
dhcp server ip-pool 1
 gateway-list 192.168.0.100
 network 192.168.0.0 mask 255.255.255.0
 address range 192.168.0.20 192.168.0.199
 dns-list 192.168.0.100
 static-bind ip-address 192.168.0.200 mask 255.255.255.0 hardware-address 3cfa-439d-18c8
 static-bind ip-address 192.168.0.201 mask 255.255.255.0 hardware-address 76bd-70f9-ff55
 static-bind ip-address 192.168.0.202 mask 255.255.255.0 hardware-address 7cd1-c3f2-5d21
 static-bind ip-address 192.168.0.230 mask 255.255.255.0 hardware-address 0c7a-15d2-0a1e
dhcp server ip-pool 100
 gateway-list 172.16.100.1
 network 172.16.100.0 mask 255.255.255.0
 dns-list 172.16.100.1
nqa entry xiaobei test
 type http
  frequency 5000
  history-record enable
  history-record number 1
  probe timeout 500
  url http://www.baidu.com
 nqa schedule xiaobei test start-time now lifetime forever
wlan service-template st_21879535715841958
 description 1
 ssid doqikui
 akm mode psk
 preshared-key pass-phrase cipher $c$3$YNKAMk5b5FMTx38d09ZBIMe9MvilCuRHcWrSs23S
 cipher-suite ccmp
 cipher-suite tkip
 security-ie rsn
 security-ie wpa
 service-template enable
interface Dialer1
 mtu 1492
 ppp ipcp dns admit-any
 ppp ipcp dns request
 dialer bundle enable
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 60
 ip address ppp-negotiate
 tcp mss 1452
 nat outbound
interface Dialer2
 mtu 1492
 dialer-group 1
 dialer timer idle 0
 tcp mss 1452
 nat outbound
interface Dialer3
 mtu 1492
 dialer-group 1
 dialer timer idle 0
 tcp mss 1452
 nat outbound
interface Dialer4
 mtu 1492
 dialer-group 1
 dialer timer idle 0
 tcp mss 1452
 nat outbound
interface Dialer5
 mtu 1492
 dialer-group 1
 dialer timer idle 0
 tcp mss 1452
 nat outbound
interface NULL0
interface Vlan-interface1
 ip address 192.168.0.100 255.255.255.0
interface Vlan-interface100
 ip address 172.16.100.1 255.255.255.0
interface GigabitEthernet1/0/5
 port link-mode route
 ip address dhcp-alloc
 nat outbound
 undo dhcp select server
 ipsec apply policy IPSEC_isakmp
 port link-mode bridge
interface GigabitEthernet1/0/4
 scheduler logfile size 16
scheduler job Job_close_wifi
 command 1 system-view
 command 2 wlan radio disable
scheduler job Job_open_wifi
 command 2 wlan radio enable
scheduler schedule Schedule_close_wifi
 user-role network-admin
 job Job_close_wifi
 time repeating at 23:59 week-day Sun Mon Tue Wed Thu Fri Sat
scheduler schedule Schedule_open_wifi
 job Job_open_wifi
 time repeating at 04:00 week-day Sun Mon Tue Wed Thu Fri Sat
line class aux
 user-role network-operator
line class console
line class vty
line aux 0
 authentication-mode scheme
 idle-timeout 0 0
 screen-length 0
line con 0
line vty 0 31
 undo info-center logfile enable
 nqa server enable
 time-range traffic_policy1_Range 11:30 to 14:00 working-day
 time-range traffic_policy3_Range 17:00 to 20:40 working-day
 time-range WIFITimeRange_sample 04:00 to 23:59 daily
 time-range traffic_policy5_Range 22:15 to 23:59 working-day
 ntp-service enable
 ntp-service unicast-server ***.***
domain cloud
 authentication portal none
 authorization portal none
 accounting portal none
domain extend-auth
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$6RBk3Kayti7RGy0B$TC6Iaj1v17kOwc2u1fRSuoYH2GdxH7q2cI7BkXSVARciTTxSrayN2K8/1N3YwuzQ9YJ4CDAVEqGFX5UGsI9v4w==
 service-type ssh telnet terminal http https
 session statistics enable
 portal host-check enable
 portal free-rule 2 destination ip any udp 53
 portal free-rule 3 destination ip any tcp 53
 portal free-rule 4 destination short.weixin.qq.com
 portal free-rule 5 destination mp.weixin.qq.com
 portal free-rule 6 destination long.weixin.qq.com
 portal free-rule 7 destination dns.weixin.qq.com
 portal free-rule 8 destination minorshort.weixin.qq.com
 portal free-rule 9 destination extshort.weixin.qq.com
 portal free-rule 10 destination szshort.weixin.qq.com
 portal free-rule 11 destination szlong.weixin.qq.com
 portal free-rule 12 destination szextshort.weixin.qq.com
 portal free-rule 13 destination ***.***
 portal free-rule 14 destination wifi.weixin.qq.com
portal web-server 1
 url http://192.168.0.100
portal web-server local-server
 url https://192.168.0.100/portal
portal web-server lvzhou-server
 url http://oasisauth.h3c.com/portal/protocol
 server-type oauth
portal local-web-server http
portal local-web-server https
portal extend-auth-server qq
portal extend-auth-server mail
 mail-protocol pop3 imap
 ip http enable
 ip https enable
url-filter policy drs
 default-action permit
app-profile drs
 url-filter apply policy drs
loadbalance link-group lg_chinatel
 transparent enable
loadbalance link-group lg_cmcc
 transparent enable
loadbalance link-group lg_cnc
 transparent enable
loadbalance link-group lg_educn
 transparent enable
loadbalance class class_chinatel type link-generic match-any
 match 1 isp chinatel
loadbalance class class_cmcc type link-generic match-any
 match 1 isp cmcc
loadbalance class class_cnc type link-generic match-any
 match 1 isp cnc
loadbalance class class_educn type link-generic match-any
 match 1 isp educn
loadbalance action action_chinatel type link-generic
 fallback-action continue
loadbalance action action_cmcc type link-generic
 link-group lg_cmcc
loadbalance action action_cnc type link-generic
 link-group lg_cnc
loadbalance action action_default type link-generic
 forward all
loadbalance action action_educn type link-generic
 link-group lg_educn
loadbalance policy policy_isp type link-generic
 class class_chinatel action action_chinatel
 class class_cnc action action_cnc
 class class_cmcc action action_cmcc
 class class_educn action action_educn
 default-class action action_default
virtual-server vs type link-ip
 virtual ip address 0.0.0.0 0
 lb-policy policy_isp
 loadbalance isp file flash:/lbisp/lbispinfo_factory.tp
 wlan rrm calibration-power interval 30
 wlan auto-ap enable
 wlan auto-persistent enable
wlan ap-group default-group
 led-mode quiet
 vlan 1
 ap-model SPM-X1-10
  gigabitethernet 1
  gigabitethernet 2
  gigabitethernet 3
  gigabitethernet 4
  gigabitethernet 5
  gigabitethernet 6
  gigabitethernet 7
  gigabitethernet 8
  gigabitethernet 9
  gigabitethernet 10
  gigabitethernet 11
  gigabitethernet 12
 ap-model SPM-X1-24
  gigabitethernet 1
  gigabitethernet 2
  gigabitethernet 3
  gigabitethernet 4
  gigabitethernet 5
  gigabitethernet 6
  gigabitethernet 7
  gigabitethernet 8
  gigabitethernet 9
  gigabitethernet 10
  gigabitethernet 11
  gigabitethernet 12
  gigabitethernet 13
  gigabitethernet 14
  gigabitethernet 15
  gigabitethernet 16
  gigabitethernet 17
  gigabitethernet 18
  gigabitethernet 19
  gigabitethernet 20
  gigabitethernet 21
  gigabitethernet 22
  gigabitethernet 23
  gigabitethernet 24
 ap-model WAP711H
  radio 1
   radio enable
   bandwidth-guarantee enable
  ethernet 1
  ethernet 2
  ethernet 3
 ap-model WAP712C
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
 ap-model WAP712C-HI
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
 ap-model WAP712C-LI
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
 ap-model WAP712E
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
 ap-model WAP712H
  radio 1
   radio enable
  radio 2
   radio enable
  ethernet 1
  ethernet 2
  ethernet 3
 ap-model WAP722
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
  gigabitethernet 2
 ap-model WAP722E
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
  gigabitethernet 2
 ap-model WAP722E-W2
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
  gigabitethernet 2
 ap-model WAP722H
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
  gigabitethernet 2
  gigabitethernet 3
  gigabitethernet 4
  gigabitethernet 5
 ap-model WAP722S
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
 ap-model WAP722S-W2
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
 ap-model WAP722S-W2-IOT
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
  gigabitethernet 2
 ap-model WAP722X-W2
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
  gigabitethernet 2
  gigabitethernet 3
 ap-model WAP722XS-W2
  radio 1
   radio enable
  radio 2
   radio enable
  gigabitethernet 1
  gigabitethernet 2
  gigabitethernet 3
 ap-model WAP723-W2
  radio 1
   radio enable
  radio 2
   radio enable
  radio 3
   radio enable
  gigabitethernet 1
  gigabitethernet 2
wlan ap wap712h model WAP712H
 serial-id 219801A1B69136QFD04P
 vlan 1
 radio 1
  max-power 15
  radio enable
 radio 2
  max-power 19
  radio enable
 ethernet 1
 ethernet 2
 ethernet 3
wlan ap wap722s model WAP722S
 serial-id 219801A0VW9025GDC0NQ
 vlan 1
 radio 1
  channel 165
  max-power 15
  radio enable
 radio 2
  channel 11
  max-power 8
  radio enable
 gigabitethernet 1
traffic-policy
 rule name xiansu
  action qos profile traffic_policy1_Rate
  source-address address-set drsRule[1]_IPrange
 rule name xiansu@weberT
  destination-address address-set drsRule[1]_IPrange
 rule name PMxiansu
  action qos profile traffic_policy3_Rate
  source-address address-set drsRule[3]_IPrange
 rule name PMxiansu@weberT
  destination-address address-set drsRule[3]_IPrange
 rule name thinkpad
  action qos profile traffic_policy5_Rate
  source-address address-set drsRule[5]_IPrange
 rule name thinkpad@weberT
  destination-address address-set drsRule[5]_IPrange
 profile name traffic_policy1_Rate
  bandwidth downstream maximum 512
  bandwidth upstream maximum 512
  bandwidth upstream maximum per-ip 460
  bandwidth downstream maximum per-ip 460
 profile name traffic_policy3_Rate
  bandwidth upstream maximum per-ip 409
  bandwidth downstream maximum per-ip 409
 profile name traffic_policy5_Rate
  bandwidth upstream maximum per-ip 512
  bandwidth downstream maximum per-ip 512
 wlan drs enable
 cloud-management server domain oasis.h3c.com
return
粉丝:14人 关注:0人
命令删除后,保存下配置,再观察下
4 个回答
粉丝:124人 关注:6人
删除后保存配置看下是否还在。
另外看下设备的软件版本是否最新,可考虑升级到最新。
zhiliao_Tuomh 知了小白
已经保存了
粉丝:5人 关注:1人
是不是没保存或者没保存成功设备重启了
save fo快速保存一下
粉丝:17人 关注:5人
这是组里的默认的配置命令,不用管他啊,又不会影响什么。
