imc的数据库异常
2021-06-17提问
  • 1收藏,695浏览
imc的告警用不了,然后历史的告警全无了,上到智能部署监控代理查看,发现没有连接到数据库monitor_db数据库,上数据库平台看到 monitor_db(可疑)。有可疑字样,该如何解决,已经重启过了。
异常截图和txt日志如下
com.microsoft.sqlserver.jdbc.SQLServerException: 无法打开登录所请求的数据库 "monitor_db"。登录失败。 ClientConnectionId:c194657c-56da-4c1e-a71b-9485ae712962 at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:216) at com.microsoft.sqlserver.jdbc.TDSTokenHandler.onEOF(tdsparser.java:254) at com.microsoft.sqlserver.jdbc.TDSParser.parse(tdsparser.java:84) at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(SQLServerConnection.java:2908) at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:2234) at com.microsoft.sqlserver.jdbc.SQLServerConnection.access$000(SQLServerConnection.java:41) at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(SQLServerConnection.java:2220) at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:5696) at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:1715) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1326) at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:991) at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:827) at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1012) at java.sql.DriverManager.getConnection(DriverManager.java:582) at java.sql.DriverManager.getConnection(DriverManager.java:154) at com.h3c.imc.deploy.dma.EnvPanel.a(EnvPanel.java:1108) at com.h3c.imc.deploy.dma.EnvPanel.E(EnvPanel.java:1061) at com.h3c.imc.deploy.dma.EnvPanel.a(EnvPanel.java:128) at com.h3c.imc.deploy.dma.az.run(EnvPanel.java:625)
paner 九段
粉丝:33人 关注:3人
可以参考下该案例:https://zhiliao.h3c.com/Theme/details/18638
